Old 21st Oct 2012, 22:56   #1
javaman
May irritate Eyes
javaman's Avatar
javaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysisjavaman can run Crysis
Phenom ii 955
I recently upgraded my pc with a phenom ii 955. Ive folded a few wus but What sort of ppd should i expect? I seem to be getting around 1k ppd.
javaman is offline   Reply With Quote
Old 22nd Oct 2012, 08:39   #2
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.
IIRC i had a Phemon II 950 at stock speed and i was getting 5-6k ppd
__________________
2x Xeon 5620 @ 3.8GHz under water
3770k @ 4.8GHz, Custom loop, GTX680 OC'd
kirk46 is online now   Reply With Quote
Old 22nd Oct 2012, 09:27   #3
Taffy
Folding for Margaret 17/3/2011 RIP
Taffy's Avatar
Taffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the Dremel
My PhenomII 955 gave about 6k fairly consistently with no overclock
__________________
1) MSI 790FX-GD70, AMD PH.II X4 955, 4GB Corsair DDR3, 2 X GTX 275, 1000W PSU in Lian Li 2100. 2) MSI 790FX-GD70, AMD PH II X3 720, 4GB Corsair DDR3, 1 X GTX 275 600W PSU in Lian Li 1100. Alienware M17x-R2 folding on i5 520M
Folding stats
Taffy is offline   Reply With Quote
Old 22nd Oct 2012, 12:56   #4
javaman
May irritate Eyes
javaman's Avatar
Im gonna have to look into my client then somethings definitely amiss. The GTX460 is producing about 2 WU's a day@ 5.7K each. So 11K PPD is coming from that, every 2days or so im get an extra WU produced @ 1.6K.
Old 24th Oct 2012, 22:48   #5
Ben Lamb
Modder
Ben Lamb has yet to learn the way of the Dremel
An x4 phenom should be producing at least 6k ppd sounds like the graphics card is holding the cpu back. I recommend running virtual box in windows so you can fold using linux and use the GPU tracker sofware to fold using the GPU in windows. This stops the GPU holding the CPU back as much, virtual box hogs all the cpu power unless you run it at low priority in windows task manager. It has a feature to allow windows to use a percentage of the cpu cycles so you can provide your GPU with a bit of cpu power to fold. I recon you should be able to get a min of 18k+ ppd with your setup so its pretty good realy. I like phenom cpus so much better than those terrible bulldozers, shame they are hard to get hold of now.
Ben Lamb is offline   Reply With Quote
Old 25th Oct 2012, 23:10   #6
javaman
May irritate Eyes
javaman's Avatar
Cheers, I'll look into doing it that way. Might be a while tho before I report back since I'll only be home for a short time the next couple of weeks. Was hoping to experiment with VB anyway and now I have a goal for it =)
Yea, I was really hoping for a phenom x6 but they really do seem like gold dust now! Ended up settling for a 955 which is a nice upgrade from the athlon 6000.
Next up, dual/tri PCI-e lane mobo and reinstall my gtx260 lol. I think there's a little bug on the go again =/
Old 26th Oct 2012, 06:06   #7
Ben Lamb
Modder
They had some cheap x6 at scan, I drove down to buy one as they were showing in stock but they didnt have any. They tried to sell me a bulldozer - no thanks ! Phenoms are sweet, best thing to do now is get a motherboard with loads of pcie slots for GPUs and a big PSU because multi gpu folding is coming soon with monsta points !
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
