#121 |
Supermodder
That is just amazing Ace!! Lovely Idea maybe U should contact Corsair and sit around the table with this great idea.
__________________
Completed Projects: Cooler Master Silencio 550 Limited Edidtion Project White, Black Obsession, Project Umbrella |
#122 |
Professional Sleever & Modder
Oh my god, thats lovely!
Can you show a picture with the red one, Please! |
#123 | ||
Multimodder
but the principle is the same if u use a co2 laser or different grit sandpaper So i will do some tests and hopefully i will get it sorted out.Quote:
![]() I will experiment ta bit more cause the light is not spreading more than in the picture without the light bar.
__________________
Inverted 600T - OCN Mod of the month July 2012 CM Test Bench V2 - Cooler master mod competition 3rd prize Rig of The month December - Guru3D Nice articles of the test bench: Here and here |
#124 |
Multimodder
Looks amazing, really nice work
#126 |
MMMMMMm watercooling....
Grats on winning the CM Case mods comp Ace (scratch mods) Super build and well deserved.
Rip
__________________
Asus ROG Maximus V Formula MoBo, Core i5 3570K @ 4.7Ghz, 6GB Corsair Dominator Ram 1600Mhz, SLi GTX460's(1GB), Enermax Revolution 1250W PSU, Xigmatek Elysium Chassis
Dual WaterCooling Loops with 12 Noctua NF-P12's = WOOOOSH!!! ![]() |
#127 | |
Multimodder
Thanks!
Thanks! btw, you will have a pm soon ![]() Quote:
![]() Thanks to all that has been following me this year and a happy new year to you all! Next post will be next year
__________________
#128 |
Minimodder
This is certainly one of the best test bench's I've seen! Well done!!!
#129 |
↓ Don't trust that face!
Those ram covers are delicious.
-NEEEEEED a picture with them with the whole case in the shot.
__________________
#131 |
dat steak
I like the fact Corsair feel the need to call and allen key 'an instillation tool'..
#133 |
dat steak
Since when did Corsair think they could compete with Marks and Sparks.. pff.
#134 |
Multimodder
Hey guys!
Back now, been very busy with work and a lot of other stuff. Have been trying my best to get the ram working but after corsairs "release" on monday i decided to shelf my idea. I tried making grooves and so on in the acrylic and i got the light to spread decently as far as the new corsair kits are covered. Maybe they had the same problem Anyways, I will move on to some other mods i want to try out instead. Updates to come as soon as i make some progress ![]() Oh, also got the Rig Of The Year over at guru 3D!
__________________
#135 |
The modding head is firmly back on.
I missed most of this build. It looks fantastic, it's got a really mechanical look about. I love the lighting affects as well.
Top modding dude |
#137 |
Multimodder
I really like how the plexi is designed in it and the mobo tray back OMG that is just beautiful. Great job.
#138 | |
Multimodder
Thanks! Thanks!
__________________
#139 |
Multimodder
Hey guys! Seems like it was forever since i was last on, been so busy with work and life in general i have not had much time for modding. I did make a bunch of different backplates which i will hopefully post a pic of tonight.
But for now i need your help. Sadly the coolant i used didn't work out so had to swap it to some normal cooling. This is when evrything went south and i have no idea anymore what's wrong. Hopefully some of you might have an idea. The problem is GPU #2 keeps rising until the computer shuts down. The loop order is res-pump-rad-parallell gpu's - res. The rad is an ek xt240 On idle both sits around 5c over ambient, max on gpu is 57c, when i stop stress testing they bouth drop to 5 over ambient in a matter of min. If i swap the gpu's around it's the other one that overheats. What i have tried: - Cleaning out the blocks and reseated the blocks. - Checked the pump for flow and pressure - Flushed the whole system - swapepd around gpu's --> the other one overheats - checked that there are water in both gpu's - have bled the computers for hrs in evry possible position while running, def not air in the system. The only thing i can think of is for some reason there is not enough flow through the 2nd gpu block. Anyone have any ideas? I was thinking of getting a series block just to rule out the parallell block. Ace
__________________
#140 |
Multimodder
The problem might be the parallel block. i would change that first and see from there. serial makes sure that the liquid has to circulate trough both blocks.
Good luck.
__________________
Completed : Bulky |
| Thread Tools | |
| View Mode | |
