Reply
Thread Tools View Mode
Old 12th Oct 2012, 22:10   #1
wejjy
Hypermodder
wejjy's Avatar
wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.
Project: "BitPac" - Watercooled Bitfenix Prodigy Build - Completed!!
Hi again guys, well some of you will be aware that my SR-2 desk build is nearing completion, so the next build begins...
Its an illness I think, we just can't help ourselves can we!
So, the project, well yes it is another Bitfenix Prodigy build, but hopefully something a little different to the others. I want to integrate overkill with the tiny size of the case, so Im going big with this one. No designs to spoil it, they're all stored safely on my drive so I can refer to them, Im afraid you guys will just have to follow along until the end. The only teaser will be these photos at the very start!
So I have the majority of the hardware already, all of the water-cooling gear is now in my possession, so tonight I made a start stripping the case down and trying to figure out which parts to keep and which to mod, and then which to get rid of all together!
Heres the strip down so far as Im sure you have all seen the case in its fully built state...
First of all stripped all the drive bays out including the DVD tray, all so easy to do, a credit to Bitfenix...
The stripped case, with the PSU installed in the bottom...
Then finally the rads, in the rough position they will occupy, they're balanced at the moment so please don't worry, they will be straight when finished, just to give you all an idea as to how tight the case will be filled!
Hardware:
* Z77 Motherboard - TBC
* GPU - TBC
* Corsair 16gb Dominator RAM
* 256gb OCZ SSD
* 2x 2TB Samsung Spinpoint HDD's
* Corsair GS650 PSU
Watercooling:
* 2 x Phobya G-Changer Rads
* EK GPU Full Cover
* EK HF Supreme CPU Nickel/Plexi
* EK Dominator Nickel/Plexi
* Laing DDC 18w Pump with EK Top
* EK Fittings
* Fans - Bitfenix 120/140 Fans Colour co-ordinated!
OS - Windows 7 and OSX Mountain Lion
Hope you all like this one guys, it WILL be different!! I promise!
__________________
Project in progress: Bitfenix Prodigy Stacker
Interior Des(k)ign | BitPac | Bitfenix Prodigy Stacker
Modding is addictive!!
wejjy is offline   Reply With Quote
Old 13th Oct 2012, 17:32   #2
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
Looking forward to it
KoSoVaR^ is offline   Reply With Quote
Old 13th Oct 2012, 19:56   #3
ziza
Multimodder
ziza's Avatar
ziza has yet to learn the way of the Dremel
X2
__________________
Per me si va nella cittą dolente,
per me si va nell'eterno dolore,
per me si va tra la perduta gente
ziza is offline   Reply With Quote
Old 15th Oct 2012, 08:44   #4
wejjy
Hypermodder
wejjy's Avatar
Thanks guys! Work is progressing, updates soon I promise!
__________________
Old 20th Oct 2012, 06:53   #5
LeandroJVarini
Mod is my life!
LeandroJVarini's Avatar
LeandroJVarini has yet to learn the way of the Dremel
will be a beautiful work!
I'm almost buying a prodigy for me to try to put a m-atx it, maybe later on!
__________________
SORRY FOR MY BAD ENGLISH!
LeandroJVarini is offline   Reply With Quote
Old 22nd Oct 2012, 10:10   #6
wejjy
Hypermodder
wejjy's Avatar
Ok so progress was delayed until some parts arrived, I received mynorder though last week from Specialtech, so yesterday I started moving forward. i'll put the pictures on and allow them to do the explaining as words are just boring!
Love these fans, they are so easy to work with and are great for watercooling builds imo
Out comes the paint...
3 coats later...
Left these to dry, and went back home, installed the motherboard power cables to see how they look.
Not bad!
Then did some work on the rads, CF'd the sides, and attached the fan bodies in place ready for the painted fans tomorrow.
Then installed the standard black Bitfenix fans as exhaust fans for the rads, may change these but will see how they cope first.
Dropped the rads in to see how close it all was, and hey presto, its perfect!
Enough space but nice and full too!
Thats all for now folks, onto the top plate next and the pump/res placement which I am excited about, then saving for the GPU!
Whadya think?
__________________
Old 24th Oct 2012, 06:28   #7
Phame
CNC mad!
Phame's Avatar
Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!
Looking good duuuude! - Loving your Desk, hope this turns out just as well!
__________________
'You had my curiosity, now you have my attention'
Work in the pipeline *Server* and *Intel NUC*
Completed Projects. *Orange and Black* and *The Wet Pi* Winner of Raspberry Pi case competition
Phame is offline   Reply With Quote
Old 25th Oct 2012, 17:48   #8
wejjy
Hypermodder
wejjy's Avatar
Thanks dude, and for following the desk too!
__________________
Old 25th Oct 2012, 23:49   #9
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Now for something completely different project nice one.
Waynio is offline   Reply With Quote
Old 26th Oct 2012, 19:08   #10
wejjy
Hypermodder
wejjy's Avatar
I know, its totally the opposite to the desk, and its a little strange as everything seems so easy in comparison, almost like Im cheating!
__________________
Old 26th Oct 2012, 19:14   #11
wejjy
Hypermodder
wejjy's Avatar
Ok so a tiny little bit of progress today. I managed to collect the fans I left drying last time and fit them. A little teaser really for you all as Im still yet to make the actual brackets and the reservoir/pump mounts.
Also I could do with some help in deciding which motherboard to go for, the Asrock Z77 or the Asus Z77?? The Asrock fits in nicely with my colour scheme, but the Asus has much higher features?? Help??
Anyway, here are the piccies again, hope you like them...
Gotta love the Phobya fans...
and the zesty Orange...
Spraying this was kind of a test as there will be a lot happening up in the roof... But I like the effect it gives as the mesh changes how orange it all looks.
And finally an overall shot for you, gives you an idea of how it will all look in the end!
Thanks guys, if anyone would like to donate a 670, it would be amazing too!
__________________
Old 28th Oct 2012, 08:55   #12
wejjy
Hypermodder
wejjy's Avatar
Ordered the Asrock board last night, along with a Samsung 256gb SSD (colour scheme is perfect!!) and some RAM, just need a modular PSU and some help deciding which GPU to go for... 660ti or 670gtx??
__________________
Old 28th Oct 2012, 12:03   #13
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Love the way you placed the rads! Where is the pump/res going?
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 28th Oct 2012, 12:53   #14
Cookie Monster
I Mod, Therefore I Own
Cookie Monster's Avatar
Cookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpitCookie Monster is almost as Godly as yodasarmpit
What sexy little cases these are, shame one wouldn't fit in my tower holder thing and that I've not long bought a Fractal Arc Midi.
I watch with interest.
__________________
Big Bird - Arc Midi | 790fx-GD70 | 955BE | 8Gb RAM | 2 x HD4890 | 120Gb SSD | 3.5Tb HDD's | 3 x Dell U2412M
Bert & Ernie - 2 x Linksys NMH405 with 2 x 1Tb HDD's
Gonzo - Apple 15" MacBook Pro
Cookie Monster is offline   Reply With Quote
Old 29th Oct 2012, 19:24   #15
wejjy
Hypermodder
wejjy's Avatar
Thanks dude, I like to be different, and to make things as hard as possible for myself too!
The pump is a Laing DDC type and the res is an EK 150 tube type res, they will both be positioned in the roof, on display but integral to the case, riddle like I know, you will see as Im working on it as we speak!! Soon...
They are great little cases yes, although I feel bad as Ive absolutely gutted this one! Shame you can't fit it into your space, but the Arc Midi is nice too (had one for a while!)
Thanks for looking in!
__________________
Old 14th Nov 2012, 19:37   #16
wejjy
Hypermodder
wejjy's Avatar
Havent really been on much lately, but got a bits done in really small doses so thought I would save it all until I had some work worthy of posting, and Im really chuffed, got afew small things left to do but I feel Ive done a half decent job so far!
I had a few deliveries, namely the below!!
So there was a lot to get on with really....
I started off by laying everything out to double check it was all ok, and then started assembling bits in their final positions.
I will just post the photos from now on, as its all fairly simple...
Hated the stickers on the side of the PSU but that got sorted another time...
CPU installed, cant wait to overclock this little beauty!
HOW TO ALERT: Skip if you want!!
Decided to do a little how to with my cleaning kit... Might help someone?
First step is to wipe off all old residue with some Kitchen towel etc...
Leaves a smeared dirty mark...
So you apply the Arctic Silver Fluid number 1 and wipe again...
This cleans it but leaves behind an oily film, so you MUST use the second fluid too...
Just a drop...
Wipe...
Then...
Perfect!!!
HOW TO OVER......
Installed the Samsung SSD and piggy backed it using velcro strip to the old Corsair SSD I had, so I have a Samsung 256GB and a Corsair 128GB SSD, one for Windows, other for Mac OSX.
Piggy backed
Then into their new home, as I said the PSU got Dinoc'd, much better now
By this time I'd started messing about with the hose routing, so had to fix the pump down on its little rubber dampers...
Its on the floor at the very front between the two rads, its snug in here to say the very least!
Then it was onto the Reservoir placement, now I didnt take many photos of this as I kind of just got into the zone so apologies!! Some will love others will hate, Im definitely the Former!! and before the haters say anything, yes it would fit inside, I want it to be a feature...
Getting there...
Installed the LED strip and put it inn the roof, am chuffed with it, great light and good effect, just cant wait to see it with the fluid!
Unwrapped the final piece of the jigsaw, but gutted as the EK block was delayed so I couldn't get it all finished off, otherwise it would be leak testing right now, ready for playtime tomorrow!! DOH!
and the glory shot...
Just got the block to fit and then its all ready to juice up and get playing!!! More very soon!!!
Oh I forgot one thing, these cases are tiny, so storage can be an issue, overcame that with a mad idea, needs a cover but... enough room eventually for 3TB's to be hidden in there, guess where...
Haha cheeky ay!!
Hope you like guys, catch you very soon!!
__________________
Old 14th Nov 2012, 20:30   #17
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Canardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the Dremel
Originally Posted by wejjy View Post
Nice ideas: 2 x 240 face to face, rez on top and hdd under the case.
I don't know if you already plan it, but you should do a shield (enclosure) to protect you hdd.
Anyway, congrats, and i very love the Prodigy
Do you know if it possible (with modding) to install an ATX or an E-ATX motherboard? What are the dimensions of the motherboard tray? Thanks
Sub!
Canardwc is offline   Reply With Quote
Old 14th Nov 2012, 21:11   #18
Waynio
Waynio's Avatar
Doing great with this wejjy, like the alternative HDD mount.
Old 15th Nov 2012, 09:34   #19
wejjy
Hypermodder
wejjy's Avatar
Sub!
Hi Canard, thanks for looking, yes I will be making an enclosure for the HDD soon and painting it to match the exterior of the case so that its hidden and safe. I love the case, but I have destroyed most of it to take the overkill cooling that I like to install!
As for the other mobo's I think you could with a little work yes, but only in the rear as standard cases do, not horizontally as there is not enough space. Anything is possible though in the world of modding!!
Thanks pal, Im trying to keep up with your work, you are too fast! I look like a snail next to you, every time I check your thread there are another 4 pages to look at! Appreciate you checkin in here though, and glad you like the HDD mod, it hard to be original sometimes here, its all been done!!
__________________
Old 20th Nov 2012, 14:15   #20
wejjy
Hypermodder
wejjy's Avatar
Almost finished! Received the water-block and set to work getting it all up and running. Had a few minor issues but nothing too major! Mostly cable routing which Im still working on.. What do you all think?? Small but mighty powerful and runs really quiet and cool!
Reference 670 cheesecake!!
Its a bit of a squeeze in there now...
Then onto the fluid, I didn't take photos of leak testing as it is all a tad boring and has been done over and over so the result instead!
Just got the windows to cut in the side panel, and the front panel to sort and we are go!!!
Did get chance to install Civ5 just to test it all works nicely, but only on the TV sorry...
Let me know your thoughts!?!
Thanks...
__________________
Reply
Tags
bitfenix, itx, prodigy
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
