#1 |
Modding and coffee
Alienware Aurora ALX-XL
![]() The Alienware Aurora ALX-XL Sometimes you get a chance you can't say no to, so that's what happened to me. After some discussions and exchanging ideas with Dell, I am very happy to announce to you a build with a super case. It's allready beautiful But I'm gonna give it a try ![]() The Alienware Aurora desktop. And not only the case, but a complete configuration with the following components: - CASE : Alienware Aurora ALX 875W-chassis (Matte Black) - PROCESSOR: Intel® Core i7-3820 (4 Core, 10MB Cache, 3.60GHz) - OPERATING SYSTEM : Windows® 7 Home Premium, 64-bits - GRAPHICS : 1 GB GDDR5 NVIDIA® GeForce® GTX 555 - MEMORY : 16GB (4 x 4 GB) 1.600 MHz Quad Channel DDR3 - HARD DRIVE : 256 GB SSD - OPTICAL DRIVE : 8X Blu-ray Disc-rw-station en 24x dvd+/-rw-station Before I start, first I want to thank all the great sponsors for making this build possible. Alienware, for the system. ![]() Nvidia to deliver GPU upgrade (more on this later) ![]() And EKWB for the watercooling components ![]() There will be a lot of pictures again in this build. What is new is that I now going to add videos, think this will be a nice addition. First contact with an alien: Always a great feeling to receive packages Once everything is dragged into the living room to have another great feeling ..... unboxing![]() The Aurora is certainly well packed, they have given this some good thought. ![]() A box in a box ![]() ![]() Clips to unlock the cover ![]() Almost ![]() ![]() ![]() The Alienware Aurora ![]() ![]() ![]() ![]() ![]() ![]() ![]() Nice shapes ![]() ![]() ![]() Front also beautiful and clean ![]() ![]() ![]() ![]() ![]() One touch on the Alien head and the panel slides down. ![]() If the PC is turned on and you activate the sliding panel, the lights which illuminate the optical drives will turn on ![]() ![]() ![]() Acrylic part what looks very nice ... especially when it is enlightened ![]() ![]() Power button ![]() Behind this is a pushpanel to the front I / O. containing (2x) Hi-Speed USB 2.0 (1x) SuperSpeed USB 3.0 (1x) Mic (1x) Headphone ![]() At the rear is the handle to unlock the side panel. ![]() ![]() Pull the last vent ![]() ![]() To unlock the sidepanel ![]() ![]() The PSU (Alienware™ 875-watt) is also swappable and modular ![]() ![]() ![]() Another great gadget is the enlightenment on the back. Activated with a push button. ![]() ![]() Also a great gadget is the Alienware Active Venting. ![]() ![]() ![]() Next box. With keyboard and other accessories ![]() ![]() ![]() The Alienware tactx keyboard with two-zone lighting setup ![]() ![]() ![]() ![]() ![]() The Alienware mousepad ![]() Some documents ![]() Drivers and utilities ![]() Cables ![]() And two Alienware 3D avatars ![]() Not finished yet ..... a monitor, the beautiful Alienware OPTX AW2310 Specs: •Connections Dual-link DVI (with HDCP), HDMI, 4 x USB •Viewable Screen Size 23.5in •Maximum Resolution 1,920 x 1,080 •Contrast ratio 80,000:1 (dynamic), static not quoted •Brightness 400cd/m2 •Response time 3ms (grey-to-grey) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Back to the Alienware Aurora .... the inside First looks without sidepanel ![]() And again a nice gadget: when the sidepanel is removed, the inside is illuminated without the power on. ![]() ![]() Powered by rechargeable batteries ![]() Very handy!!! The caps for the airflow and coverup are very nicely designed and printed ![]() ![]() ![]() ![]() Cap for the GPUs is rotatable and removable ![]() ![]() Beautiful swappable, tool-less and cable-free hard drive bays ![]() ![]() ![]() ![]() ![]() Also well thought about is the power suply for the side panel (Lights) On the side of the powersupply are contact points which provide this ![]() ![]() For now a Nvidia GTX555 is installed, but this will be exchanged for two Nvidia GTX680 ![]() Cooler motherboard ![]() And the beautiful Alienware CPU cooler ![]() ![]() Personally I really like this one, so it stays in this build (perhaps modify) ![]() What cable management is concerned, everything is provided. But it looks a bit messy. This will be better ![]() ![]() ![]() ![]() ![]() Module for lighting, fans and other applications ![]() ![]() This will be a lot of work, but a very exciting thing to do. The first change that I'm going to do is swap the Nvidia GTX555 for two GPUs Nvidia has sent me. Again thank you Nvidia ![]() For sending me two Nvidia GTX680's Engine Specs: - CUDA Cores: 1536 - Base Clock: 1006 - Boost Clock: 1058 - Texture Fill Rate: 128.8 - Memory Speed: 6.0 Gbps - Standard Memory Config: 2048MB - Memory Interface Width: 256-bit GDDR5 - Memory Bandwidth (GB/sec): 192.2 Unboxing again ![]() ![]() ![]() ![]() The beautiful GPU's ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() with one Dual Link DVI-I, one Dual Link DVI-D, one HDMI and one DisplayPort ![]() And installed the new GPU's ![]()
#2 |
Modding and coffee
And now it is time for some modding
![]() First a window in the Alienware Aurora. And maybe two, one on both sides. But this is for later... first one. The sidepanel ![]() ![]() Contacts for lighting has to be kept in mind ![]() And the shapes / curves must be maintained ![]() Everything is pretty easy to disassemble. Black panel removed and drawn the line for cutting ![]() ![]() Disassambled the remaining parts ![]() ![]() RGB strip for color effects ![]() Detached the Acrylic carefully ![]() ![]() What's left...a piece of iron ![]() This is what we gonna use for cutting the window in the plastic panel ![]() After some sawing and filing ![]() ![]() Excess plastic also removed with my dremel to place the window (later) ![]() first fit ![]() Next step. We use the jigsaw ![]() Removed the reinforcement strip and drawned the hole slightly larger than the window in the plastic panel ![]() And saw it (and some filling of course) ![]() The points which seem to be thin will be reinforced ![]() Furthermore, it's still a strong frame ![]() And placed everything back. The gap inside between the plastic and iron needs to be filled ![]() And the window is almost finished ![]() ![]() A big start topic with a lot of pics and vids, but hope you like it. Until the next update!!! Grtz. Kier Last edited by kier; 27th Oct 2012 at 17:17. |
#3 |
Supermodder
Nice kier, this will be epic
__________________
***gtek-computerdesign.com*** |
#4 |
www.^.nl
Really curious where this is going Richard
![]() Congrats on the cooperation with Dell and Nvidia!
__________________
Preparing: Raz3r D3sk Running : L3p Parvum Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk Sites: www.l3p.nl - www.redharbinger.com |
#5 |
Minimodder
Great start!
#6 | |
Modding and coffee
Thank you Gtek
#7 |
Professional Sleever & Modder
Looks great Kier!
#8 |
Multimodder
Wow! So cool already. Looking forward to seeing this. KayinBlack's log has been awesome, so these cases seem like they will yield some cool results.
__________________
Project Carbon Apple |
#9 |
I Endure
Careful what you do with that name, apparently it's a summoning spell.
Great start, let me know if you run into any problems, I've got my Area-51 case able to do just about everything short of walk the dog now. I've been able to get the ESA working with third-party boards, as well as getting GPU clocks tied into the deal. When you get into cable management, have fun with that nightmare. Also, if you'll pull the PSU I can tell you if it's a straight swap with the 1100W Delta that came in mine. I can also show you where to get those dirt cheap, if need be. |
#10 |
Avoiding the "I guess.." since 2004
Oh gawd the metal parts of that case look so rubbish...
Good luck with that one!
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2 |
#11 | |
still thinking....
![]() It's looking better already with that window cut. Good luck.
__________________
stillthinking |
#12 | ||||
Modding and coffee
Thanks
![]() Quote:
#13 |
Supermodder
Pure awesomeness! I'm very excited about this mod. Sub'd inmediately
__________________
Current projects: Graphite 5 | Tydirium is on the way! Previous mods:|Sandcrawler Mod| |Illuminated Mind| Follow me on Facebook |
#14 |
I Mod, Therefore I Own
Huzzah! Another build by Kier to drool over
__________________
ZiiP Gamestore [ZiiP] Gaming Community - IW BlackMailers and loonies abound! Sui Generis: i7 920, Corsair H50, 6GB Dominator C7 1600, EVGA x58 SLI LE, Corsair F3 120GB SSD, Samsung F3, Sapphire 5870 Vapor-X, Corsair HX850W, Corsair Obsidian 800D, Iiyama 26" Prolite, Logitech G15, Logitech G5, Sennheiser PC350. |
#15 |
Supermodder
The design of the sidepanel is fit perfect with the case very nice Kier. Looking forward to the next update.
__________________
Completed Projects: Cooler Master Silencio 550 Limited Edidtion Project White, Black Obsession, Project Umbrella |
#16 |
*learning english*
after hours of new XCOM i'll shoot it if it moves
![]() interesting mod! i'll watch!!!
__________________
10 re-plan "SuperBestBuild Of My Dream" 20 have a sleep 30 goto 10 |
#17 | ||
Modding and coffee
![]() After this on vacation ![]() Quote:
Shoot my Alien ??? |
#18 |
*learning english*
__________________
#19 |
dat steak
Definitely looking forwards to this!
#20 |
Modding and coffee
![]() Thanks |
| Thread Tools | |
| View Mode | |
