Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 24th Apr 2012, 23:29   #101
Spotswood
Custom PC case builder
Spotswood's Avatar
Spotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the Dremel
Originally Posted by bluc View Post
Tried downloading the specs for the 5.25 bay cage but getting error 404 anyone got a live link?
Do you mean Form Factor of 5.25" CD Drives?
Spotswood is offline   Reply With Quote
Old 25th Apr 2012, 03:25   #102
bluc
Supermodder
bluc has yet to learn the way of the Dremel
Thanks spotswood thats what I was after what the usual gap between drives? or is it fine to have them flush against each other?
bluc is online now   Reply With Quote
Old 25th Apr 2012, 03:37   #103
kinghong1970
Just a Clumsy Ape
kinghong1970's Avatar
kinghong1970 has yet to learn the way of the Dremel
anyone have a link for form factor for slim cd drives that are used on laptops?
thanks in advance.
kinghong1970 is offline   Reply With Quote
Old 26th Apr 2012, 00:23   #104
Spotswood
Spotswood's Avatar
thanks in advance.
Specification for Form Factor of 5 1/4" 9.5mm and 12.7mm Height Optical Drives
__________________
Rich
Custom Case Builder
Old 3rd Jun 2012, 02:24   #105
bluc
Supermodder
Anybody have the dimensions for power supply mounting holes and exhaust airflow cutout? Sorry dont know how I missed it its in the atx specs pdf
EDIT: anybody know if the power supply mounting holes have changed since atx version 2.01 there is no power supply spec drawing in the latest atx pdf
Old 3rd Jun 2012, 14:51   #106
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
There you go...
NOTICE: All holes are mirrored to allow for installing in any direction.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 5th Jun 2012, 08:23   #107
bluc
Supermodder
Legendary thank you just what I needed!!
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
Old 30th Jan 2013, 07:52   #108
tekonivel
Multimodder
tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!
this thread is awesome!
tekonivel is offline   Reply With Quote
Old 14th Feb 2013, 17:30   #109
Blooddrunken
In Flames we Trust
Blooddrunken's Avatar
Blooddrunken has yet to learn the way of the Dremel
Thanks and +rep @jrs77
Blooddrunken is offline   Reply With Quote
Old 15th Feb 2013, 15:04   #110
GotMod?
Minimodder
GotMod?'s Avatar
GotMod? has yet to learn the way of the DremelGotMod? has yet to learn the way of the DremelGotMod? has yet to learn the way of the Dremel
Does anyone can help me to figure out lamtron fc5 front bezel dimension?
Need it to create a cnc cut template, wanna do something like this
I would appretiate any help, thanks!
__________________
'Monochrome' Lian Li V600FB - Finished
GotMod? is offline   Reply With Quote
Old 15th Feb 2013, 15:53   #111
jrs77
theorycrafting
jrs77's Avatar
Measurements are done via photo-comparison in Photoshop, but they should be rather accurate.
__________________
Old 15th Feb 2013, 17:52   #112
GotMod?
Minimodder
GotMod?'s Avatar
Thanks a lot! That's exactly what i was looking for!
__________________
Reply
Tags
guide
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
