#1 |
Indonesian Modder
Poor Man's PC MOD - Finish..
Yaaay, finish.. now i can focus to my next mod..
This is my 2nd thread.. The first one is: Poor Man's PC MOD (cheap PSU Sleeving + guide) Honestly i dont know how to start this thread My PC spec Procie: Intel Core G840 2.8Ghz Cache 3MB [Tray] Socket LGA 1155 HSF: Xigmatek Dark Knight (na na na na na na na) Mobo: ASRock H61M-U3S3 (LGA 1155, Intel H61, DDR3, USB3, SATA3) RAM: Patriot DDR3 Signature Line Kit Series Dual Channel PC10600 4GB VGA: Sapphire Radeon HD6670 1GB DDR5 128 Bit CARBON PCI cover Case: Powerlogic Attrix 5000 CARBON PSU: FSP Supersonic 450W Monitor: LG Flatron 17" CARBON Keyboard n Mouse: DELL CARBON Fan: Yateloon D12SH-12 GP, 88 CFM, 2200 RPM, Fully designed with anti vibration damper. Lets start with PSU sleeving... Start Sleeving 30 meter shoe laces for less than you can see some detail pics for its quality on my first thread. I'm using low price FSP Super Sonic 450 ![]() This is how I make the tool to open that 24 pin, just an ordinary MacGuyver multi tools ![]() And this is the final result... ![]() ![]() And now, i want to deal with vibration damper for my yateloon fans. Instead of buying 3$ rubber screw for each fan, i prefer tearing my mouse pad and buy some rubber rope (pre sleeved at 3$ per 100yards ).![]() ![]() ![]() ![]() and tied the fans like this: ![]() ![]() It is usefull for fan bracket alternative too ![]() Done! ![]() Yateloon, the best at its price/performance * Model: D12SH-12 * Air Flow: 77 CFM * Fan Speed: 2200 RPM * Noise Level: 36 dBA * Current: 0.30 Amps 2 pin w/o rpm sensor cost less than 2$ For this mod, I use an old case (2006) Powerlogix Attrix 5000 (2nd hand for only 18$) ![]() A nice case, complete with temperature, RPM sensor on LCD front panel display. And yes as all other old case, PSU bay are positioned above motherboard. I would like to change psu position to someplace under mobo like other modern case. ![]() (damn autofocus) Since it's only in my dream that i could afford a COSMOS II, so a cosmos style case feet would be awesome enough for me
#2 |
Indonesian Modder
![]() This is where HDD cage belong ![]() Aaaaaand its gone ![]() Make a hole for PSU ![]() ![]() ![]() ![]() Fits perfectly ![]() This is the front lcd display ![]() ![]() No, i'm not doing duck face for top fans: ![]() ![]() ![]() ![]() And this is my fans... yaaay, i have lot of fans For case feet, cosmos style... ![]() ![]() ![]() ![]() I use few cents priced bathroom towel hanger
#3 |
Ultramodder
Its all about what you do with what you have.
Im not worried about sponsored builds and the stuff people have been given, so i wouldnt worry about that. Im sure most on here arent that shallow that they only watch builds if the modder gets stuff for free. Its about the effort you put in and your doing fine so far. keep it up. |
#4 | |
Indonesian Modder
to heat things up: ![]() ![]() ![]() ![]() ![]() ![]() ![]() 2.5$ (45cm x 100cm) carbon texture sticker And my mouse... and my monitor... and my wallpaper too ![]() Aaaannnddd... ![]() ![]() ![]() ![]() ![]()
#5 |
Multimodder
nice way to get things done your way. I think you represent many of us who don't have the funds to buy asus ROG stuff and dual cpu builds with the SLI configs.
keep up the good work! |
#6 | |
Indonesian Modder
Anti vibration plus tool less HDD rack ![]() ![]() No more HDD vibration noise ![]() and its easy to swap HDD too (after I update my driver, i can easily safely remove HDD on my windows) ![]() I messed up in several areas when painting my case , i'll repaint it once everything is done. took me weeks to search left angle PSU power cable.. all I can found is right angle power cable ![]() some early pics ![]() I have noise dampening pad too.. i believe it would dampening some sound, or at least it covers case feet screws ![]()
#7 |
Hypermodder
Looking good. I love this because you're simply using what's available.
Have you considered putting some filtreing material to help keep the dust out of your PSU? |
#8 | |
Indonesian Modder
Using 3 yateloons at full speed produce enough noise. But if i turn it off, my SB temperature would reach 60 and my case will beeping when heat sensors hitting 60C. A store available fan controller will not written on my shopping list. So i'm trying to make my own fan controller with my limited knowledge. After several readings and learning electrical scheme, i nearly give up. Then i came up with the easiest fan controller idea using just a potensiometer to reduce the delivered "volt" to fan. ![]() I try three different potensiometer ![]() And use four of this yateloons ![]() ![]() ![]() I tried every configuration, 1 potensio for 1/2/3/4 fans, 12V+ or ground cable in potensio, basicly any possibilities that possible to connect my fan with this cheap fan controller. Gladly i dont blew up my PSU ![]() Then i found out that 1K ohm potensio is powerfull enough to controll one 0.3A fan. I also mod my PSU too, to make it possible to run fans on 12v or 5v. I color my molex with permanent white board marker a lot easier than spray paint.![]() I'm not satisfy enough with my mod, so i make single hole for single psu cable
#9 |
Multimodder
Great job mate!
I really like to see mods done with what you can get that looks great. Keep the good work and remember not everything is about the cash.
#10 |
*learning english*
that's cool!
i've used mouse-pad for "anti-vibration" but that idea with hole-puncher is brilliant!!! there were always a problem for me to make screw holes in dust-filtering materials and dampeners. and now it's solved!
__________________
10 re-plan "SuperBestBuild Of My Dream" 20 have a sleep 30 goto 10 |
#11 |
In cornichons I trust.
Oh, great ! I love the way you use the lacets to fix the fans : it looks nice and it's screw-less. And this is really cool !
__________________
“If you don't know what it is, it may be edible.” — Mod or not mod, leçon n° 27 —
#12 | |
Hypermodder
I didn't have my morning coffee yet when I posted.
#13 |
Retro Fan
Love it! I like to see budget builds here. It always amazes me how people can use cost-cutting tactics to make some great builds.
After all, most of us can't afford to make PC Cases out of Aluminium, dual watercooling loops and use GTX 680s for everything. I think the shoelaces are an amazing idea. I might do something similar with coloured ones. You've given me some great ideas to mod my case without spending much.
__________________
~Intel Core I3 3220 ~8GB Corsair Vengeance 1600Mhz~ CorsairCX600w ~ Asus GTX560ti Direct CUII Core @ 950Mhz Memory @ 2250Mhz ~ P8H77 ~ 128GB Samsung 830 SSD ~ Gelid Tranquillo ~ USB modded NES, Master System, Mega Drive and N64 controllers for Emulation~
#14 |
Fenrir The Wolf
High five! Excellent job friend.
#15 |
Minimodder
Really nice work - very professional-looking and you must be really resourceful to find uses for all those different parts like the mousemat - keep giving us more ideas please!
#16 |
What's a Dremel?
dude, ur topic make me create an account for this forum, and i would like to say:
your pc rox!!! i know how hard is to buy expensive thing to make a good casemod, i live in brazil and is very hard to find 'casemod' thing to buy, and a basic acrilic 30x30 costs +\- R$80,00(40 dollars) what i want to say is, u give me very nice ideas for my 'casemod', actually is only a tt v4 yet, im planning start something in it.. Congratulation Dude, your pc rox!!! |
#17 | |||||
Indonesian Modder
![]() I'm thinking to make budgeted water cooling mod... but may be next mod... i've already purchase another case (30$ tower case, 2nd handed as usual )Quote:
A brown coffee with brown sugar would be great... have you tried luwak coffee? Quote:
I would love to see other gread ideas.. ![]() Quote:
#18 |
Indonesian Modder
another shoelace sleeve:
![]() ![]() Premium Power Cable PSU
#19 |
I think we can make that fit
Just a suggestion, If you would switch your airflow from bottom to top it would cool you PC better. It is kind of hard to use your Power supply to pull hot air down. Your working against Convection I believe is the correct term. Other than that not real crazy about all the CF sticker I think paint would have looked a bit nicer. Great Job working within a tight budget and with what you had. My hat is off to you
__________________
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses |
#20 | |
Indonesian Modder
![]() outlet fans: 2 yateloon 12cm nearly 88CFM each, 1 9cm NMB fan about 30CFM, and 1 yateloon 12cm for PSU to push the heat out of psu case. inlet fans: none I'm bad in painting... really bad.. 3$/can I need minimum 2 primer cans and 2 cans for main paint, and perhaps 1 can of clear coat... and some sanding paper... I already tried, and failed.. I'll try harder in my next mod.. |
| Tags |
| jay2 cheapskate |
| Thread Tools | |
| View Mode | |
