Scratch Build – Complete The Red One by C4B12 | 11-08-17 (completed)
Discussion in 'Project Logs' started by C4B12, 13 Oct 2012.
  1. C4B12
    C4B12 Minimalistic PC's
    6 Oct 2011
    Hello again.
    Im pretty new to Bit-tech but I have some builds already done that I wanna show. This one is the first real scratch build I ever did. It was a project at school. The idea came from someone on a swedish forum that made the same thing, but not so nice. So I wanted to make it look good and a little bit more serious.
    The hardware I used in this build is not something to brag about but I think the actual case is the most important. In the pictures you will see all kind of hardware but it ended up with this:
    Asus M2N68-AM PLUS
    AMD Athlon2 X2 245 @ 3150MHz
    4gb Corsair DDR2
    Corsair 400W
    PowerColor Radeon HD4650 SCS3 512MB @ 750/550
    This red thing, dont know what its called in english, in swedish its "drickaback". But its a "case" for bottles. Ive always loved Coca-Cola so when I found this "drickaback" on my work I bought it for ~2$.
    First thing was to cut out bigger holes on the sides for 2 Revoltec 120mm fans.
    Next thing was to cut out some of the plastic inside it to fit a matx motherboard and the psu.
    The hole in the front I put a acrylic plate.
    Then I took a motherboard plate from an old chassi and two hinges and put it in place.
    The bottom looks like this. And cant have it like that!
    So I put a plate with some feets on it.
    For the top I also used acrylic and hinges. This tinted acrylic looks really good I think.
    Needed some red cathodes too.
    One thing that Im really proud over with this build is the power button. Took some old switch and put here.
    And then glued this Coca-Cola cap on it.
    This was the first time I ever sleeved something, so its not that good.
    This is a little overview picture of some of the hardware I used.
    Final pictures:
    So this is my Coca-Cola case aka The Red One. My first real serios build ever and this is what made me love computer modding and so on.
    Hope you liked it, comment what you think.
    /Johan Nyman
  2. AbKaRy
    AbKaRy What's a Dremel?
    1 Sep 2012
    Nice idea :)
  3. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Brilliant idea and superbly executed I love it
  4. C4B12
    6 Oct 2011
    Thanks! Wish I was sponsored by Coca-Cola though ;)
    Thank you! :)
  5. Cheapskate
    13 May 2007
    Nice fit and finish work for a traditional student furniture building block. :lol:
    The last time I saw one of these used for a case it was filled with expanding foam.
  6. bulldogjeff
    2 Mar 2010
    That is really different and very cool..Nice modding
  7. Pranja
    Pranja Blackwolf
    18 Dec 2011
  8. ali_robb2000
    ali_robb2000 What's a Dremel?
    17 Feb 2003
    Nice build, I like the power button! And how you've repurposed something old like that crate
  9. C4B12
    6 Oct 2011
    Haha yeah probably. You should see the teachers faces when I told them what I was gonna do for my project in high school. "Im gonna build a computer in a box for coke bottles" :D
    Thank you bulldogjeff! :)
    Oh havent seen that one. Nice though. :)
    Thanks man! :)
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D Cool, nicely done mate. :dremel:
  11. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Great idea and build! :)
  12. C4B12
    6 Oct 2011
    Thank you Waynio and Bladesingerz! :dremel::D
  13. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Nice job Johan! ...... btw, I noticed your MkII VW GTI on facebook...very nice :thumb:
  14. N!ck
    N!ck ModMag.Net
    24 Sep 2008
    Great build, awesome to use as a LAN-Party rig:rock:! Featured your project on my web site.
  15. Mr.Evil
    Mr.Evil What's a Dremel?
    7 Feb 2012
    great idea, it's very cool !
  16. C4B12
    6 Oct 2011
    Thanks you Bill! VW is the only way ;) Saw your Jetta on instagram too, loved it!
    Thanks man! :)
    Thank you!
