Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 26th Sep 2012, 10:48   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Intel puts Sandy Bridge parts out to pasture
Massive list of Sandy Bridge chips put on death row - including the i5-2500K - along with, for some reason, a single Ivy Bridge chip...
http://www.bit-tech.net/news/hardwar...e-retirement/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 26th Sep 2012, 11:00   #2
Elton
Officially a Whisky Nerd
Elton's Avatar
Elton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming Saiyan
I'd say they probably discontinued the 3450 on the fact that it's not necessarily needed. Judging by the SKUs the 3450 sits right by the 3470 but is hardly any cheaper and the new 3350 basically is the same chip bar a small decrease in turbo frequency. I guess you could say they're just cutting back on the SKU confusion although to me it's still a tad baffling to see that many SKUs of the same damn chip.
__________________
Gotta keep it 100 we got fundamentals.
Elton is offline   Reply With Quote
Old 26th Sep 2012, 11:05   #3
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
And you didn't even considered Xeon E3's there, which are the same thing again, just with a minor differences.
faugusztin is offline   Reply With Quote
Old 26th Sep 2012, 11:08   #4
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
They could at least add support of 1.35V DDR3 to Ivy Bridge. This is supported by SB .
What's the point of reducing the power consumption of the CPU if they do not support low voltage RAM module (which were supported by the previous gen) ?
GuilleAcoustic is offline   Reply With Quote
Old 26th Sep 2012, 13:01   #5
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Still not moving to Ivy Bridge due to the heat issues, and the fact I am happy with my 2700k but if that was to fall over I would just replace it with another sandy bridge based chip, or save the extra cash up and go sandy bridge e.
Sandy bridge was always going to be discontinued and I thought it would have been sooner than now though.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 26th Sep 2012, 13:04   #6
Platinum
Multimodder
Platinum has yet to learn the way of the Dremel
My 370k runs quite happily with my 1.35v memory, set it in the bios and no issues?
Platinum is offline   Reply With Quote
Old 26th Sep 2012, 13:12   #7
GuilleAcoustic
Ook ? Ook !
I've read somewhere that it can't run @1.35V with desktop IB (but can be run @1.5V)
Old 26th Sep 2012, 13:43   #8
K.I.T.T.
Hasselhoff™ Inside
K.I.T.T.'s Avatar
K.I.T.T. has yet to learn the way of the Dremel
Well I'm glad I've already got my paws on the i5 3450S I wanted but I did spend a good while looking at the range trying to understand what was going on with the position of the vanilla 3450.
__________________
i7 3770K @ 4.6GHz [WC] | 16GB Corsair Dominator Platinum | 2x Power Color HD7870 PCS+ [WC] | Asus P8Z77WS | Corsair AX850 | 250GB Samsung 830 | 1TB WD Caviar Black
K.I.T.T. is offline   Reply With Quote
Old 26th Sep 2012, 14:44   #9
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
just because a chip does not support something on a box does not mean it wont work. Ivy bridge happily accepts 1.35v on memory if you can find the relivent chips. Officially remember the intel cpus do not support ram above 1600mhz that does not stop us running 2100 + in them.
rollo is offline   Reply With Quote
Old 26th Sep 2012, 14:50   #10
GuilleAcoustic
Ook ? Ook !
Just want to be sure, because some say "yes it works", others say "yes it works, but @1.5V" while the last ones say "no it doesn't".
I sent an email to Intel to have a fix and 100% safe answer. I'm building a low power ITX professionnal rig and don't want to buy 1.35V ram to have it running @ 1.5V.
Old 26th Sep 2012, 15:00   #11
azazel1024
Supermodder
azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.
I am happily running 1.25v memory with my 3570 and it is running at 1.25v and the spec'd 1600mhz and 9-9-9-25 timing.
The processor/memory controller has no issue running lower voltage memory.
Heck my laptop with an i3517u is running its memory at 1.28v (it is 1.35v memory, but for some reason the BIOS is volting it even lower, and it is running just fine also at 1600mhz and 9-9-9-27).
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 26th Sep 2012, 15:04   #12
GuilleAcoustic
Ook ? Ook !
Glad to read that . Still the internal core temp issue, but bet there will be not much diff between i3-2120T and i3-3220T.
Old 26th Sep 2012, 17:37   #13
Griffter
Supermodder
Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!
Core i5-3450 discontinued i think cos there is some problem or patent issue with it and rather than have a recall stop selling it. i think cover-up. for microsoft, i dont think thats a wild theory at all.
Griffter is offline   Reply With Quote
Old 26th Sep 2012, 17:50   #14
faugusztin
What does Microsoft has to do with this topic ? Problem ? Patent issue ?
The only issue i5-3450 has that it has the same price as i5-3470, which is 100Mhz higher, so it is not selling well. Also, if you would have bothered reading the article, you would have noticed the "All models will continue to be purchasable until the end of March 2013" line.
Old 26th Sep 2012, 23:38   #15
Chris_Waddle
Trying hard not to upgrade again
Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.
I've just built my wife a new machine with the 3330 on a Z77 board and it's running fine at 1600mhz 1T at 1.35v.
On topic, I am surprised it's taken so long for this announcement. I think it more to do with them having had very large stocks of them, rather than they have just stopped making them. I would be amazed to think that they have still be making them when ivy bridge has been around for so long.
Chris_Waddle is offline   Reply With Quote
Old 27th Sep 2012, 02:14   #16
Elton
Elton's Avatar
So basically they're going to re-flash that ivy bridge one. Streamlining SKUs isn't too bad.
__________________
Old 27th Sep 2012, 05:59   #17
sui_winbolo
Giraffe_City
sui_winbolo's Avatar
sui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysis
Not very surprising, glad I got my i5-2500k when I did, it's a great CPU.
__________________
Giraffe01
:: Intel i5-2500K | ASUS P8Z68-M Pro | Corsair LP 8GB RAM | XFX 6870 1GB |
WD Velociraptor 300GB HDD | Corsair Pro 650w PSU | Silverstone MATX Case ::
sui_winbolo is offline   Reply With Quote
Old 27th Sep 2012, 07:49   #18
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.
"some problem or patent issue"; "cover-up"; "microsoft"? This sounds like crazy person speak from someone living in a basement full of canned goods and wearing a tinfoil hat, but thanks for taking part. If you know of a specific flaw in the CPU, or a specific legal issue with it, please enlighten us.
__________________
mclean007 is offline   Reply With Quote
Old 27th Sep 2012, 07:52   #19
mclean007
Officious Bystander
mclean007's Avatar
This is likely right - they've realised they have fragmented too far, and will speed bin the chips destined to end up as 3450s between 3470 for the chips capable of reliably handling the fastest speeds and 3350 for the less capable ones.
__________________
Old 27th Sep 2012, 07:55   #20
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
Dude, can you recommend a good source for tinfoil? The cheap stuff from the grocery store makes terrible hats.
On topic, I've been wondering lately why I still see so many computer ads for boxes with SB processors. I assumed they had been discontinued a while ago and it was just the OEMs selling through existing stock. Or that Intel dumped a load of them cheap and Dell and the like snapped them up to shove them in lower-end machines.
fluxtatic is offline   Reply With Quote
Reply
Tags
22nm, 32nm, i5-2310, i5-2320, i5-2400s, i5-2405s, i5-2500, i5-2500k, i5-2500s, i5-2500t, i5-3450, i7-2600k, i7-2600s, i7-2700k, intel, ivy bridge, mooo, sandy bridge
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
