#41 | ||
Squid
![]() Quote:
![]() ![]() I donīt know why, but Iīll just take that as a compliment. About the pictures, I have a really old compact camera and itīs full of sh*t... The grain comes from bad resolution and a lot of sharpening in PS. But I actually like to keep the WIP-photos bad... The final shots will make a really good impression that way
#42 |
Squid
Small update:
![]() Glued the I/O panels in the bottom and used a filler for the gaps. ![]() Milled a hole in the plateau for I/O cables ![]() Two 16mm holes for the hoses... ![]() And this is for hiding those ugly chromy I/O sockets on the mb. Some pieces of 7mm walnut. ![]() Cut and glued them together in an angle. ![]() Sanded another angle from the back, and added a fitting backpiece. ![]() This is how itīll look like. I like it! ![]() From behind. Laterz! ![]() ![]()
#44 |
Shut up and Mod
Nice
__________________
Life. Liberty. The pursuit of those who oppose it.![]() Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide @furballzen |
#45 |
Squid
Thanks a lot!
#46 |
Squid
Iīve come up with some designs for the foot, but I canīt really decide. Any thoughts?
![]() Alt 1. The classic one... Youīve seen it on previous builds. But I like it, itīs plain and elegant. ![]() Alt. 2 The reaching one. A bit more "up" to it I guess ![]() Alt 3. The organic one... I donīt know about this one, but itīs something new. ![]() Alt 4. The six legged one... Looks like a squid somehow, but I kinda like it anyway. Hereīs an animation I made for you guys, just for the fun of it ![]() ![]() ![]()
#47 |
Keep calm & mod on. =)
Alt 4 I think quizz, the others are nice but 4 looks good to me.
![]() Animation made me lol, can picture the giddy rig scuffling around a room LMAO, needs a techno beat & flashing lights. ![]() ![]() Oh yeah, the IO cover looks awesome BTW. |
#48 |
Multimodder
I like the dancing computer option.
I would vote that you do Alt3, but with six legs. Definitely six legs is the way to go. You do great work! |
#50 |
Pump Killer
Alt 3 - with 5 or 6 legs. I think the curvy shape of the feet would look good with the dome on top.
But 4 legs is just wrong, just like 4 spokes on a rim for a car! ![]() Beautifull work man!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#51 |
I ate Bhindi Bhaji.
I agree on alt3 as Angle says, because the curved legs go with the curved dome.
Great work. |
#52 |
Scratchbuilder
Im with Wayne on this one. alt 4!
__________________
Scratch builds | Cold Winter | CURV3D | The Red One | Casemods | BarPC | Check out my facebook-page where I post everything about my mods. Like/share if you want to.
#53 |
Hypermodder
Alt5... do it!
My vote would be Alt4, if Alt5 isn't attainable (the animation )
__________________
Mosquito Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC |
#54 |
Supermodder
Alt 4 gets my vote.
#55 |
Squid
Thanks for all the replies guys, really appreciated!!
Ok, so itīs alt.5 then, the dancing fidgety rig ![]() ![]() ![]() Seriously, Iīll go for six legs then. Personally, Iīd go for alt 4, but thatīs me thinking safe I guess. The curved one would look more interesting in a way, but itīs almost too much, especially with six legs I think. Very squiddy-like. Alt 4 WILL look more stable and clean, and it kinda resembles the roots of a tree. Hmm... Got some more thinking to do. Thanks again mates!!
#56 |
I think we can make that fit
Great wood working skills, I'm looking forward to seeing more keep up the good work and I think Alt 3 is nice.
__________________
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses |
#57 | |
Squid
I finally decided to go with alt 4. I like the simplicity and steadiness. This is how I made the foot: ![]() Made a six sided rod out of birch on the table router. Had to be accurate, and this was acctually a bit hard to make. ![]() Took a piece of walnut ![]() Sanded it ![]() Split it in three ![]() Then just cut the three into six. I also turned a bit of the rod on top for mounting it later. Then I cut it to the lenght of 130mm. ![]() Walnut is very light weighted, so I made some small metal rods for extra weight. ![]() Put them in there. ![]() When I tested the construction, the pegs where too long and created a gap between rod and feet. But I liked the expression of it very much, so now Iīm thinking about using it. Iīm thinking about using 6mm copper rods instead of regular pegs. What do you guys think? ![]() From under ![]() From above ![]() Close up Some paint work done aswell. ![]() From birch... ![]() .. to black! ![]() Also painted the inner construction ![]() Took what I could find and used orange as primer ![]() Then two layers of "ancient white" ![]() Close up. Laterzzz / Quizz |
#58 |
Supermodder
nice progress! i think copper would look awesome!
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#59 |
Hypermodder
Nice work! The pegs don't look bad, but I think I would use regular dowel instead of the fluted ones, but that's just me. I won't lie, though, I was hoping to see some sliding dovetails ;-)
When you say you sanded the walnut, did you actually sand it to that shape? No band saw to remove most of it? That must have taken some time...
__________________
#60 | |
Squid
Thank you!
But the dowels made me noticed that gap effect, so Iīm glad I did it. Btw, as I wrote above, Iīm not going to use those wooden dowels, but copper ones. Itīll look nice I think. And yeah, I put it in a bandsaw before sanding. Iīm just lazzzzy when typing... You my friend, are very observant =)
| Thread Tools | |
| View Mode | |
