Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 28th Sep 2012, 09:42   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Adapteva Parallella promises pocket-sized supercomputing
16 or 64 cores of parallel processing goodness alongside a dual-core CPU, in a board the size of the Raspberry Pi? Interesting...
http://www.bit-tech.net/news/hardwar...a-parallella/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 28th Sep 2012, 10:24   #2
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Bet this would be great for folding.
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 28th Sep 2012, 13:07   #3
sixfootsideburns
modeteer
sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.
bet this would be great for almost anything computer related!
sixfootsideburns is offline   Reply With Quote
Old 28th Sep 2012, 15:31   #4
greigaitken
Supermodder
greigaitken has yet to learn the way of the Dremel
i'd get some if i had a need and budget fo custom made software. i dont. surely by the time you spend £50k developing your software... you could have bout some bulldozers.
greigaitken is offline   Reply With Quote
Old 28th Sep 2012, 17:02   #5
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
Given the press this is getting I was hoping they would have a wider range of examples available online. The performance is promising but the specific details are a bit vague. How does one of these 64 cores compare to say a core in dual/quad core ARM for example? They've shown off a simple math example, but how about something that's a bit more 'Wow!' guys.
Guinevere is offline   Reply With Quote
Old 29th Sep 2012, 01:11   #6
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
Not impressed at all! Look at the video, is uber SLOW !
Gradius is offline   Reply With Quote
Old 29th Sep 2012, 07:36   #7
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
Yeah, but it doesn't have the GPU muscle the RPi does. It'd be great for...uh...um...hm. Let me get back to you on that. :P
fluxtatic is offline   Reply With Quote
Old 29th Sep 2012, 17:44   #8
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
For $100, that is actually pretty cheap and a better value than almost any other ARM platform.
The problem is if the performance-per-watt is worth it. An intel or possibly AMD system might be a better choice in the end. Lets hope phoronix tests this out, they did a pandaboard cluster pitted against some intel processors and didn't prove to be a better investment, although it wasn't explicitly worse either.
Since this new board has all these cores on 1 system, it's bound to have much better ppw than the pandaboard cluster.
schmidtbag is offline   Reply With Quote
Old 30th Sep 2012, 07:10   #9
Roskoken
Multimodder
Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.Roskoken is a hoopy frood who really knows where their towel is.
Playing pretty fast and loose with the term "super computer" I think.
Roskoken is offline   Reply With Quote
Old 30th Sep 2012, 08:13   #10
docodine
killed a guy once
docodine's Avatar
docodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for president
If this is a super computer, what's mine? Future technology?
docodine is offline   Reply With Quote
Reply
Tags
adapteva, andreas olofsson, epiphany, epiphany-iii, epiphany-iv, gpio, kickstarter, microcomputer, parallel processing, parallella, raspberry pi
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
