Reply
Thread Tools View Mode
Old 8th Feb 2013, 03:44   #101
Sissilisko
Multimodder
Sissilisko has yet to learn the way of the Dremel
nice to see it getting it's final form, keep up the good job!
__________________
Finished:
-Mini-PC http://forums.bit-tech.net/showthread.php?t=248203
unfinished:
none!
Sissilisko is offline   Reply With Quote
Old 8th Feb 2013, 19:17   #102
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
To be honest, I didn't like the first version at first sight, but the second, the evolved version will be very nice work!
__________________
Current projects: Tydirium is on the way!
Previous mods: |Sandcrawler Mod| |Illuminated Mind| |Graphite5|
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 8th Feb 2013, 20:43   #103
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
Originally Posted by siliconfanatic View Post
Mhm. The pics just make it look like acrylic sandwiched between alu. What with the build I'm financialy... narrowing down, being made with acrylic, steel and alu it gives me a very benefial alternative to cutting mind numbing amounts of acrylic and alu bars... solves a few design issues too,
Just means that you are all the more awesome by helping me a great deal without even knowing it
thanks
Of all the modders I most often find you to actually deserve the hammer of the great bindibadgi :worship:
Well,I am glad that my bad photography skills helped your project.
Thank you Sissilisko-I will.
Well, it was prototype-prototypes never look good. But I am glad that you like mark 4.
Some pics of rad fit testing:
100+ posts. Thank you for being such great support.
This is also first anniversary of start of my modding adventure.
__________________
_Cosmos S Reaper_ _L.R.E.C._ _Scorpio_
_Arya_-under construction _ROG Crawler_
Pranja is offline   Reply With Quote
Old 8th Feb 2013, 21:42   #104
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Not been keeping a close enough eye on this, looking awesome Pranja.
Waynio is offline   Reply With Quote
Old 8th Feb 2013, 21:54   #105
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
oooh, this is going to be great!
__________________
Works as a tool retailer, glad if i can help someone with tool questions!
Hopes that i someday completes my first scratchbuild...
kelmannen is offline   Reply With Quote
Old 8th Feb 2013, 22:22   #106
Pranja
Fenrir The Wolf
Pranja's Avatar
Thank you Waynio-I appreciate it.
Thank you kelmannen. I am glad that you like it.
__________________
Old 10th Feb 2013, 23:52   #107
Pranja
Fenrir The Wolf
Pranja's Avatar
I made a custom thermometer for water inside reservoir.
Items used: one fitting,teflon tape, cheap ebay digital thermometer, a little bit of hot glue.
Also,some new parts arrived.
__________________
Old 17th Feb 2013, 09:49   #108
Waynio
Waynio's Avatar
That's a heck of an awesome motherboard tray.
Actually, that is a motherboard tray isn't it?.
Old 17th Feb 2013, 11:30   #109
Pranja
Fenrir The Wolf
Pranja's Avatar
Yes, that is MBO tray. I am glad that you like it.
__________________
Old 18th Feb 2013, 18:02   #110
Pranja
Fenrir The Wolf
Pranja's Avatar
Update- I glued PSU holder-now it is a black and transparent version and fits nicely with case color scheme.
Design and holes of PSU bracket are changed a bit.
Gluing the part in its place.
__________________
Old 18th Feb 2013, 18:43   #111
AverageNinja
Almost an EpicNinja
AverageNinja's Avatar
AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.
I'm liking it dude! Keep 'em coming!
AverageNinja is offline   Reply With Quote
Old 18th Feb 2013, 18:44   #112
Pranja
Fenrir The Wolf
Pranja's Avatar
Thank you. I will.
__________________
Old 18th Feb 2013, 19:31   #113
siliconfanatic
Rep whore/ Car lover/ Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
Looking good!
__________________
Hard to explain to someone who has no clue. Or doesn't believe you. It's a daily struggle being in pain or feeling sick on the inside while you look fine on the outside. Please put this as your signature for at least 1 hour if you or someone you know has an invisible illness (Pancreatitis, Crohn's, PTSD, Anxiety, Bipolar, Depression, Diabetes, LUPUS, Fibromyalgia, MS,Lupus, ME, Arthritis, Cancer, Heart Disease, Epilepsy, Autism, etc.) " Never judge what you don't understand.
siliconfanatic is offline   Reply With Quote
Old 18th Feb 2013, 19:36   #114
Asouter
Tremendously Difficult Lifestyle
Asouter's Avatar
Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.
Nice project, I have some nylon spacers (8mm) which would be much kinder to your plexi than those bolts, I used them on deep thought ....If you like I could send some through if it'll help with your build
PM me if you're interested
A pic of how I'd used them
__________________
Finished Project : D33P THOUGHT
Finished Project : THING
Current Project : Mini Moto Mayhem
Asouter is offline   Reply With Quote
Old 18th Feb 2013, 20:02   #115
Pranja
Fenrir The Wolf
Pranja's Avatar
Looking good!
Thank you.
Thank you Asouter-that is very kind of you. I am grateful for your offer.
But I allready decided to use plexi tubes as spacers.
__________________
Old 18th Feb 2013, 20:38   #116
Asouter
Asouter's Avatar
Originally Posted by Pranja View Post
Thank you.
No worries Pranja, just noticed the unjust 3 star rating, voted for 5 stars to bump it up
__________________
Old 18th Feb 2013, 21:09   #117
Pranja
Fenrir The Wolf
Pranja's Avatar
Thanks for the rating Asouter,but I those stars don't worry me.
__________________
Old 18th Feb 2013, 21:17   #118
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.
Just a heads up: I used hot glue long ago in aquarium related stuff. It's not very good at sealing water. The seal will break with a little pressure/thermal expansion/etc..
Update faster. Please.
Cheapskate is offline   Reply With Quote
Old 18th Feb 2013, 21:21   #119
Pranja
Fenrir The Wolf
Pranja's Avatar
Don't worry-I used teflon tape for sealing water. Hot glue is only used to keep everything in place.
I wish I could update faster-but it is not up to me. Sorry.
__________________
Old 21st Feb 2013, 19:21   #120
Pranja
Fenrir The Wolf
Pranja's Avatar
PSU tray is finished and dead PSU is placed for testing.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
