Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Oct 2012, 09:51   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Aerocool X-Predator X1 review
http://www.bit-tech.net/hardware/cas...or-x1-review/1
brumgrunt is offline   Reply With Quote
Old 5th Oct 2012, 09:59   #2
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Not my favourite-looking case of all time, but that system of fan/drive mounts looks quite good!
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 5th Oct 2012, 11:23   #3
stupido
Minimodder
stupido has yet to learn the way of the Dremel
On the first page the "CPU cooler clearance 115mm" looks not correct...
stupido is offline   Reply With Quote
Old 5th Oct 2012, 11:33   #4
Speed
I'm all you need!
Speed's Avatar
Speed is a Super Spamming SaiyanSpeed is a Super Spamming SaiyanSpeed is a Super Spamming SaiyanSpeed is a Super Spamming SaiyanSpeed is a Super Spamming SaiyanSpeed is a Super Spamming SaiyanSpeed is a Super Spamming SaiyanSpeed is a Super Spamming SaiyanSpeed is a Super Spamming SaiyanSpeed is a Super Spamming SaiyanSpeed is a Super Spamming Saiyan
Looks like it should be 158mm without side panel fan. Source: http://www.aerocool.com.tw/index.php...-white-edition
Speed is offline   Reply With Quote
Old 5th Oct 2012, 11:40   #5
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
I could swear I remember typing it as 158mm... Anyway, fixed, thanks!
Dogbert666 is offline   Reply With Quote
Old 5th Oct 2012, 11:58   #6
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Off topic slightly but as you linked to it in the conclusion I thought you should know that Scan no longer sells the Antec One so could you recommend a different alternative please?
__________________
SchizoFrog is offline   Reply With Quote
Old 5th Oct 2012, 12:06   #7
Dogbert666
bit-tech Staff
Dogbert666's Avatar
The case recommendation remains the same, but Amazon have the Antec One in stock for 44.99
http://www.amazon.co.uk/Antec-One-Mi.../dp/B006TVQU6C
Old 5th Oct 2012, 12:38   #8
Pookie
Level 0
Pookie's Avatar
Pookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming Saiyan
If i was a stormtrooper I would buy this case
__________________
Unlimited Fibre Broadband 38Inc Per month including line Rental!
http://pulse8broadband.co.uk/fibreoptic-broadband
Pookie is online now   Reply With Quote
Old 5th Oct 2012, 12:47   #9
SchizoFrog
I *am* a Dremel
I'd prefer to use some blue lighting and add some blue details and go for the R2-D2 look.
__________________
Old 5th Oct 2012, 13:04   #10
Paradigm Shifter
de nihilo nihil fit
Paradigm Shifter's Avatar
Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.
I've seen far worse for a lot more money, when all is said and done. Not something I'll be buying, but I would imagine that it would perform much better with all the fan mounts filled - even with low-speed fans to save delicate ears. For a start, a pair of 140mm Fractal Design 1k RPM fans on the side would probably drop temps a lot.
__________________
Core i7 5820K | 32GB Crucial DDR4 | Asus Rampage V Extreme | Titan X | 1TB SSD + 6TB HDD | 7680x1440 + 1920x1200
Paradigm Shifter is offline   Reply With Quote
Old 5th Oct 2012, 18:47   #11
S1W1
Multimodder
S1W1's Avatar
S1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpit
I actually really like the look of the case.
Just me?
__________________
AMD X6 1090T OC @ 3.75GHZ | Corsair H50 cooler | 8GB Corsair XMS3 @ 1600MHZ | Asus M4N98TD Evo Motherboard | Gigabyte GTX 670 2GB OC| XFX 750W Black Edition PSU | Samsung 1TB Spinpoint F3 HDD | 300GB WD Velociraptor | Samsung 840 250GB SSD | NZXT Hades mid tower with red LEDS and engraved side panels | Windows 7 Home Premium 64bit | Asus Xonar DX |
=== Alienware M11X R3 laptop ===
S1W1 is offline   Reply With Quote
Old 7th Oct 2012, 10:35   #12
ec928
Minimodder
ec928 has yet to learn the way of the Dremel
Another generic cheap rubbish case review. CustomPC/Bit-Tech, not all of us are unemployed or students with no income. You review high end GPU's costing hundreds of pounds, so where are the 'equivalent' high end case reviews, why this obsession on ONLY low end kit when it comes to cases?
ec928 is offline   Reply With Quote
Old 7th Oct 2012, 13:49   #13
Speed
I'm all you need!
Speed's Avatar
There are quite a few high end case reviews if you look but as with anything a balance must be achieved. Most of the users of this site would not spend 200+ on a case, so personally the balance is pretty well thought out imho.
If you want reviews of other cases just... Google?!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
