Reply
Thread Tools View Mode
Old 31st Oct 2012, 19:15   #41
Evenge
Hypermodder
Evenge's Avatar
Evenge has yet to learn the way of the DremelEvenge has yet to learn the way of the Dremel
Great work! May I ask where did you buy that hex mesh from? I've tried to find some Fin suppliers for it but so far no luck.
__________________
Project: Discovery
Project: Strobe
Main: i5 2500K - 8GB - GTX570 - Win 7
Laptop: Asus U36SD - i5 2430M - 4GB - Win 8 Pro
Evenge is offline   Reply With Quote
Old 1st Nov 2012, 00:51   #42
ZWong
What's a Dremel?
ZWong has yet to learn the way of the Dremel
Sweet! The sketchup looks really great - good luck on the contest.
ZWong is offline   Reply With Quote
Old 1st Nov 2012, 01:59   #43
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is definitely a rep cheat.Mechh69 is definitely a rep cheat.Mechh69 is definitely a rep cheat.Mechh69 is definitely a rep cheat.Mechh69 is definitely a rep cheat.Mechh69 is definitely a rep cheat.Mechh69 is definitely a rep cheat.Mechh69 is definitely a rep cheat.Mechh69 is definitely a rep cheat.Mechh69 is definitely a rep cheat.Mechh69 is definitely a rep cheat.
Nice work so far, looking forward to seeing more. Subbed
__________________
Originally Posted by Deders View Post
What if you touch yourself with kittens?
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is online now   Reply With Quote
Old 1st Nov 2012, 06:03   #44
Ace_finland
Multimodder
Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!Ace_finland - it's over 9000!!!!!!!!1!1!1!!!
I got it from here here , shipping is a bit much but i had a bunch of stuff i needed anyways How much do you need of it? I found a place in Finland you could order some but the minimum size was 2x1m
Thanks!
Ace_finland is offline   Reply With Quote
Old 1st Nov 2012, 14:43   #45
Evenge
Hypermodder
Evenge's Avatar
Well not sure how much but I believe I could find use to it.
I'll PM you later when I find some time to work on my project once again. My workshop is located about 450km away from me so no fun at the moment.
But thanks for the information!
__________________
Project: Discovery
Project: Strobe
Old 5th Nov 2012, 18:08   #46
Ace_finland
Multimodder
Big update coming tomorrow if i get time to take pictures of all the stuff
Sneak preview
stay tuned
Old 5th Nov 2012, 18:31   #47
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
2x Lamptron fan controllers?
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 5th Nov 2012, 19:07   #48
Ace_finland
Multimodder
Oh yes
Old 5th Nov 2012, 20:46   #49
bluc
Supermodder
bluc has yet to learn the way of the Dremel
Nice work and progress I like the use of rivnuts give a nice neat finish
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
bluc is online now   Reply With Quote
Old 5th Nov 2012, 21:03   #50
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.quizz_kid is a hoopy frood who really knows where their towel is.
Very very very nice!!
__________________
Revelation (in progress)
R-KAID-Я (on hold) / The Shrine / REDELUX / 4M / R-kaid-6
http://www.facebook.com/enannanvision
quizz_kid is offline   Reply With Quote
Old 6th Nov 2012, 06:03   #51
Ace_finland
Multimodder
Thanks, its a lot easier than welding, and if you make a mistake just drill it out and redo it
Thanks!
Old 6th Nov 2012, 19:19   #52
Ace_finland
Multimodder
further progress :)
back as promised
Almost forgot to update, have another project that I've been working on for the last 5 months. Can anyone guess what it is? Just got the "table back from a workshop that leveled it for me. So now i just need to get it assembled and it should be good to go if I just can figure out how to use it
Back on topic
Started sanding the edges, tried a lot of different machines and files before getting the result i wanted. Still need to straighten up the edges but wanted to mill the fan controllers first in case i make a mistake and need to redo it.
Milled away a bit of material to get the psu as close as possible to the back of the case to make as much room as possible inside the case
Started disassembling the new lamptron's
Very easy to take apart
In the preview yday you saw the milling so no need to post more pics of that, the controller fitted!
Had to power it up
After looking for leds for the acrylic and realizing buying "computer leds" are way too expensive i started looking for other options. Found this through a company in Finland. I don't know the price but it should be less than 50€ for 5m of leds. These are 15,6W/m so should be plenty of lumens
The Leds can be cut every three leds and cables can be soldered on straight on the copper tabs, 8mm wide and 2,5mm high. The best thing with them is if you have a 2cm led strip or a 5m led strip all you need is 12V.
Also have milled the front acrylic, milled a 3mm gap to place the leds in, a nice tight fit.
From the top
Full 12V, probably need to run them on 8V, otherwise with 2m's of leds it will look like a nuclear power plant
As low as it goes.
Still need to sand the acrylic edges to make it more smooth and spread the light even better, but it's a good start.
Does anyone have a suggestion how to get good photos when photoing the acrylic? They are super red but turns kinda orange in the pictures
Think that's it for now
Old 6th Nov 2012, 19:57   #53
kinghong1970
Just a Clumsy Ape
kinghong1970's Avatar
kinghong1970 has yet to learn the way of the Dremel
back as promised
linear motion bearing blocks and rails... looks like a nema 23 motor mount hole... and oodles of aluminum...
lemme guess.... um... cnc router?
kinghong1970 is offline   Reply With Quote
Old 6th Nov 2012, 22:13   #54
ZWong
What's a Dremel?
Awesome. I love acrylic-lit LEDs. As for photographing them...no, not really. I'm not a big photography buff. Sorry :/
Old 7th Nov 2012, 04:24   #55
Ace_finland
Multimodder
Yeah, its a nema 23 support well spotted!
Old 7th Nov 2012, 05:57   #56
bluc
Supermodder
Steller work love the overall design and the way you did the fan controllers
__________________
Old 7th Nov 2012, 14:16   #57
Ace_finland
Multimodder
Thanks!
Old 19th Nov 2012, 07:20   #58
Ace_finland
Multimodder
Got some great news guys. After some discussions with EK Waterblocks they decided to sponsor me in this build!
Since I started water cooling I have always liked the design of the water blocks that EK provide. So it is truly an honor to work with such a great company!
The parts
Unpacked
This i won over at cooledpc.com but thought i would share it anyways
Pump top to add some performance
EK-DDC X-TOP CSQ - Acetal, such a buty
Waterblock for my Asus Gene-V, EK-MOSFET ASUS M5G
EK-CoolStream RAD XT (240)
A bunch of fittings, some i have bought and some sponsored
EK-RES X3 150
EK-FC5X0 GTX GW Backplate - Black
New build update coming shortly.
Special thanks to Gregor over at EK for helping me out!
Old 20th Nov 2012, 15:31   #59
Ace_finland
Multimodder
Sneak preview of whats to come, will update tonight if i got enough time
Old 20th Nov 2012, 18:43   #60
Ace_finland
Multimodder
Been quite busy the last few days having time off work in order to be able to finish the mod for the competition.
Started with some motherboard raisers, was gonna machine them in aluminum but then i found this nice red Ø20mm plastic bar. Not the right red but they won't be seen after its installed and it's so easy to machine in plastic.
First i machined them to the right diameter
Drill and tap
All done!
Test fitted the pumps and the rads to check for clearance issues
This looks a bit weird, but its in the middle of the case. Had to cut some space for the cables from the psu, this should be enough.
All sanded and ready to get glass blasted
Glass blasted and ready to be powdercoated
It looks a bit uneven but its smudges from me fingering it, i didn't see it but it shows up in the photos, will clean it off before the final shots!
Radiator box, or whatever you would call it
Rear side of the same part
Almost assembled
And some final shots of the case itself, I really like the way it looks and glass blasting the acrylic made a really matte finish which hopefully will hide the single leds and give an even light throughout the acrylic.
Still need to cut slots in some of the acrylic to be able to install all the leds.
Also need to make something to hold the GPU's in place, i know what i want now so I just have to fabricate it.
Stay tuned for more updates
Sponsored by:
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
