Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 24th Oct 2012, 22:24   #1
Ptarmigan
What's a Dremel?
Ptarmigan has yet to learn the way of the Dremel
Catalyst 12.11 (beta) drivers folding.
These new drivers are due out as public release any day now so I thought I'd download and test the beta out for folding and see if there is any improvement to go with the gaming improvement (yes I know Nvidia are better for folding but my wallet is not a bottomless pit and I have three kids to raise so the day I buy a new card/2 cards will be the day a mate gives me them for nowt!).
Anyway, having paused the client (V7) I installed the drivers and restarted the client....and got something a little unexpected...my time to complete a WU jumped from 7 hours to 4 days on one card and 16 hours on the other. Not what I was looking for.
Now, two things here, one, it's a beta driver, and two I did install part way through a WU. However, is anyone else testing the driver and if so are they also seeing exorbitant times to complete and did they install cleanly at the end of the previous WU?
If anyone has not already upgraded their drivers, and is not keen to see their PPD drop, I would suggest holding back on the upgrade until I or others can confirm if this is a genuine issue or if it is due to the way I did the upgrade.
Happy folding.
__________________
Hanging from a cliff by one hand while looking at the scenery below does wonders for work related stress....
Folding stats
Ptarmigan is offline   Reply With Quote
Old 26th Oct 2012, 19:26   #2
OlegZh
What's a Dremel?
OlegZh has yet to learn the way of the Dremel
Hello.
I have exactly the same behavior. I can add that GPU utilization dropped to 40%, CPU utilization per core dropped by half, temperature has fallen of course too. PPD dropped in 3 - 3.5 times (was ~6500, now it is 1910 on Radeon 7770 at 1140 MHz core). So folding is now kind of pointless with such efficiency.
OlegZh is offline   Reply With Quote
Old 29th Oct 2012, 15:51   #3
yht78
What's a Dremel?
yht78 has yet to learn the way of the Dremel
Hi, me too with hd 7850. Catalyst overdrive shows also 40% for the GPU activity while folding and PPD dropped from 5-6k to 1800. All games seems to run fine though.
Did you test the 12.10 whql drivers if it has the same problem? I'm thinking if I should revert back to 12.8 and wait for a proper drivers. No reason to fold with this low ppd.
yht78 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
