#1 |
Minimodder
GTX670 folding support?
Hey guys, I have noticed that my Asus GTX670 isn't folding even with the GPU option active. After looking on here and the folding forums it seems that the 6 series isnt supported yet for folding and I was wondering when it is likely to be foldable. At the moment I am churning out a PPD of around 55k PPD although my PC is only on for about 8 hours a day if that so having the GPU running should hopefully bump up my PPD by a fair amount, cheers guys
__________________
#2 |
Cheesecake Nom Nom
it will fold you need to download a GPU.txt file and drop it on your f@h v7 client install folder i believe
im ot sure where you can download it... there is another thread somewhere with the details
__________________
2x Xeon 5620 @ 3.8GHz under water ![]() 3770k @ 4.8GHz, Custom loop, GTX680 OC'd |
#3 |
Minimodder
Ah ok, thank you very much, this whole folding thing is a bit new to me
__________________
#4 |
Cheesecake Nom Nom
you wouldnt have to do this usually but because the 6xx gpus are new and the v7 client doesnt update its self yet you need to download the gpu.txt file
and the 6xx kelper gpu's are not optimized for folding yet so they dont produce as mush ppd as they should
__________________
#5 |
Modder
Here is what you need to do its a bit of a pain in the butt but it works well -
http://www.overclock.net/t/1271684/w...ies-kepler-gpu |
#6 |
Was that a warranty I just broke?
That complicates it. All you need is to get the gpus.txt file from stanford and put it in the program directory. Then next t ime you load the v7 client (ie FAHControl) it will be detected and used. No external software is needed.
__________________
#7 | |
Modder
The tracker is very good and works well as you can do your cpu folding in a linux virtual machine and then run the GPU in the tracker which stops it slowing the cpu folding down as much. |
| Tags |
| gtx670 gtx 670 folding |
| Thread Tools | |
