#81 |
Supermodder
Coming along great man.
#82 |
Supermodder
I'll high 5 this. Looks fantastic!
#83 |
Multimodder
Red leds look amazing! Great effect with the plexi!
#84 |
Keep calm & mod on. =)
Coolest test bench I've seen, in 2011 this is totally 5 stars.
![]() ![]() In 2012 everything is being trashed it seems yet modding continues to get better. About the stupid ratings, head over here & cast a vote, it's unofficial but people who are bothered about the misuse of the system are trying to make bit-tech take note, some have been turning the rating system to meaningless dribble & it needs dropping. http://forums.bit-tech.net/showthread.php?t=250884 Options are. 1. Get rid of the voting system. 2. It's a useful indicator (but it isn't anymore). 3. Don't care. |
#85 | |
Multimodder
Thanks!
Thank you! Thanks! Quote:
#86 |
Multimodder
New update! Getting close to the end of the Coolermaster competition! Have been very busy the last weekend, spent around 30hrs on the computer on saturday and sunday and had to take today off work just to get it up and running. Taking it to get photographed tomorrow so i can get some proper shots of it for the competition.
Sorry if its not in order the update, a bit stressed due to still having a lot to do before the photo shoot. Anyways, gonna start with the parts. A lot of the parts are from my previous build but there are also new parts Coolermaster test bench Intel 3570K Asus Maximus GENE-V Corsair Dominator Platinum 16GB 1600MHz 128gb OCZ Vertez 2 SSD Corsair AX850 PSU 2 X Gainward GTX570 2 x Lamptron FC5 V2 4 x Schyte Gentle Typhoon A lot of leds Watercooling: 2 x EK-FC5X0 GTX GW Backplate - Black 2 x EK-RES X3 150 2 x EK-DDC X-TOP CSQ - Acetal 2 x EK-CoolStream RAD XT (240) 1 x EK-MOSFET ASUS M5G - Acetal + Nickel 1 x EK Supremacy cpu block 1 x EK Dual parallell sli block 2 x laing ddc pumps A lot of EK fittings Mayhem's Aurora tharsis red ![]() Sleeved the led wires, the cat loves it ![]() Installed in the acrylic ![]() The lamptrons installed ![]() Mounted the rads and the fans to an xspc rad mount, quite a tight fit, a little bit over 1mm to spare ![]() ![]() Plumbing done on loop 1, was a bit more difficult than i first expected. Ignore the blue cables, resleeved them after ![]() Had to check what it looked like with the Hyper212 that i've used during the build. Had to remove all the water cooling so i could get all the sizes right ![]() So many cables, had to cut every cable and shorten them, they would not fit in the case as is. ![]() Tried to get hold of some genuine CoolerMaster sticker but it was a lot harder than i expected. So contacted Coolermaster and got approved to make my own stickers. Was gonna go with normal stickers but due to the case is slightly textured it wouldn't look good so went with these polyurethane based "3D" stickers. Got a few different color combinations made so i could pick the one i liked the most. Big thanks to Mr Glasberg over at staffans.fi for making these priority 1 and making them in more or less a day ![]() ![]() Assembled and more or less ready to go. Still have a lot to do but this will have to do for the competition. Leak test ongoing ![]() ![]() Don't wanna post too many pictures of the bench, gonna wait until tomorrow after the "proper" photos are taken. Next update most likely tomorrow. Sponsored by:
#88 |
Multimodder
Thanks, i've gotten a lot of inspirations from you renderings in the past! Love all of your builds!
__________________
Inverted 600T - OCN Mod of the month July 2012 CM Test Bench V2 - Cooler master mod competition 3rd prize Rig of The month December - Guru3D Nice articles of the test bench: Here and here |
#89 |
Supermodder
Niiiiice!
#90 |
Multimodder
__________________
#91 |
< Your add here >
oh wow the videocard mount matches the memory, that makes the mount even better
#92 | |
Multimodder
just need to figure out how to do it so it looks as standard ram but with acrylic in it
__________________
#93 |
Multimodder
Hey guys, pics will be up tomorrow from the photo shoot, until then a teaser
![]() ![]() and yes, i know i need to bleed the system again ![]() Sponsored by:
#94 |
Fenrir The Wolf
Looks great. I can't wait for more pictures.
Pet the cat for me.
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
#95 |
Multimodder
#96 |
Supermodder
I keep forgetting how small this build actually is.
Can't wait to see your final photos! |
#97 | |
Multimodder
they will be up tomorrow!
__________________
#98 |
Professional Sleever & Modder
The teaser looks great
, some bleeding wouldt be a bad idea ;D
#99 |
Sweet sweet sweetness
#100 |
< Your add here >
Good stuff Ace
| Thread Tools | |
| View Mode | |
