Reply
Thread Tools View Mode
Old 19th Oct 2012, 15:00   #41
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
B NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run Crysis
Fan mount window...not pretty..
Cut a new one using the old as a template.
Fitted using the stock trim
So thats another thing off the list...
B NEGATIVE is online now   Reply With Quote
Old 24th Oct 2012, 13:10   #42
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
The kit from XSPC has arrived! Got some rarities in here too!
An unpainted prototype EX 360!
4 EX 120s of various colours!
A D5 bay and 2 normal bays!
Lets have a closer look shall we...
The evergreen XSPC bay res,staple of many builds.
The prototype 360,painted tanks and polished sides i think for this if i can squeeze it in.
The guys at XSPC did ask what colours i wanted,i said i didnt mind as they would be painted anyway.
So he sent a mix of unseen colours.
The D5 res i will be using if i can get a cheap pump.
A lot of kit for sure!
Once the fittings arrive,its all systems go!!
This custom loop wouldnt of got off the ground without the great team at XSPC.
I will try to do you proud!
Old 25th Oct 2012, 11:32   #43
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Started on the front cover panel,got it roughed out ready for prep and paint.
Gloss black with some yellow detailing is the look for this piece
Old 25th Oct 2012, 13:39   #44
_ferry_
Supermodder
_ferry_'s Avatar
_ferry_ has yet to learn the way of the Dremel
Maybe you should ad a 8Mbit warning in the title....
_ferry_ is offline   Reply With Quote
Old 25th Oct 2012, 17:51   #45
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Squigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the Dremel
some nice goodies there from XS !! That prototype 360 rad is prime for a steam punk themed mod! Really like the solid face-plate, think that's gonna finish it off nicely! Looking forward to the paint and detailing
__________________
Ω Omega Desk Ω
Squigly is offline   Reply With Quote
Old 25th Oct 2012, 22:40   #46
Waynio
Tetrep
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Nice progress & goodies.
800 pixels for biggest dimension seems to be the acceptable norm for good size pictures, if you did that with these they would load extremely fast for people considering the size of them at that res.
Waynio is offline   Reply With Quote
Old 26th Oct 2012, 06:51   #47
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
I will GIMP the pics in future to a more acceptable size,thanks for letting me know
Old 26th Oct 2012, 06:58   #48
thegyufi
on air
thegyufi has yet to learn the way of the Dremel
really good work with the new window, much better ! Maybe you can add some bullet impact like mnpctech already did, like this http://www.mnpctech.3dpixelnet.com/p...ch.com9z9i.jpg
keep modding !
__________________
[project log] Apple Cube
thegyufi is offline   Reply With Quote
Old 26th Oct 2012, 14:00   #49
Waynio
Tetrep
Waynio's Avatar
I need to look into how to make them show as 800 max dimension on forums but make them clickable so they can be seen as 1400 dimension at least once this is completed anyway otherwise full shots of this rig especially when altogether so much detail will be lost on small res.
Old 26th Oct 2012, 15:28   #50
SuicideNeil
I'm insane, not stupid.
SuicideNeil's Avatar
SuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for president
Same idea as clickable thumbnails- upload smaller versions to photobucket or flickr etc, and also the full size versions. Stick the [ img ] code to the smaller versions on the forum and have a url link to the full size versions ( like clicking a hyperlink, only the hyperlink is an image itself too ).
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
SuicideNeil is offline   Reply With Quote
Old 26th Oct 2012, 15:35   #51
Waynio
Tetrep
Waynio's Avatar
Thank you for that Neil bit more messing but worth it on final pictures. rep
Old 28th Oct 2012, 12:09   #52
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Seems a 360 fits in the top with no modding...other than taking a support beam in the drive bays out.
There is about 3/4 on an inch overhang on the ends but its wont interfere with air being exhausted.
The front panel got its final filing and etch coat today,so it will be finished by weds...
Now,I need to get a pump,spray the rad tanks and get the sides buffed up,then I start with the pipework!
Hopefully end of week it will be ready to fill up and have the loop signed off.
Old 28th Oct 2012, 12:45   #53
Phame
CNC mad!
Phame's Avatar
Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!
This is such a sweet case mod, executed flawlessly, love it dude.
__________________
'You had my curiosity, now you have my attention'
Work in the pipeline *Server*
Completed Projects. *Orange and Black* and *The Wet Pi*
Phame is offline   Reply With Quote
Old 29th Oct 2012, 14:26   #54
jinq-sea
Steering a Boat in Holland
jinq-sea's Avatar
jinq-sea is the Cheesecake. Relix smiles down upon them.jinq-sea is the Cheesecake. Relix smiles down upon them.jinq-sea is the Cheesecake. Relix smiles down upon them.jinq-sea is the Cheesecake. Relix smiles down upon them.jinq-sea is the Cheesecake. Relix smiles down upon them.jinq-sea is the Cheesecake. Relix smiles down upon them.jinq-sea is the Cheesecake. Relix smiles down upon them.jinq-sea is the Cheesecake. Relix smiles down upon them.jinq-sea is the Cheesecake. Relix smiles down upon them.jinq-sea is the Cheesecake. Relix smiles down upon them.jinq-sea is the Cheesecake. Relix smiles down upon them.
This is looking great - can't wait to see the finished product!
jinq-sea is offline   Reply With Quote
Old 30th Oct 2012, 10:25   #55
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
PIPEBENDING TIME!!!
The loop is in,just needs a a little tweaking here and there to get the lines right,but this is the layout.
Old 30th Oct 2012, 10:50   #56
Waynio
Tetrep
Waynio's Avatar
The customer is going to be extremely happy with this Neg, that's absolutely MOTY type pipe bendery, man your good at that.
Old 30th Oct 2012, 11:12   #57
Kovoet
Do I or Don't I
Kovoet's Avatar
Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.
I thought it might have been to small but i tell you what it looks absolute brilliant very very nice and clean
__________________
[Coolermaster Cosmos II] [i7 i2700K] [Hydro H100i] [ASUS GTX680 DirectCUii Top] [16GB Corsair Vengeance 1600mhz] [Asus Sabertooth Z77] [Corsair AX850] [1 x 300gb VelociRaptor] [1 x 1TB samsung F3] [Dell U2312H & U2311HM] [Corsair K90] [Belkin (razer) N52te] [ASUS ROG Vulcan] [120GB Corsair pro SSD] [ Mushkin 120GB deluxe SSD Sata 3 ][Logitech G9x] [ASUS Xonar DX soundcard]
Asus Nexus Tablet
Kovoet is offline   Reply With Quote
Old 30th Oct 2012, 11:33   #58
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
You flatter me Good Sir.
I would settle for MOTM myself....
I do think that copper is the way forward,it looks just so much cleaner!!
Thanks Mate!!
Old 30th Oct 2012, 12:35   #59
Nikkop
Multimodder
Nikkop's Avatar
Nikkop has yet to learn the way of the DremelNikkop has yet to learn the way of the Dremel
SO DAMN SEXY, DROOOOLS.
I love the color yellow, it's a shame it's such a rare color when it comes to computer-hardware. Luckily Asrock recently released their motherboard with yellow color-scheme, just right before I got my new motherboard so buying it wasn't an option
In fact, my next soon upcoming project will also have yellow as main-color (even tho my motherboard is red, unfortunately.)
But I love it, freaking damn hot.
Nikkop is offline   Reply With Quote
Old 30th Oct 2012, 16:57   #60
KrunchR
Supermodder
KrunchR's Avatar
KrunchR has yet to learn the way of the Dremel
Fantastic work mate!
KrunchR is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
