Reply
Thread Tools View Mode
Old 6th Dec 2012, 16:47   #81
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
oooh, delicious combo of copper and walnut. It's like when those dudes eating peanut butter and chocolate accidentally ran into each other.
Cheapskate is offline   Reply With Quote
Old 6th Dec 2012, 19:45   #82
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Again, subbed waaaaay too late. Anyway, now I'm here.
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 7th Dec 2012, 07:41   #83
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysisquizz_kid can run Crysis
Peanut butter and chocolate? Thatīs a deadly sin man... But thanks!
Hi man... Itīs never too late for stopping by. Appreciate it!
__________________
R-KAID-Я (in progress)
The Shrine / REDELUX / 4M / R-kaid-6 / Sputnik 0667
quizz_kid is offline   Reply With Quote
Old 7th Dec 2012, 14:58   #84
quizz_kid
Squid
quizz_kid's Avatar
:Hereīs an update for you all!
I started off with the lighting... This is the idea:
Got this 8mm copper tube in the mail this morning
I aslo got this little tube cutter... Itīs very effective and the cuts are perfect.
I just cut the whole tube down into small random sized pipes.
Then I inserted some black bezel LED holders into the tubes, and they fitted almost too perfect (I only had three LED holders, so gonna order some more) To make the diodes fit Iīll have to sand the edges down like on the picture. Well thatīs going to be boring...
Then I placed the pipes in a nice "random" flow on the top plate and marked it for drilling. I decided to have some LEDs up on the I/O hider too.
Then I wanted to try something new for some of the cables. This is the power SW cable. I cut one of the cables and replaced it with a copper wire for good bending.
I tried to get the two cables through this nice lace I had laying around, but it was too tight. I came up with a solution where I put a tiny piece of schrinking tube on the end of both cables, and finally managed to get them both through.
And this is what you can make with a cable like this, a stable spiral. I like it!!
Then I made a mesh for the I/O hider and found a nice little thing for the P4 cable to go through.
I painted the mesh black, and turned brass into copper. This is how it looks. Oh, and yeah, thatīs my DIY P4 cable.
And here are some pictures of the pipes breaking through the surface of the top plate.
The I/O hider
From above
Close up
Another angle
Finally, I made the tiny tiny walnut piece. Can you guess the function of this one??? Itīs 52mm long, if thatīs a clue?...
Laterzzz!
__________________
Old 7th Dec 2012, 16:44   #85
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
24 pin?
__________________
Cosmos S Reaper L.R.E.C. Scorpio
Arya-under construction ROG Crawler-under construction
Pranja is online now   Reply With Quote
Old 7th Dec 2012, 19:28   #86
quizz_kid
Squid
quizz_kid's Avatar
Originally Posted by Pranja View Post
24 pin?
Just spoil all the fun Pranja!! ... and we have a winner. But you scare me. Are you walking around with the measurements of an ATX connector in your head??
__________________
Old 7th Dec 2012, 20:44   #87
Pranja
Fenrir The Wolf
Pranja's Avatar
Well,my professor would said: "That's the way how engineers solve problems."
I don't know measurments,but I am very good in comparing object sizes.
__________________
Old 7th Dec 2012, 22:01   #88
quizz_kid
Squid
quizz_kid's Avatar
Comparing sizes... Now thatīs a .... skill!!
__________________
Old 7th Dec 2012, 22:07   #89
quizz_kid
Squid
quizz_kid's Avatar
Iīve been looking at the copper pipes all evening, and Iīm not too sure about them anymore. I find them nice, but for this build they just might be a bit too much. I want something more simplyfied here I think. Iīm going to make a new top plate tomorrow, exactly the same, but without the pipes... Hmm
__________________
Old 11th Dec 2012, 15:59   #90
quizz_kid
Squid
quizz_kid's Avatar
Update time
I decided to get rid of the door function and glued it all together. Thereīs really no need for a door anymore, this after a minor change in the case design. And it will feel more solid now. I left the hinges in there in lack of ideas, but itīll look ok I think.
As I said, those copper pipes seemed a bit to much, so I made a new top plate, a very similar one as you can see, but with 7mm holes instead of 8mm, AND i put a darker stain on it. Itīll look better with the board and is a nice contrast to the outer shell. Much better I think.
I will leave those copper pipes and go with these tiny LED bezel holders instead. The build will have a much cleaner look now. But what a waste of copper
Then I stained the I/O hider in the same tone as the top plate and made a new mesh.
Then it was time for some sleeving. Itīs my first ATX sleeving, and itīs very unique I guess. Used black and black/brown cotton laces for the job.
The walnut connector in place. Iīm very happy with the result.
From another view
.. and another one
.. and another one. Donīt know if Iīm going to keep that spiral cable though.
Last shot... Here you can see the new mesh aswell. Better alighment and it almost touches the board now. Also got rid of that P4 copper detail... Much better!
Laterzzz!
__________________
Old 12th Dec 2012, 20:58   #91
C4B12
Scratchbuilder
C4B12's Avatar
C4B12 has yet to learn the way of the DremelC4B12 has yet to learn the way of the Dremel
Oh that 24-pin <3
__________________
Scratch builds | Cold Winter | CURV3D | The Red One |
Casemods | BarPC |
Check out my facebook-page where I post everything about my mods. Like/share if you want to.
C4B12 is offline   Reply With Quote
Old 13th Dec 2012, 07:10   #92
crudbreeder
What's a Dremel?
crudbreeder has yet to learn the way of the Dremel
I really like the sleeving on your projects, it really adds to the "vintage radio" look.
crudbreeder is offline   Reply With Quote
Old 13th Dec 2012, 20:03   #93
siliconfanatic
Car lover and Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
You Could make some led bezels with those copper pipe stubs... Might take a bit of work though... but wasting copper is sinfull so... Still looking good a always!
__________________
Blackalize it!
I *am* the guy who loves too many threads to bump them all.
siliconfanatic is offline   Reply With Quote
Old 13th Dec 2012, 20:18   #94
phinix
Say it! Who's your dremel?!
phinix's Avatar
phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!
Thanx guys...
I have a question. Does anyone here know where to get special angled SATA cables?
Iīll need a cable with an angle like this:
Here you have left and right versions: http://www.aquatuning.co.uk/index.ph...tprod/2/page/2
__________________
::: i5 2500K :: GTX670 :: 2x 840 PRO 128GB :: Gigabyte Z77 mATX :: 4GB Ballistix :: Hazro 27" :: CM QF Rapid MX Browns :::
projects: ::: “PHINIX CUBE” ::: "PHINIX nanoTOWER" ::: "PHINIX AURORA" :::
phinix is online now   Reply With Quote
Old 14th Dec 2012, 00:06   #95
quizz_kid
Squid
quizz_kid's Avatar
Originally Posted by C4B12 View Post
Oh that 24-pin <3
Glad you like it! Itīs just a detail, but Iīm quite proud myself
Thank you. Guess itīs the color scheme. Canīt go wrong with brow/black sleeves
Yeah, I knew. But too much copper and I might lose the copper, if you know what I mean. Better to keep it sparse I think, makes the few copper ingredients pop out real good.
Thanks. I found one on ebay though, a perfect one. Black and with round cable, not flat.
__________________
Old 14th Dec 2012, 19:10   #96
Darkwisdom
Retro Fan
Darkwisdom's Avatar
Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.Darkwisdom is a hoopy frood who really knows where their towel is.
I love that walnut connector. So much sexy wood. I'm thinking more and more about a wooden case for my first project log =p
__________________
~Intel Core I3 3220 ~8GB Corsair Vengeance 1600Mhz~ CorsairCX600w ~ Asus GTX560ti Direct CUII Core @ 950Mhz Memory @ 2250Mhz ~ P8H77 ~ 128GB Samsung 830 SSD ~ Gelid Tranquillo ~ USB modded NES, Master System, Mega Drive and N64 controllers for Emulation~
Darkwisdom is offline   Reply With Quote
Old 14th Dec 2012, 19:49   #97
quizz_kid
Squid
quizz_kid's Avatar
Thanks man. Yeah, wood is really something. Really looking forward to your log!
Small update:
Glued the footstand into the case today
The feet are not mounted into the stand yet, as you may notice the small gap to the left
Another angle
Then I started on the rad. This is my way of mounting it... Spacers painted copper
And these are painted pegs. I found some perfect metal fittings for themounting aswell. Painted them black.
Below are some grainy photos of the rad when mounted. I like it very much...
__________________
Old 14th Dec 2012, 19:53   #98
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
man that 24pin block is sooooo damn sexy!
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 14th Dec 2012, 20:33   #99
Pranja
Fenrir The Wolf
Pranja's Avatar
Wow! O.o
Brilliant idea with rad mounting.
__________________
Old 15th Dec 2012, 20:37   #100
quizz_kid
Squid
quizz_kid's Avatar
Thanks editor!
Wow! O.o
Thank you pranja, the solution turned out quite good yes. Difficult to mount a radiator without having pegs from outside
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
