Reply
Thread Tools View Mode
Old 23rd Oct 2012, 05:11   #21
Vetalar
*learning english*
Vetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming Saiyan
Convection isn't a problem here IMHO. In active airmovement it's almost doesn't matter. Only problem could be when warm air from psu sucked inside case by fans
send from my BLADE via tapatalk
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 23rd Oct 2012, 06:10   #22
jay2
Indonesian Modder
jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.
Ambient air sucked inside psu thru my side window case (metal mesh with air filters) and push hot air from PSU out of my case (bottom mesh PSU).
(bottom view)
next time i'll make another fan hole at the bottom case and put my yateloon to exhaust hot air around vga card.
Negative air flow fans ...negative air flow fans
jay2 is offline   Reply With Quote
Old 23rd Oct 2012, 15:55   #23
Ripitup121
MMMMMMm watercooling....
Ripitup121's Avatar
Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.
Epic budget modding here mate, i love the sleeve on the coolermaster style legs you made. One question though and thats why does it look like your cpu cooler is tilted, did it take a knock or is it just the photo angle???
Epic work mate
Rip
__________________
Asus ROG Maximus V Formula MoBo, Core i5 3570K @ 4.7Ghz, 6GB Corsair Dominator Ram 1600Mhz, SLi GTX460's(1GB), Enermax Revolution 1250W PSU, Xigmatek Elysium Chassis
Dual WaterCooling Loops with 12 Noctua NF-P12's = WOOOOSH!!!
Ripitup121 is offline   Reply With Quote
Old 23rd Oct 2012, 19:59   #24
Julien Pod
What's a Dremel?
Julien Pod has yet to learn the way of the Dremel
Very funny the way you used shoe laces !!!
And pretty result by the way
Julien Pod is offline   Reply With Quote
Old 24th Oct 2012, 02:27   #25
jay2
Indonesian Modder
Epic work mate
Rip
I found 2nd hand xigmatek dark knight (without 1155 bracket) for only 15$. So instead of using intel standard cpu cooler, i took 775 xigmatek dark knight. And luckily my asrock mobo has Combo Cooler feature so i can use 775 HSF on 1155 socket, although yes the mounting hole is a little bit tilted
ppl can do anything with everything they have when they really want something badly.
Old 24th Oct 2012, 04:28   #26
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming Saiyan
Originally Posted by jay2 View Post
This is my air flow setting, i'm using negative air flow to pull all hot air out of my case, and let the cold air flowing through side case (with filter)
outlet fans: 2 yateloon 12cm nearly 88CFM each, 1 9cm NMB fan about 30CFM, and 1 yateloon 12cm for PSU to push the heat out of psu case.
inlet fans: none
I'm bad in painting... really bad.. 3$/can I need minimum 2 primer cans and 2 cans for main paint, and perhaps 1 can of clear coat... and some sanding paper... I already tried, and failed..
I'll try harder in my next mod..
My apologies I must have misred your post, I thought you were pushing air through the top and using your PSU to pull it through the bottom. Please ignore what I wrote above about the airflow.
__________________
Deders - What if you touch yourself with kittens?
.//TuNdRa - Short of standing on a street corner (I'd make an ugly hooker, anyhow.)
i7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, MSI 660TI 3GB, BFG 260 GTX Core 216 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is offline   Reply With Quote
Old 24th Oct 2012, 04:41   #27
jay2
Indonesian Modder
thats alright, no need to apologies
a little progress:
since i had to sell my dremel like rotary tool to survive untill next salary day
I use a knive to drill some holes on font case
Marked non food kitchen knive. Make 3 holes
For this... fighter pilot style switch from local market and my diy fan controller. I forget to buy one more potensio knob
I use the switch to change fan voltage from 12V to 5V incase i need total silence for movies. Fan controller needed when i play some stealth game. Full rpm only for benchmarking (which is i never did) and for full action game (full speaker volume to cover 44++dB yateloons).
Old 24th Oct 2012, 09:47   #28
Ripitup121
Ripitup121's Avatar
[QUOTE=jay2;3195998]I found 2nd hand xigmatek dark knight (without 1155 bracket) for only 15$. So instead of using intel standard cpu cooler, i took 775 xigmatek dark knight. And luckily my asrock mobo has Combo Cooler feature so i can use 775 HSF on 1155 socket, although yes the mounting hole is a little bit tilted
Ah ok no worries so, is it affecting your temp at all?
__________________
Old 24th Oct 2012, 15:20   #29
jay2
Indonesian Modder
So far, it still better than intel stock HSF..
Old 24th Oct 2012, 20:01   #30
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Doing great. Seeing this makes me want to do another $0 case. The towel rack is brilliant!
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 25th Oct 2012, 08:44   #31
Kasius
Bringing the dremolition
Kasius has yet to learn the way of the Dremel
Imaginative, love it
__________________
"We are the music makers and we are the dreamers of dreams"
Kasius is offline   Reply With Quote
Old 25th Oct 2012, 09:47   #32
jay2
Indonesian Modder
Do it love to see your mod design..
I'm thinking to get water cooled... tomorrow is salary day and now i'm calculating some impossibilities (240 rad, standard pump, low end cpu water block, NB block, vga block, normal reservoir)
naaah, i guess I'll just buy some tubing first, and several cheap fitting...
Old 26th Oct 2012, 18:50   #33
Vloyadkin
What's a Dremel?
Vloyadkin has yet to learn the way of the Dremel
I really like this mod and your ingenuity(?) (spelling pad)..
Rated and subbed
Vloyadkin is offline   Reply With Quote
Old 29th Oct 2012, 02:25   #34
jay2
Indonesian Modder
Rated and subbed
I got packages from china... i'll install em tomorrow
Old 30th Oct 2012, 02:44   #35
jay2
Indonesian Modder
3 bay reservoir... less than 2$, i'm not measuring anything, if it's not fit, i'll use it as my tool box, but then it fits perfectly i'm glad
I'll buy 5$ submersible pump tomorrow...
Old 30th Oct 2012, 07:18   #36
Editor22
E22 | Hex-Gear
Editor22's Avatar
Editor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming Saiyan
Some really cool ideas dude, loving the fan mounts and the towel rack base.
__________________
Stores: E22 | HEX GEAR
Social: Youtube | Facebook
Projects: Evolution | K2 MK1 | 21
Editor22 is offline   Reply With Quote
Old 1st Nov 2012, 19:35   #37
WALKYRIE
Minimodder
WALKYRIE has yet to learn the way of the Dremel
I love those full black matt Yate-Loon Fans, me too have lots of Yate-Loon 120 and 140mm
WALKYRIE is offline   Reply With Quote
Old 6th Nov 2012, 02:33   #38
jay2
Indonesian Modder
Updates...
My beloved Xigmatek Dark Knight
more fins down
And.. tadaaa... I'll tidy up this thing later...
Old 6th Nov 2012, 03:01   #39
HobbieZones.com
Multimodder
HobbieZones.com's Avatar
HobbieZones.com has yet to learn the way of the Dremel
Very good idea to take a stock cpu cooler and mod it to water.
Just be sure to do a leak test then install.
Looking GOOD.
HobbieZones.com is offline   Reply With Quote
Old 6th Nov 2012, 06:21   #40
jay2
Indonesian Modder
Looking GOOD.
Leak test passed
Reply
Tags
jay2 cheapskate
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
