Reply
Thread Tools View Mode
Old 26th Sep 2012, 22:23   #1
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
K.3nny's C-BonizeD DangerDen acrylictubes!
Heey lads,
I had a break for like 8? months :P so i started this 1 week ago
Let go!
Put the case onto the Carbon vinyl
Cut everything out
Stick it!
Thnks to L3P i had some black assortiment of inbusses
Finished!
Tried something original with the Window panel
Better pics in Daylight.
Bought some random hardware
New:
OCZ OCZSSD2-2VTXE120G, voor die 60 euro
Used
Mobo en Cpu
Asus Rog maximus 3
Intel 875K
Carbonize the cpu block till i can afford a identical plexi one
mobo with memory build
Testfit in the case, getting cramped already :P
I have some little room left
With sidepanel
positioned the Dual pump and drilled the holes for it.
Bought at my local plumber store 2 metre of acrylic tubing.
First try
My working bench
Heat it up, hold it inplace, take a sprint to kitchen and cool it down, mission succesfull!
Bp C47 where in the mail, gladly !:
Same as the SSD!
Prepared the tubing for the fittings, Just like Kier does, grind a 8mm edge.
Then i used speedhack! lol, i forgt to make shots of the buildup progress :P
I dont have budget for the sleeving, maybe next month
Because there is no room between panel and mobotray, i need to route everything between the mobo and the mobopanel, but it worked
thats all folks!
k.3nny is offline   Reply With Quote
Old 27th Sep 2012, 03:39   #2
whyte
Multimodder
whyte's Avatar
whyte has yet to learn the way of the Dremelwhyte has yet to learn the way of the Dremel
Really love the case. The window you made is amazing. And last but not least, the acrylic tubes are sooo coool.
__________________
Project Carbon Apple
whyte is offline   Reply With Quote
Old 27th Sep 2012, 07:03   #3
xD3aDPooLx
Minimodder
xD3aDPooLx has yet to learn the way of the Dremel
k.3nny, bout time your back. This is freaking killer man. How long did it take to get the case all done.
xD3aDPooLx is offline   Reply With Quote
Old 27th Sep 2012, 07:09   #4
k.3nny
Hypermodder
k.3nny's Avatar
Wrapping about 30 mins
Plumbing, around 4 hours
Old 27th Sep 2012, 07:50   #5
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Nice job on the CF and tubing!
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 27th Sep 2012, 08:41   #6
k.3nny
Hypermodder
k.3nny's Avatar
Ty sir!
Old 27th Sep 2012, 10:48   #7
k4p84
Modder
k4p84 has yet to learn the way of the Dremel
Hey,
Very nice build you have there.
Regards
Ed
k4p84 is offline   Reply With Quote
Old 27th Sep 2012, 13:44   #8
maestro0428
Master Modder
maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.
Now that is how tubing is done! That looks so much better than all those damn fittings. Never been a fans of those. Nice work.
__________________
JAllen Labs GT1000- 3770K @ 4.5ghz, 32GB Dominators, ASUS 660GTX OC SLI, Samsung 840 Pro 256GB SSD, 4 drive RAID 0 and 3TB storage in a Silverstone Fortress GT03, Logitech G9X Gaming mouse on Razer eXact Mat, Custom built Fostex studio monitors, Yamaha amp, Nvidia Surround 3x23.5 AOC LED LCDs
maestro0428 is offline   Reply With Quote
Old 27th Sep 2012, 14:32   #9
k.3nny
Hypermodder
k.3nny's Avatar
Originally Posted by k4p84 View Post
Hey,
Regards
Ed
Thnks ed !
Haha, yeah i was tired of the tubing also, always so "hanging around"
So, i fixed it
Old 27th Sep 2012, 15:23   #10
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
These TFC Triebwerk fans are really badass
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 27th Sep 2012, 16:31   #11
k.3nny
Hypermodder
k.3nny's Avatar
Some what clearer pics taken with a handycam
not allot of tekst, just better pics
Did some random sleeving, put 24/gpu extenders, black SATA cable and much better cablemanagement
Also did a boot
Old 29th Sep 2012, 16:14   #12
k.3nny
Hypermodder
k.3nny's Avatar
Soo, its quite done now, The system is up and running smoothly after some flaws,
First, because the solid tubing didnt expand to pick up the pressure what was left behind when u turn the system off i had some minor leaks, after a little chat Peter(l3p) came with an idea, that was to make a kind of balance line of 1/2tubing, so i made it like he suggested, and damn it worked, was a miracle! its running real smoothly now, Gladly
Piics
Old 29th Sep 2012, 16:36   #13
Oso Polar
What's a Dremel?
Oso Polar's Avatar
Oso Polar has yet to learn the way of the Dremel
looks awesome mate. Great job!
Oso Polar is offline   Reply With Quote
Old 30th Sep 2012, 11:24   #14
k.3nny
Hypermodder
k.3nny's Avatar
Thnks !
Old 30th Sep 2012, 12:46   #15
l3p
www.^.nl
l3p's Avatar
l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.
Love the piping Kenneth!
__________________
Preparing: Raz3r D3sk
Finished : L3p Parvum - Cross - L3p AlCu - L3p L4n - L3p D3sk
Sites: www.l3p.nl - www.redharbinger.com
l3p is offline   Reply With Quote
Old 30th Sep 2012, 12:54   #16
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Sweet build man!
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 30th Sep 2012, 13:33   #17
Meelobee
< Your add here >
Meelobee's Avatar
Meelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run Crysis
Nice work
Meelobee is offline   Reply With Quote
Old 1st Oct 2012, 14:54   #18
k.3nny
Hypermodder
k.3nny's Avatar
Thnks L3p
Originally Posted by Editor22 View Post
Sweet build man!
thnks !
Originally Posted by Meelobee View Post
Nice work
Thnks man ! I like the standup bench your doin!
Old 25th Oct 2012, 15:44   #19
k.3nny
Hypermodder
k.3nny's Avatar
Stil leakfree!
after 24 days
stresstest and gaming etc no problem !
Old 25th Oct 2012, 16:59   #20
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
I missed this whole project some how.. That is a wicked build Kenny, it all just works really well together. I love the idea for using solid clear tubing as well.
Another top build, well done dude. Looks brilliant.
bulldogjeff is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
