Reply
Thread Tools View Mode
Old 10th Oct 2012, 19:02   #1
Ace_finland
Multimodder
Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!
Test bench mod by Ace_finland NEED HELP
Hey guys,
So i entered the Cooler master mod competition this year and thought i would start a case mod log here.
I was thinking for ages for a case to pick and by accident i found the test bench by Cooler Master at a local computer store. I new instantly that this is the case i wanted to modify. It's different enough to other cases and i didn't find anyone else in the competition using the same case.
After countless hrs designing i think i came up with something worthwhile doing. I was gonna post earlier but after reading the rules i didn't start this thread before fabricating something. Not much to show but at least i have started
So this is the design I'm gonna stick with for now unless i change my mind for a 100th time
Its not the latest version but rendering takes too long so this will have to do. It won't be as glossy as the picture and if i have time I will make some custom gpu back plates and do something to the new Dominator platinum memory i have just gotten.
Also started fabricating the radiator boxes today.
Started with some kinda straight pieces of 1mm metal sheet. Decided on 1mm thickness to add some stability and still easy to fabricate
The machine
Bent a small test piece to figure out the radius and the measurement, also to get all the angles right.
Made four pieces so i can mess up two, easier to make extra now than going back to make two new ones
Quick test fit to see how its gonna look
Also the parts that arrived
Hope you like it and please comment, more comming soon!
Final shots!
Sponsored by:
Ace_finland is offline   Reply With Quote
Old 11th Oct 2012, 01:51   #2
whyte
Multimodder
whyte's Avatar
whyte has yet to learn the way of the Dremelwhyte has yet to learn the way of the Dremel
whoa.. got my attention. subbed.
__________________
Project Carbon Apple
whyte is offline   Reply With Quote
Old 11th Oct 2012, 01:56   #3
jay2
Poor Man PC Mod
jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.
subbed too.
jay2 is offline   Reply With Quote
Old 11th Oct 2012, 04:10   #4
bluc
Supermodder
bluc has yet to learn the way of the Dremel
Nice start bending brake and render are awesome. Gotta get a bending brake one day. subd
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
bluc is online now   Reply With Quote
Old 11th Oct 2012, 05:29   #5
Ace_finland
Multimodder
Thanks guys!
Old 11th Oct 2012, 16:36   #6
Phame
CNC mad!
Phame's Avatar
Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!
Looking good man, keep my eye on this!
__________________
'You had my curiosity, now you have my attention'
Work in the pipeline *Server*
Completed Projects. *Orange and Black* and *The Wet Pi*
Phame is offline   Reply With Quote
Old 15th Oct 2012, 07:47   #7
Ace_finland
Multimodder
Thanks Phame!
Back after a lot of hrs in the garage and at the workshop at work. Not much of an update when it's full of fail but thought i would share anyways.
Plan A
Cut a template of the size i wanted
Mark the piece to be cut
Working with my best friend (angle grinder)
After a lot of filing.
After this i realised cutting the next 3 slots in the metal will make it very thin and will flex and bend a lot. And the plan is to powder coat it after i'm done with it so i can't use any filler. so over to...
Plan B
Decided to get all the cuts before bending. Don't mind the tolerances, just forgot to adjust the digits
Make a "table" for the mill at work.
Used doubble sided sticky tape between the table and the metal sheets to prevent the pieces to vibrate during milling.
Fastened the sheets with screws in as many places as possible, i did not want the sheet to move during milling.
Let the milling begin. Still a Manual mill so need to be very focused
More fasteners used as it progressed.
Almost done, still need to deburr all the edges and as you can see in the red circle i made a bit of a mess. I had just finished that slot and turned the mill off without turning off the feed. So when i turned the mill on it went like a bat out of.... Words can not describe the feeling when that happened. I had spent 6 hrs milling just to do a simple mistake. Anyways, gonna weld it back and see if i can file it down. Wouldn't be a problem if i could use filler.
More updates coming tuesday-wednesday if i get the metal bent into shape.
Ace_finland
Old 15th Oct 2012, 09:16   #8
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Looking good so far
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 15th Oct 2012, 09:18   #9
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
interesting project here! main concern with CM benchtable (from reviews) was PCI-E card fixation (lack of it ) - interesting to see how it turns out! (and grab couple ideas to mod own bench table )
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 15th Oct 2012, 09:22   #10
Ace_finland
Multimodder
Originally Posted by Editor22 View Post
Looking good so far
Thanks!
Originally Posted by Vetalar View Post
interesting project here! main concern from reviews was PCI-E card fixation (lack of it ) - interesting to see how it turns out! (and grab couple ideas to mod own bench table )
i've been thinking how to solve the pci-e fixation, what i would like is something that can easily be deteached or something you can just clip onto the card cause it really needs support
Old 15th Oct 2012, 11:26   #11
Vetalar
*learning english*
in my own bench i've take 2 150mm m4 threaded rods near pci1 and pci7 and place 5mm thick PVC strip between 'em. and use self-tapping screws for card fixation...
like this, but right rod near audio connectors on MB
__________________
20 have a sleep
30 goto 10
Old 15th Oct 2012, 16:41   #12
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
Oh yeah, I really like the look of this one
bulldogjeff is offline   Reply With Quote
Old 15th Oct 2012, 18:41   #13
Ace_finland
Multimodder
Thanks for the idea, i was thinking something similar, it's just very hard to figure out something that goes with the design
Thanks
Old 16th Oct 2012, 17:02   #14
Ace_finland
Multimodder
welded and grinded down the mess i did the other day
Got the sheets bent today but now i don't know if i should go with the circular mesh or the hexx mesh. The hexx mesh is made out of 1mm aluminum and the circular mesh is made out of steel sheet which would make the whole construction a lot more stable. What do you think?
Circular or hexx???
Thanks for dropping in!
Old 17th Oct 2012, 00:53   #15
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
I would have gone for the mesh , looks so much better and goes with the geometric designs of the case
KoSoVaR^ is offline   Reply With Quote
Old 17th Oct 2012, 17:08   #16
Sissilisko
Multimodder
Sissilisko has yet to learn the way of the Dremel
Circular. tuo hunajakenno kuvio näyttää vaa nii pieneltä ja liian hennolta, ja sulla on kuitenkin sen verta pyöreitä reunoja ja muuta nii ton iha rei-itetyn pitäis näyttää aika siistiltä siinä.
Sissilisko is offline   Reply With Quote
Old 17th Oct 2012, 17:46   #17
Cookie Monster
I Mod, Therefore I Own
Cookie Monster's Avatar
Cookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpit
I'd go with the circular mesh, the thickness of the material between the holes is larger than the hex mesh which matches the case better. The hex mesh just looks too thin.
Only my opinion though.
__________________
Big Bird - Arc Midi | 790fx-GD70 | 955BE | 8Gb RAM | 2 x HD4890 | 120Gb SSD | 3.5Tb HDD's | 3 x Dell U2412M
Bert & Ernie - 2 x Linksys NMH405 with 2 x 1Tb HDD's
Gonzo - Apple 15" MacBook Pro
Cookie Monster is offline   Reply With Quote
Old 18th Oct 2012, 10:30   #18
Ripitup121
MMMMMMm watercooling....
Ripitup121's Avatar
Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.
WOW. i love the render and work done so far. circular mesh cheesecake i think too and subbed. just epic
Rip
__________________
Asus ROG Maximus V Formula MoBo, Core i5 3570K @ 4.7Ghz, 6GB Corsair Dominator Ram 1600Mhz, SLi GTX460's(1GB), Enermax Revolution 1250W PSU, Xigmatek Elysium Chassis
Dual WaterCooling Loops with 12 Noctua NF-P12's = WOOOOSH!!!
Ripitup121 is offline   Reply With Quote
Old 18th Oct 2012, 11:29   #19
Williz
Supermodder
Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.
Circular mesh! I'm eagerly awaiting more updates
__________________
Silverstone RV-02 White edition / Asus Crosshair V / AMD 1090T Phenom @ 4 GHz
RAM 16Gb G.Skill RipJaws Z 1.5v DDR3 @ 1600 / 2x XFX 6870 Black Editions
1x Crucial M4 64Gb /4 x 1Tb Samsung (Need to check what models)
PSU = Seasonic 760w GOLD rated
Williz is offline   Reply With Quote
Old 18th Oct 2012, 12:27   #20
Ripitup121
Ripitup121's Avatar
Is that Gangnam Style or just Finnish?
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
