Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 24th Oct 2012, 07:05   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
SteelSeries Siberia v2 Frost Blue review
http://www.bit-tech.net/hardware/per...-blue-review/1
brumgrunt is offline   Reply With Quote
Old 24th Oct 2012, 09:11   #2
Toasted Rofls
What's a Dremel?
Toasted Rofls has yet to learn the way of the Dremel
"As such, it remains a solid choice, just not the best."
I love how upfront and direct you guys are about this sort of stuff. It's like when you are discussing technology with a friend, you tend to make candid statements like "sure, it's powerful, but XXX is by far cheaper and only 5% slower, it's just the better choice." It's you being honest about the product. "Yeah, it's good, but XXX is still probably the one you want."
Far to often reviewers just look at things in a vacuum, and while that's appropriate at certain times, like when looking at the extreme end of enthusiast equipment, where all that matters to 99% of the people buying it is sheer performance, almost everything else needs to be weighted against peers, and I'm glad you guys do that in every review.
Toasted Rofls is offline   Reply With Quote
Old 24th Oct 2012, 09:40   #3
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
The ear cushion material is advertised as noise deadening and though your ears won't be in a vacuum
But that's a good thing and much less painful.
http://imagine.gsfc.nasa.gov/docs/as...rs/970603.html
Guinevere is offline   Reply With Quote
Old 24th Oct 2012, 12:46   #4
Smellyhead
Supermodder
Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.
Does anyone actually buy this version? For £60-70 you can get one of the many other colours which make the headset much more worth the price tag.
Would you guys still rate the Vucan above it when taking into consideration the less expensive colours? (Black/White can be had for £60, others for £60-70)
__________________
i7 2600k | Gigabyte Z68A-D3-B3 | 8GB Vengence | Sapphire 380x Nitro | Antec VP550
Smellyhead is offline   Reply With Quote
Old 24th Oct 2012, 13:54   #5
SMIFFYDUDE
Supermodders on my D
SMIFFYDUDE's Avatar
SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.
Zimmer frames and wheelchairs pop into my head for some reason.
__________________
i7 6700K|Sabertooth Z170 S|16GB Crosair Dominator Platinum 3200MHz|KFA2 GTX 1080 HOF|Creative Sound Blaster ZxR|Super Flower Leadex Gold 850W|Corsair 780T|HP LP2475w|Speedlink Medusa 5.1|CM Storm Inferno|Windows 10
Steam: SMIFFY
SMIFFYDUDE is offline   Reply With Quote
Old 24th Oct 2012, 15:20   #6
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
It's hard to judge how alike they'd be, at least in terms of noise quality, as the different coloured Siberia v2 headsets are connected by 3.5mm jacks, and thus lack the built-in soundcard, while the Siberia v2 USB appears to feature a different, 7.1 virtual surround soundcard instead of the stereo one of the Frost Blue. As the hardware in the other headsets thus differs, however slightly, from the Frost Blue, I wouldn't want to recommend them outright, although I'm sure they'd be just as comfortable!
Dogbert666 is offline   Reply With Quote
Old 24th Oct 2012, 16:41   #7
SlowMotionSuicide
Come Hell or High Water
SlowMotionSuicide's Avatar
SlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for president
Nice system to go with the colour scheme:
__________________
G3258 @ 4.3GHz | MSI Z97 Gaming 5 | 8Gb Dominators | GTX 660 | Crucial MX100 256GB | F1 Spinpoint 1TB | Seasonic P-760 (XP≤) | NZXT H440W
SlowMotionSuicide is offline   Reply With Quote
Old 30th Jan 2013, 12:37   #8
matt...
Slacker
matt...'s Avatar
matt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremel
While I don't have a great comparison point other than some high-end Sony circumaural headphones (they did noise-cancelling at a slightly lower price point than Bose with just as good sound as far as I could tell) the 'basic' SteelSeries siberia V2s are excellent. Matched up with a basic Asus Xonar dgx sound card they really do sound excellent whether listening to music or gaming
They are fantastically comfortable and well recommended for just shy of £50....
__________________
"I have not failed. I've just found 10,000 ways that won't work," Thomas Edison
matt... is offline   Reply With Quote
Old 22nd Jun 2013, 23:06   #9
undertaken316
Banned
undertaken316 has yet to learn the way of the Dremel
I was looking for a more detailed look at the Siberia V2 especially the lue forst ediiton and I stumbled upon this awesome review. It convinced me
http://youtu.be/V1gwgFpKaJQ
undertaken316 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
