Reply
Thread Tools View Mode
Old 19th Jan 2013, 17:18   #61
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
AciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run Crysis
Had a really cheap idea. Got some screws and cut off most of it and glued it into the holes in the front. Unbelievable how such a small, cheap thing can make that much of a difference
AciD_RaiN is offline   Reply With Quote
Old 20th Jan 2013, 02:06   #62
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Wait.... what?
The front panel wasn't secured with bolts in the first place?
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 20th Jan 2013, 02:32   #63
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
Originally Posted by Nutman View Post
Wait.... what?
The front panel is screwed to the case but the acrylic and fan grill are just stuck on top of the front panel with double sided tape. I made some mistakes in the thinking ahead process so I just had to do it this way...
The front radiator wouldn't have fitted in line with the grill anyway...
Old 20th Jan 2013, 02:36   #64
Nutman
Nutman's Avatar
Oh, ok. Well, I guess you learn as you live.
__________________
Old 20th Jan 2013, 11:29   #65
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
That's what I love about making mistakes... You learn
Old 9th Feb 2013, 19:46   #66
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
Finally getting the motherboard on Monday so I decided to install the LEDs and do as much cable management as possible before the mobo installation. All that is left then is the CPU and liquid
Old 9th Feb 2013, 19:58   #67
tekonivel
Multimodder
tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!
Nice and clean. keep up the good work!
tekonivel is offline   Reply With Quote
Old 9th Feb 2013, 20:15   #68
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
Thanks mate I have already started a new mod but I just need the funds to start properly. I will be selling this one to finance the next one
Old 10th Feb 2013, 16:10   #69
Lehani
Multimodder
Lehani's Avatar
Lehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the Dremel
so are you droppin' this mod ? or will you finish it ?
__________________
Why did you buy that? - because i can
Mods: Watered Shadey
Lehani is offline   Reply With Quote
Old 10th Feb 2013, 17:07   #70
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
I will finish it as soon as I can afford a descent CPU for it
Then I will sell it if I can...
Old 11th Feb 2013, 22:21   #71
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
I received the motherboard today so I did some more work
Let the fun begin BTW cable management is not my strong side...
Old 11th Feb 2013, 22:50   #72
Nutman
Nutman's Avatar
Very nice. Gonna use the same mobo for the wifey's upcoming build. Is it any good so far?
__________________
Old 11th Feb 2013, 22:53   #73
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
It looks awesome but I don't have a CPU yet so I don't know if it's any good :P
Old 13th Feb 2013, 18:19   #74
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Looking sweet.
-One thing:You could lash the gpu power cords to the side of the front fans. It would hide the ugly side of the fans, and straighten your cables in one fell swoop.
-Ignore me if that was the plan all along.
Cheapskate is offline   Reply With Quote
Old 13th Feb 2013, 20:57   #75
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
Originally Posted by Cheapskate View Post
Looking sweet.
Thanks mate I had been thinking about it actually but I probably wouldn't have done it unless someone had pointed it out
Old 15th Feb 2013, 06:25   #76
jeckulz
Supermodder
jeckulz's Avatar
jeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremel
Great work mate.
Nice touch with the old di noc there
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz
OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb
Coolermaster 600w Silent Pro Modded Lian Li PC-0700
jeckulz is offline   Reply With Quote
Old 15th Feb 2013, 06:54   #77
Meelobee
< Your add here >
Meelobee's Avatar
Meelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run Crysis
Can't you route the cables from the videocard up to the roof and then to the front/back?That would give it a much cleaner look.
Like this:
Meelobee is offline   Reply With Quote
Old 15th Feb 2013, 08:28   #78
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
Like this:
I am pretty sure that was what Cheapskate meant so yes that is the plan
Old 15th Feb 2013, 15:11   #79
AverageNinja
Tech-Kid
AverageNinja's Avatar
AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.
Looking really nice! I love the bitfenix prodigy!
AverageNinja is offline   Reply With Quote
Old 15th Feb 2013, 16:08   #80
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
Thanks mate I love it too but if I am ever gonna do a build that small I am probably not gonna spend that much on it like I did with this one :P
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
