#21 |
Keep calm & mod on. =)
Hardware mounting looks interesting, nice progress quizz.
#22 | |
Squid
Thank you mate =) |
#23 |
Multimodder
fabulous work so far! I like the color/material scheme as well.
I'm not sure about the stand - I'll have to wait and see what you had in mind. (an idea: Google "twisted trunk" --> maybe something along those lines - with a mix of copper wire/tubing, black wire, and walnut wood...) |
#24 | |
Squid
#26 | |
Squid
Well thank you, Jipa!! |
#27 |
Squid
I thought Iīd try the lazzzer today...
![]() I wanted to try modding the GPU a bit, so I made two new acrylic fan mountings, replacing that big ugly black plastic... Also cut some I/O extensions from 4mm MDF while I was at it. ![]() GPU before ![]() ![]() GPU after ![]() ![]() From above... ![]() I like it, the clear arcylic pieces are almost invisible when the fans are running. I might do something about those stickers though. ![]() Cut some holes in the bottom piece for the I/O mountings. ![]() And placed them with precision. ![]() Hereīs the placement of the pump and res ![]() Iīm going to add some material under the res later. ![]() Also made some taps for connecting the cylinder with top and bottom. ![]() Glued in place... ![]() Taaada! Laterz!! / Quizz ![]() ![]()
#28 |
I couldn't wait a week to check out some updates, sweet progress quizz.
#29 |
Scratchbuilder
Starting to look really really good!
__________________
Scratch builds | Cold Winter | CURV3D | The Red One | Casemods | BarPC | Check out my facebook-page where I post everything about my mods. Like/share if you want to.
#30 |
Multimodder
The quality and detail of your work is amazing - I'm looking forward to following this! Keep it coming...
#31 | ||
Squid
Thanx friend! Quote:
Update time!!! Made some progress with the dome today... ![]() Started off drawing some on a sheet of 6mm ply. ![]() Cut the hole for the dome. Made a small mistake with the router, but fixed it with this little piece... ![]() Drilled some holes and sanded the outer diam. ![]() Placed the dome inside... Perfect fit Drilled three holes in the acrylic and attached M4 skrews to secure it to the ply.![]() As you can see the acrylic had to be sanded ![]() Used the vertical sander. ![]() Better! ![]() Fitted on top of the shell. The ply will be painted black later. ![]() Another angle. ![]() Used the ply to pin the holes into the taps ![]() Drilled... ![]() Used the ply as mallet for the bottom aswell. ![]() ... and drilled some more. ![]() Also put the cover in place and drilled some holes to connect it with the walls underneath. ![]() Under the cover plate. Laterzzzz / Quizz
#32 |
Scratchbuilder
I want to see mooooore!
__________________
#33 |
Multimodder
yes, keep it coming. This is easily one of my favorite projects right now...
#35 |
Hypermodder
looking great
I have to ask, is that your shop? Or a workplace shop? Looks so nice! Edited for typo
__________________
Mosquito Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC Last edited by Mosquito; 10th Nov 2012 at 16:32. Reason: typo ... our should have been your |
#36 | |
Squid
Thanks Mosquito! ... Forgive me, but I donīt understand the question. Our shop? |
#37 |
Hypermodder
Dang it, typo... your* shop (home/personal shop)
__________________
Mosquito Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC |
#38 |
Squid
Oh... Thatīs the shop of my school, not a personal one Iīm afraid. One day maybe
#39 |
Never thought domesday would look so nice.
![]() ![]() Excellent stuff quizz. ![]()
#40 |
Multimodder
Don't ask why, but it reminds me of Discworld, from Terry Pratchett! LoL
Great job! I think that you would have to low your camera's ISO/gain! It will improve that grey grain!
| Thread Tools | |
| View Mode | |
