Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Sep 2012, 12:10   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Hitachi targets quartz glass for long-term storage
Just don't drop it, whatever you do.
http://www.bit-tech.net/news/hardwar...tachi-quartz/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 25th Sep 2012, 13:02   #2
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
I always thought the problem with 'long term' storage was not the media, but the hardware needed to read it.
There's plenty of old data stored on various formats out there...but the hardware needed to read them, dies long before the data does.
Hustler is offline   Reply With Quote
Old 25th Sep 2012, 13:36   #3
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run Crysis
Precisely. Hieroglyphs stored on stone tablets are still with us 3,000 after they were written - the problem is reading the language, not identifying the shapes.
__________________
Intel Core i5-2500K | 8Gb Corsair Vengeance DDR3 1,600 Mhz
Gigabyte Geforce 460 GTX OC 1Gb | 1Tb + 1.5Tb Samsung Spinpoint F3 | Asrock Z68 Extreme4
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 25th Sep 2012, 13:48   #4
nmunky
What's a Dremel?
nmunky has yet to learn the way of the Dremel
The data on the disc is not in some "magical format" it's binary data.
Binary.
It's either 1 or 0, the same as sectors on a HDD platter, the pits on a CD/DVD or the flip flops in a static RAM chip. Imagine writing your name in the sand, then writing your name on a piece of paper. The process is the same and the storage method is the same, only the medium differs.
You can see the shapes on a stone hieroglyph just fine but you have no idea what they say.
Data on old formats is the opposite problem.
nmunky is offline   Reply With Quote
Old 25th Sep 2012, 13:53   #5
fellix_bg
What's a Dremel?
fellix_bg has yet to learn the way of the Dremel
Well, the binary code is the simplest one so reading shouldn't be an issue, but interpreting the meaning. Simple logic/math rules (predicates) can be used as a guide of how to understand and link the pseudo-random bits for the far future generations.
fellix_bg is offline   Reply With Quote
Old 25th Sep 2012, 13:58   #6
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
"impressively capacious" as they have demonstrated a storage density 15% greater than CD-ROM.
That's CD-ROM, not DVD-ROM or BD-ROM.
They're talking about 40MB per square inch!
It's a long way from electronic quantum holography that has been demonstrated to store at a rate that's equal to 3 Exabytes per square inch (That's three million terabytes to you and I)
We don't need archival mechanisms that will store data for millions of years. We need massively high capacity storage solutions that are robust and cheap enough to use and replace later on with the next big thing.
If they can get the storage density up to usable levels and it's cheap to write and read (Ha! I found the flaw. It's cost) this could be a winner.
Guinevere is offline   Reply With Quote
Old 25th Sep 2012, 14:02   #7
Gareth Halfacree
WIIGII!
bit-tech Staff
Originally Posted by Guinevere View Post
"impressively capacious" as they have demonstrated a storage density 15% greater than CD-ROM. That's CD-ROM, not DVD-ROM or BD-ROM. They're talking about 40MB per square inch!
Yes, in a first-generation lab prototype. It's likely to be significantly higher than that when (if) it reaches shop shelves.
__________________
Old 25th Sep 2012, 14:28   #8
Star*Dagger
Banned
Star*Dagger has yet to learn the way of the Dremel
Technology will march on, adapt or die.
Star*Dagger is offline   Reply With Quote
Old 25th Sep 2012, 16:37   #9
MrJay
You are always where you want to be
MrJay's Avatar
MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.
Am i the only one who is thinking of the tacky laser cut crystal ornaments with the colour changing LED base that you can buy?
I have one with 'Jay' laser etched inside (family has some bizarre ritual of buying ker-ings and **** with my name in/on).
Im guessing this is the same principle, just with some kind of practical application...rather than tatty gift shop w**k
__________________
Main Phanteks Enthoo ITX Windowed - Pentium G3258 @ 4.5GHz - 8GB Samsung DDR3 @ 1600 MHz - Sandisk Ultra 240GB - EVGA 760 SC 2GB - Asrock Z97M-ITX/ac - Windows 10
HTPC Intel NUC (Celeron 847) - 30GB Samsung mSATA SSD - 2GB Crucial RAM 1333MHz - Windows 10
MrJay is offline   Reply With Quote
Old 25th Sep 2012, 16:40   #10
Fizzban
Man of Many Typos
Fizzban's Avatar
Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.
Come on I want my B5 data crystal already!
__________________
-Banana in disc drive error-
To win the battle, is to be prepared to die - Miyamoto Musashi
Originally Posted by RedFlames View Post
Asking to pick between the main parties is like asking which testicle you want to be kicked in, you're gonna get kicked the nuts whoever you pick... Just have to hope whoever you pick aren't wearing steelies...
Fizzban is offline   Reply With Quote
Old 25th Sep 2012, 17:52   #11
PingCrosby
Supermodder
PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.
"Designed to last a million years", better keep that receipt safe...
PingCrosby is offline   Reply With Quote
Old 25th Sep 2012, 20:48   #12
greigaitken
Supermodder
greigaitken has yet to learn the way of the Dremel
is the R&D sponsored by facebook?
greigaitken is offline   Reply With Quote
Old 25th Sep 2012, 22:05   #13
Sloth
#yolo #swag
Sloth's Avatar
Sloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming Saiyan
I was thinking much the same, but with Christmas tree ornaments. It can store all of your photos and videos from previous years in a tacky little ornament to put on future trees!
Also, I never figured your username was your actual name. Jay pride! (pun intened )
__________________
Intel i5 2500k | Gelid Tranquillo | ASUS P8P67 | G.Skill Ripjaws 8GB | XFX 7970 Black Edition | SeaSonic X650 | Intel X25-M 160GB | WD Caviar Black 1TB | CoolerMaster HAF922
Dell U2412M | 2x Samsung Syncmaster 931B | SteelSeries Siberia V2 | Razer DeathAdder 2013 | Leopold FC200RR/AB | Leopold FC200RC/AB
Sloth is offline   Reply With Quote
Old 26th Sep 2012, 08:05   #14
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.
I think people need to look beyond their own domestic uses for technology to see the true benefit in something like this - obviously nobody needs such robust storage for home use, and I doubt this will ever see a place in the home. But it would be IDEAL for use in extreme environments. Interplanetary / interstellar travel would be a good example - the harsh EM radiation, magnetic fields, temperature extremes of deep space and the shock / heat of launch and reentry are all tough on existing storage media, so something like this (literally carved in stone!) would be ideal. You could use it on a terraforming mission to carry DNA strings for reconstruction of Earth organisms (I'm getting a bit sci fi but this has in seriousness been suggested).
Or say we discovered a distant civilisation - a probe enclosing a message from us would take (at least) thousands of years to travel to another star, and it would be relatively trivial for any sufficiently technologically advanced civilisation to decode a series of optical binary digits in a rock - and bear in mind that they'd need to be at - at least - 19th century human level for us to pick them up in the first place from radio transmissions at the time their signals were sent - add on signal transit time, probe construction time and the time it would take the probe to reach them and they would likely either have reached a technological level far in advance of our state of the art, or have wiped themselves out. They could safely and non-destructively examine the object, would quickly realise it contained ordered binary data, and reconstruct the bitstream. Assume it was primarily ASCII or Base64 encoded text - they'd work out very quickly that it was an 8 or 6 bit (respectively) encoding scheme, especially if we started with some sort of header to guide them to that conclusion. Conveying text information would be difficult with no common language, but numerical information could be exchanged. You could also convey bitmap images (either as binary data strings or by physically engraving the image in the rock using the same laser technology), in which you'd show schematics for more complex data formats. Think of the resources humanity would throw at decoding a message from an alien civilisation. One can imagine that they would do the same, and they'd very quickly get to the point where they could access any data format we had sent, including video and audio, star charts, maps of Earth, etc. There would be debates for years about what to include, because we wouldn't necessarily want to give away too much information to an unknown alien race, but we could send whatever we liked, assuming data density did go up a fair amount from 40 MB/in2...
Anyway, there's my flight of fancy for this morning :-)
__________________
mclean007 is offline   Reply With Quote
Old 26th Sep 2012, 08:15   #15
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
How does one type a nerdly snort? :P
fluxtatic is offline   Reply With Quote
Old 26th Sep 2012, 09:12   #16
julianmartin
resident cyborg.
julianmartin's Avatar
julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.julianmartin is definitely a rep cheat.
Holy ****. They're developing goa'uld control crystals.
__________________
work
Xeon X5660||Asus P6X58D-E||12GB XMS3||240GB SSD||GTX770||Define R3||X58 forever
julianmartin is offline   Reply With Quote
Old 26th Sep 2012, 09:36   #17
MrJay
MrJay's Avatar
That is the ultimate in tackiness!
And yep, they think its such an unusual name (not really) so come any kind of gifting period, i get **** with my name on it. : P
__________________
Old 26th Sep 2012, 16:56   #18
Hakuren
Multimodder
Hakuren has yet to learn the way of the Dremel
Babylon 5 Data Crystals are HERE!
Let's rejoice.
Hakuren is offline   Reply With Quote
Reply
Tags
femtosecond laser, hitachi, kiyotaka miura, kyoto university, optical storage, quartz glass, storage
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
