#1 |
Modder
Folding problem
Hi. Needing some advice on what to do, im having problems folding on my new rig. My graphics card isn't doing anything....iv got the chip running a smp ( only seem to be getting a projected 4378 ppd tho ) , but iv no idea what to do to get the graphics card folding ? any help would be much apprachated.
__________________
i7 3820 @ 4.875ghz / Sabertooth X79 / MSi Twin frozer3 680gtx oc / Corsair 32gb quad kit / 128gb m4 ssd + 2tb hdd / Xonar dx / Ocz zx 1250w / H100 / Slightly modded Corsair 700D / 7 Pro |
#2 |
Thinking about which mod to do 1st.
which client software are you using?
__________________
#3 |
Modder
In systems info tab, it says its 7.1.52 build.
__________________
#4 |
Another CPC refugee .....
Have a quick search of the threads on this forum, as you need to do a couple of extra things if you're running a Kepler card (and a number of people have posted threads on what to do) ....
#5 |
Modder
Thanks doc..... i followed instructions, downloaded the gpu file and put it in the data directory...nothing. Some also tryed the "client type:beta" command...not sure if iv put that in the right place - config - slots....click on the gpu -edit, then iv put it down at the bottom in the " extra slot options " bit.....is this right ? cause its not changed, says its workin, but doing nothin gggrrrr. I even downloaded FahCore_15.exe version 2.24, i had seen this mentioned on forums, and i was running 2.22, so i replaced that, still no joy :'( Starting to wish i had just kept the 580, that worked at least
![]() Then the magic faries came along and fixed it while i was making a coffee and re-starting my pc lmao Thank you for all the replys
__________________
i7 3820 @ 4.875ghz / Sabertooth X79 / MSi Twin frozer3 680gtx oc / Corsair 32gb quad kit / 128gb m4 ssd + 2tb hdd / Xonar dx / Ocz zx 1250w / H100 / Slightly modded Corsair 700D / 7 Pro Last edited by Jay88018; 15th Oct 2012 at 11:52. Reason: Pc fixed itself while i wasn't looking ;) |
#6 |
Magic faires are a rarity - make the most of them
#7 |
What's a Dremel?
@ DocJonz Heheh -
@ OP you did use the file titled GPUs.txt yes? the little 's' is critical as I discovered when GPU didn't work. Ref your CPU, that's a tad low - I assume you've applied for a passkey to allow you to claim the bonus points for finishing work units early?
__________________
Hanging from a cliff by one hand while looking at the scenery below does wonders for work related stress.... |
#8 |
Modder
Yeah P, i think the problem was more me...i was closing the fah program window, but it was still running, soon as i did a proper restart, it worked...my bad
Yeah i did, think it was a wu that i had lost any chance of bonus points at since it had taken me so long with my problems and mucking around, once i had finished that wu, the ppd went up....woops. Got it set smp 6 the now, the gpu as well, seems to be getting between 38k to 43k ppd average, but im just glad its working again.
__________________
#9 | |
__________________
#10 |
Modder
Sorry for the late reply, been addicted to BF3 recently. I tried to pause half of the foldin, but it paused it all, not sure how to do it without muckin about with the setting again...and i dont really wanna do that lol i took a couple of pics so you can see the info i can see, please tell me anyway to show you any other info you need, hope these pics help tho.
![]() ![]() http://photobucket.com/jaysfoldingpics
__________________
i7 3820 @ 4.875ghz / Sabertooth X79 / MSi Twin frozer3 680gtx oc / Corsair 32gb quad kit / 128gb m4 ssd + 2tb hdd / Xonar dx / Ocz zx 1250w / H100 / Slightly modded Corsair 700D / 7 Pro Last edited by Jay88018; 22nd Oct 2012 at 09:38. Reason: Dont think the pics upload worked, so adding the link to go see the pics on the website. sorry |
| Thread Tools | |
