Reply
Thread Tools View Mode
Old 17th Oct 2012, 23:33   #1
Ruairi
What's a Dremel?
Ruairi has yet to learn the way of the Dremel
Platinum Edition - SFF Dual CPU Work Station - Minor Update 20th October
About the project;
In brief:
This project was hatched when I brought a rather unusual Motherboard off John Morrison (a.k.a confusis) the Supermicro X7DWT a half SSI (16.5*41.6cm) dual socket motherboard. The board was a perfect candidate for a small form factor workstation build. The build gets it name from planned monochrome chrome and black exterior.
Explained:
Platinum Edition was designed as a movie editing and 3d Rendering workstation, for my work in indie films, computer modding and architectural design. The dimensions of the build are roughly 225mm W 450mm D 185mm H or just a little bit under 19 litres (the Intel SFF specification). This will be a scratch build made out of aluminium and glass. The colour theme will predominantly monochrome, with the exterior design being black and chrome. The design has been heavily influenced by Art Deco and Diesel Punk architecture and design. I will be placing a strong emphasis on silence, something usually neglected in server builds. I will be using 80mm Towers for the CPU's and aftermarket cooling for the GPU (I have allocated space for triple slot coolers in the design)
Specs:
CPU - Intel Xeon L5420 * 2 (overclocked using old school taped pin method to 3.00GHZ)
Motherboard - Supermicro X7DWT
Ram - 8GB DDR2 667 FB-Dimms
GPU - Sapphire HD 5670 with artic cooling cooler (temp)
PSU - Silverstone essentials 500w*
Coolers - Deepcool Ice Edge Mini FS * 2
* Run down of power usage; PSU has 408w of 12v power available (board runs solely off of 12v) CPU's are 60w * 2 overclocked. Chipset is 30 + 10w. Ram is 8w * 8w. HDD/SSD under 10w. Total : 234w. Leaving 174w Available for GPU. Why not leaves some headroom? Because power supply's operate much less efficiently when below 20% of there total output, by choosing a PSU that will keep the system power consumption in an optimal range I will save money in electricity over the life of the PC.
Modding started, first panels cut to size out off 3mm Aluminium (Tip: Get ripped in 30 days, become a manual case builder.. filing )
Silverstone 500w PSU, primed and ready for sleeving.
Modified 20 Pin connector for funky motherboard, thing i'll go with Black and Grey MKII, with maybe a hint of B-Magic, those empty slots bug me a bit, so I might have some dummy cables there
You all know what this means
PSU Sleeving started ( going slowly )
MDPC Kitteh
Ruairi is offline   Reply With Quote
Old 18th Oct 2012, 01:06   #2
siliconfanatic
Car lover and Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
no vid card slots? why not jus go fer an sr-2? i mean, is that cheaper or something? will be following closely as its still dual cpu and as for the air cooler: me gusta
__________________
Originally Posted by quizz_kid View Post
Blackalize it!
I *am* the guy who loves too many threads to bump them all.
siliconfanatic is offline   Reply With Quote
Old 18th Oct 2012, 01:24   #3
improprietary
FT03 is a bitch to watercool
improprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremel
When i saw the four ram sticks i was salivating, then i found out that its only eight gigs Do you really not need anymore?
Otherwise can't wait to see more!
__________________
I'm spending a year dead for tax reasons. - Douglas Adams
Wanna help me and get cloud storage? Use Dropbox http://db.tt/msbUQQC
improprietary is offline   Reply With Quote
Old 18th Oct 2012, 06:24   #4
Balder
Calmer than a monk on morphine
Balder's Avatar
Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.
http://www.supermicro.com/products/m...5400/X7DWT.cfm
Anyway that looks like a really funny (in a good way) board xD
Looking forward to see it come together!
__________________
All progress is precarious, and the solution of one problem brings us face to face with another problem.
- Martin Luther King, Jr.
Balder is offline   Reply With Quote
Old 18th Oct 2012, 22:23   #5
siliconfanatic
ah. overlooked that.
__________________
Blackalize it!
Old 18th Oct 2012, 22:45   #6
legoman
breaker of things
legoman's Avatar
legoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for president
Thats quite a tasty board that.... Subbed!
__________________
AMD Phenom X6 1605T @ 4.5Ghz |Corsair H80 |Gigbyte970A-UD3 | 2X4 GB Kingston HyperX Beast | ASUS AMD 6950 2GB DirectCU II | Corsair HX750 | Liteon DVD RW | Samsung HD103SJ 1Tb | Crucial M4 SSD 64GB | Phobya FanMax 6 | Edimax EW-7612Pln | Coolermaster Storm Trooper | Win 7 Pro 64it | Roccat ARVO | Logitech G500 | Bamboo 1 | Samsung SyncMaster 2033SW
legoman is offline   Reply With Quote
Old 18th Oct 2012, 23:11   #7
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
B NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run Crysis
I love that board,you should put the word about for a custom block....
B NEGATIVE is offline   Reply With Quote
Old 19th Oct 2012, 06:44   #8
Ruairi
What's a Dremel?
No video card shots as its in the rig I'm using at the moment (tis abit dusty too )
Not going with a SR2 for a few reasons:
A: it's consumer quality - Server gear is designed to run 24/7 in hot cramped enviroments, boards like the SR2 are more designed for short term benching runs and don't quite have the same durability.
B: it's MAHOOOSIVE case would have to be 2-3 times the size.
C: Pricey and hard to get a hold of.
Hey, yeah only 8gb at the moment, I will probably be upgrading to 16gb at some point though.
Yeah it is a funkay board, its design has allowed me to fit dual processors in a SFF case though.
Thanks
I won't be watercooling this build to save cost, complexity, size and maintenance. Maybe in a future build though
Picture of design added to first post
Old 19th Oct 2012, 13:51   #9
BeauchN
Multimodder
BeauchN should be considered for presidentBeauchN should be considered for presidentBeauchN should be considered for presidentBeauchN should be considered for presidentBeauchN should be considered for presidentBeauchN should be considered for presidentBeauchN should be considered for presidentBeauchN should be considered for presidentBeauchN should be considered for presidentBeauchN should be considered for presidentBeauchN should be considered for president
This looks very interesting! Subbed!
__________________
The Beast: Silverstone PS-07 | i7 970 @4.2 | Rampage Gene II | 12GB Vengeance RAM | H80 | GTX 560-Ti 448
BeauchN is offline   Reply With Quote
Old 19th Oct 2012, 14:29   #10
Dk_vr
Multimodder
Dk_vr's Avatar
Dk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the Dremel
Indeed very interesting...
These coolers are sponsored or you bought them and how are you going to mount 775 cooler on 771 socket? Some custom made brackets ?
I am asking because Supermicro motherboards can be really tricky when you decide to install a cooler.
Apart from that did you thought to make a channeling cooling with one fan on front plate to cool the whole machine ?
P.s. Do you think you will be able to cool the FBDIMMS like this ?
Dk_vr is offline   Reply With Quote
Old 19th Oct 2012, 15:59   #11
Phame
CNC mad!
Phame's Avatar
Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!
Looking forward to this.. GL
__________________
'You had my curiosity, now you have my attention'
Work in the pipeline *Server*
Completed Projects. *Orange and Black* and *The Wet Pi*
Phame is offline   Reply With Quote
Old 19th Oct 2012, 19:53   #12
siliconfanatic
whoa there! sr-2 built for short benching runs? just how short are we talking. if not able to be a gaming/server rig ima need a dual socket board like it with same # of pci slots+ram... and built to fold/etc all the time... ho does it perform if insulated+ below ambient? would it last longer? asking cause my knowledge of it just got up turned. talk about a rude awakening to cold hard facts if you ask me.
__________________
Blackalize it!
Old 19th Oct 2012, 22:04   #13
Ruairi
What's a Dremel?
Thanks!
I brought them, had a lot of good experiences with them though, I will be making custom mounting brackets for them
I haven't shown it in the model, but I will indeed be having a shroud to channel air over the chipset and ram coolers.
Thanks!
Hey,
I'm not saying that the SR2 isn't a great board, and will work fine as a regular gaming or workstation board. But this PC I'm building will be at 100% nearly 24/7 either with rendering, folding or other tasks. Something it was designed to do, something the SR2 could probably manage but was probably never designed to do/
About running it below ambient I have no idea to be honest, never really been into that stuff. IF you are looking for a dual socket board, and looks aren't on the top of the agenda I'd whole heartily recommend a Supermicro Board.
Minor update, cut some alu strips and put some of the pieces together for a little mockup
Last edited by Ruairi; 20th Oct 2012 at 00:37. Reason: Minor update, didn't want to double post.
Old 20th Oct 2012, 14:26   #14
siliconfanatic
ohh. okay.. guess ima havta look into that. thnks for the suggestion. was just kinda ridin the sr-2 wagon, cruisin along then BAM! it does have a weakness after all!
__________________
Blackalize it!
Old 2nd Nov 2012, 12:46   #15
llamafur
WaterCooled fool
llamafur's Avatar
llamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremel
Can't wait to see more of this.
llamafur is offline   Reply With Quote
Old 27th Nov 2012, 20:35   #16
avolla
Hackintosher
avolla's Avatar
avolla has yet to learn the way of the Dremel
Looks like fun. Can't wait to see this thing progress into something really special.
avolla is offline   Reply With Quote
Old 27th Nov 2012, 21:15   #17
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
This is turning out to be very interesting! I love the idea a lot! Can't wait to see more!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is online now   Reply With Quote
Old 27th Nov 2012, 21:30   #18
marius_mym
Minimodder
marius_mym's Avatar
marius_mym has yet to learn the way of the Dremel
Now that's what I call a special motherboard ! Subbed!
marius_mym is online now   Reply With Quote
Old 28th Nov 2012, 00:37   #19
voigts
Hypermodder
voigts's Avatar
voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.
I really like the look of this design. Very nice, modern, and yet the lines flow well.
__________________
Previous Project: Zenith Antique Radio Scratch Build
Current project: Project Quintessence
voigts is offline   Reply With Quote
Reply
Tags
dual cpu, mdpc, monochrome, sff, silent
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
