Reply
Thread Tools View Mode
Old 14th Oct 2012, 20:20   #1
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysis
The Shrine (update 24/3 COMPLETED! photos and video)
Time for a new project!
"The Shrine" is a HTPC in solid walnut. The concept for this build is nature and technology in symbiosis.
For coolant I´ll be using something amber like. This to resemble resin, binding machine and nature together. Colors I´ll be using are Walnut, black and copper.
The build is designed around an acrylic dome which I found a couple of weeks ago
It will be built in two levels:
*A top "display", with water cooled CPU and MB encapsulated by the dome.
*A base, "the trunk", where other components will be sharing airflow
Sketch
I will also have an Arduino based LED system on top, with 30 diodes in orange,
breathing sort of randomly. Well, let´s just hope for the best
Specs:
CPU: ?
MB: ASRock H77M-ITX
Psu: my oldCorsair CX 430W
GPU: my old GTX 460
RAM: Corsair Donimator 2x4GB
SSD: Corsair Neutron GTX 240GB
Water cooling for CPU:
Block: Alphacool NexXxoS XP³ Light - Acetal Edition - Intel/AMD
Rad: Alphacool NexXxoS ST30 Full Copper 120mm
Fan: 1x Phobya G-Silent 12 1200rpm Black Silent Edition
Res & Pump: Phobya DC-220 & Alphacool Cape Corp AGB2
Fittings: Alphacool 16/10 G1/4 - shiny copper
Dome, aprox 320mm in diam
I will try to finish my REDELUX build next week. Until then...
Hope you´ll enjoy this / Quizz
Sponsors:
__________________
R-KAID-Я (in progress)
The Shrine / REDELUX / 4M / R-kaid-6 / Sputnik 0667
quizz_kid is offline   Reply With Quote
Old 14th Oct 2012, 20:21   #2
quizz_kid
Squid
quizz_kid's Avatar
Woodwork:
Bought myself a fine piece of walnut lumber
Cut and planed pieces
24 pieces and some 7,5° cutting. Then I made 2 rounded groves along each piece, for decoration.
BRIO railway in walnut anyone???... Or just a 24 sided cylinder.
Some components for you guys:
ASRock H77M-ITX
Picked this board because of layout and color.
My old 460 will be placed under the mobo with a flexible riser.
Three 40mm fans for intake.
PSU was too big, so I took it apart.
Much better!
Components for the Arduino module.
Thank you Andreas on Aquatuning.se for the cooling system from Alphacool and Phobya!
And thank you Gareth at Corsair, for the RAMs and SSD!
__________________
Old 14th Oct 2012, 20:24   #3
Phame
CNC mad!
Phame's Avatar
Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!
This is a nice idea, good luck on it dude!
__________________
'You had my curiosity, now you have my attention'
Work in the pipeline *Server*
Completed Projects. *Orange and Black* and *The Wet Pi*
Phame is offline   Reply With Quote
Old 14th Oct 2012, 21:48   #4
C4B12
Scratchbuilder
C4B12's Avatar
C4B12 has yet to learn the way of the DremelC4B12 has yet to learn the way of the Dremel
Always nice to see your scratch builds. Love it. Looking forward to this.
__________________
Scratch builds | Cold Winter | CURV3D | The Red One |
Casemods | BarPC |
Check out my facebook-page where I post everything about my mods. Like/share if you want to.
C4B12 is offline   Reply With Quote
Old 15th Oct 2012, 14:21   #5
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Another quizz project, & now sponsored awesome.
Waynio is offline   Reply With Quote
Old 15th Oct 2012, 14:42   #6
quizz_kid
Squid
quizz_kid's Avatar
Thanks!
Thank you... and nice to see you here mate!
Yep... Should probably change signature to "pro" now... or "owned" maybe
__________________
Old 17th Oct 2012, 21:53   #7
quizz_kid
Squid
quizz_kid's Avatar
Work from today:
Started by milling the intake on the front. This is the only decorative element on the main walnut cylinder. Going to keep it sparse and simple here, to keep the spotlights on the dome.
I placed sacrificial pieces in there before I cross cut in the milling machine, to not lose material.
After milling.
I like it! Like a abstract tree or something. Goes well with the concept I think.
Backlit.
Took away some material for the three 40mm fans. Not the best intake, but it´ll help a little.
I will have a hatch in the back to facilitate assembly. Here I´m using a 7,5° gigg for some hinge milling.
Black hinges.
Kind of discrete I think.
The backside.
Milled a hole for the radiator on the hatch, 10x10cm.
Almost ready for glue now.
Found some 5mm magnets for the hatch aswell.
Drilled holes for them.
Later! / Quizz
__________________
Old 17th Oct 2012, 22:22   #8
Waynio
Waynio's Avatar
That sacrificial method is handy to know about nice to see some more workshop stuff in your logs, was never all that sure of what methods or tools you use for all steps really but it's always been clear you are awesome at this.
Sweet progress.
Old 17th Oct 2012, 23:59   #9
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Bro, your work is sooooooo good, talented thats for sure!!! Cant wait to see how this is going to look like at the end!!!
AnG3L is offline   Reply With Quote
Old 18th Oct 2012, 03:52   #10
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen
Furball Zen is online now   Reply With Quote
Old 18th Oct 2012, 20:30   #11
quizz_kid
Squid
quizz_kid's Avatar
Sweet progress.
Thanks Waynio. I know I´ve been sparse with workshop pictures before. This is my new workshop btw The zink machine I´m working on there is a KILLER!! You can do anything with it...
Thanks AnG3L! Much appreciated...
Originally Posted by Furball Zen View Post
Some work:
Put the pieces in order
Used masking tape to keep them together
Glued under pressure. Note that I didn´t glue the pieces with red crosses. That´s the hatch.
After a couple of hours I removed the pressure. The cylinder is pretty fragile as it is, only 13mm thick. But I will make it more stable later and lock the cylinder with bottom and roof.
I milled inside the hatch and made a plateau for the 120mm radiator.
The zink machine is a pleasure to work with... My new favourite toy!
This is how it´ll look like...
I´m not going to use skrews from the outside so I drilled holes right through the rad.
Later!!
__________________
Old 20th Oct 2012, 08:47   #12
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
Awesome work quizz. Much to learn from your project logs. The sacrificial wood for the milling is good to know, I always wonder why the ends break when I'm using the router. And the geometric constructions are always so well done. I watch.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 20th Oct 2012, 13:46   #13
quizz_kid
Squid
quizz_kid's Avatar
Thank you Attila. Yeah, I learned about using sacrifical pieces just a month ago, feel kinda new born
__________________
Old 20th Oct 2012, 14:12   #14
KrunchR
Supermodder
KrunchR's Avatar
KrunchR has yet to learn the way of the Dremel
Great work quizz.
KrunchR is offline   Reply With Quote
Old 20th Oct 2012, 14:30   #15
Waynio
Waynio's Avatar
Oooooh, real nice work quizz.
Watching what you do is really going to give me drive to try a woody project.
Old 20th Oct 2012, 16:12   #16
Furball Zen
Shut up and Mod
Quizz, youre giving Waynio a woody!!
__________________
@furballzen
Old 20th Oct 2012, 18:00   #17
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Oh, this is going to be good.
A delicious block of walnut like that is hard to come by here. Even the pine available here right now was from stuff that died during the drought. It's all cracked and crappy.
I'm going to assume you drilled between the tubes.
Cheapskate is offline   Reply With Quote
Old 21st Oct 2012, 19:51   #18
quizz_kid
Squid
quizz_kid's Avatar
Originally Posted by KrunchR View Post
Great work quizz.
Thanks!
Yeah, you def should try it... It´s like working with butter compared to metal work
We´ve got some really good local lumber up here, it´s a blessing
And yeah, I tried to avoid the tubes while drilling.
Just a small update today. I wanted a delicate small start button in black and copper, but even searching through ebay did me no good. Hard to come by things in copper I guess. Well, I gave up and made one myself.
Bought this 13mm push button in nickel
Had to drill some holes in the back to seperate button from nickel housing.
Seperated...
Painted the nickel in copper. Also cut and painted som mesh for the intake.
Button glued back with epoxy. That´s it!
__________________
Old 23rd Oct 2012, 21:41   #19
quizz_kid
Squid
quizz_kid's Avatar
More work...
Made a bottom piece in 16mm MDF and milled two groves for supporting walls inside the chassis.
Cut the two walls from an 10mm shelf I had laying around.
Test mounted stripped GPU, PSU and SSD
Airflow will pass between the walls and through the chassis.
Cut and veneered the plate for the mobo. 4mm MDF with walnut.
The plate/display will be attached to the two supporting walls with screws on top. And here´s the h77m on top of it.
Walnut and black... I think this will look really good
__________________
Old 24th Oct 2012, 00:17   #20
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
Looks sweet! Nice work preventing tear out with the sacrificial pieces when doing the vents. What do you use for milling that? Is it a metal mill, or one specific for wood?
I don't know how I missed all this... But glad I found it :-)
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
