Reply
Thread Tools View Mode
Old 2nd Nov 2012, 17:52   #21
pascal1973
What's a Dremel?
pascal1973 has yet to learn the way of the Dremel
Another awesome build......
pascal1973 is offline   Reply With Quote
Old 3rd Nov 2012, 20:23   #22
kier
kier's Avatar
kier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for president
Thanks Pascal
Update!!!
After playing some games and testing it was time to strip the case.
First the wiring, which is quite a lot in this case. But quite logical because all the gadgets.
PCB and a lot of cables for the lights
The PCB strip at the top for lighting and power pump
2 of these for the lighting behind the HDD bays
And some more cables
After all cables are removed, This is what's left ... for illumination
Also removed the Alienware mobo. Rams will by provided with black ram coolers later on.
Fan bracket for the swap bay
And the fanbracket for the GPU's
The HDD bays are easy to disassemble with screwdriver
Putting the SSD away for later
CPU cooler remains a beautiful item, so as previously mentioned this will be used again in this build later
Removed the midplate.
And mobo tray
Still dismanteling with only a screwdriver Also removed the PSU
Later on this will be black
And the cables which will be a challenge regarding the sleeve job
And removed the covers
Everything is stripped, so this is what's left
Time to think and mod. The idea is to put 2x 360 rads for the GPUs
This is not possible in the original case. Therefore I'am gonna raise the case using an old LL case where I have shortened the vertical bars and put it back together.
Mounted the Alienware Aurora on top and made a bracket around the lower part​. Because the lower case is smaller I had some space for the HDD cage to place it in the empty space.
For the sides I have cut a piece of aluminum and bent the curves in it.
Bent everything in the shapes of the lower strip on the existing side panel. This strip is where the new cover is going to be mounted on.
Done both sides and front.
After this cut out the radiators
All assembled and stick together with tape
Shiny
Made the covers black
And the end result after some sawing, filing, drilling, bending and pasting.
The Alienware Aurora XL version
__________________
kier is offline   Reply With Quote
Old 3rd Nov 2012, 20:27   #23
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Cool idea-looks great mate.
Pranja is offline   Reply With Quote
Old 4th Nov 2012, 03:48   #24
PcJunkie209
Multimodder
PcJunkie209 has yet to learn the way of the Dremel
Looking good Bro!
PcJunkie209 is offline   Reply With Quote
Old 4th Nov 2012, 06:08   #25
craig - toyoracer
Supermodder
craig - toyoracer's Avatar
craig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysis
The new window is a great improvement and nice work on the rad base extension.
Good luck and hope you have fun, as there is lots of work ahead to transform this case into something great.
__________________
octTower
Electrocutous Orchid
craig - toyoracer is offline   Reply With Quote
Old 4th Nov 2012, 07:14   #26
kier
kier's Avatar
Thanks
Originally Posted by PcJunkie209 View Post
Looking good Bro!
Thank you Craig. And yes a lot of work but i like it
__________________
Old 4th Nov 2012, 13:35   #27
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Looking good Richard !
k.3nny is offline   Reply With Quote
Old 5th Nov 2012, 08:17   #28
KayinBlack
Toxophile
KayinBlack's Avatar
KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.
Yeah, that's the same PSU. I also know where to get spare wiring looms if you need it.
Good stuff so far, it'll be interesting to see what you do with yours!
__________________
I don't feed the trolls...
PC: Intel i7-4830K, ASUS X79 Deluxe, 64GB GEiL Golden Dragon 1333MHz RAM, EVGA nVidia Titan Black 6GB Hydro Copper, Blu-Ray burner, 4x250GB Samsung 840 EVO in RAID 10, Corsair AX860i.
KayinBlack is offline   Reply With Quote
Old 5th Nov 2012, 08:27   #29
dreps
Multimodder
dreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremel
looking great so far. lets see what you are gonna do with this beauty
dreps is offline   Reply With Quote
Old 5th Nov 2012, 18:01   #30
Owndapwn
Modder
Owndapwn's Avatar
Owndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run Crysis
Good modding, but why would you buy an Alienware. :|
Owndapwn is offline   Reply With Quote
Old 5th Nov 2012, 18:14   #31
kier
kier's Avatar
Thanks Ken
Ill keep in mind, thanks
thanks
Why not
__________________
Old 6th Nov 2012, 18:39   #32
Owndapwn
Modder
Owndapwn's Avatar
Originally Posted by kier View Post
Why not
Horrible price to performance, a record of parts failing, a very significant overheating rate, a rather poor case internally, the stigma associated with owning an Alienware, and the part where it's a $600 dell with LED's, a $40 presealed watercooler prone to pump failures and leaks, and an outdated $200 graphics card that they charge upwards of $1100 for.
Old 6th Nov 2012, 19:06   #33
l3p
www.^.nl
l3p's Avatar
l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.l3p is the Cheesecake. Relix smiles down upon them.
Who cares ... it's about modding the hell out of that thing (And I'm sure Richard will!)
Also ... I don't think he bought it ... he got the awesome honor to mod it.
__________________
Finished Projects: : www.l3p.nl
Follow me daily: www.fb.com/l3p.nl
l3p is offline   Reply With Quote
Old 6th Nov 2012, 19:49   #34
Owndapwn
Modder
Owndapwn's Avatar
Don't get me wrong, the modding looks great so far, but as a computer, Alienware is utter rubbish, and that's not really debatable.
They're an absolute waste of money.
It's like buying a Mac (Whose only good side is the OS) and replacing OS X with Linux.
Absolute waste when you can build something better for half the price.
If they gave it to him free, then disregard.
But if he paid full price for one...
Especially when you could have Checked ebay and built a PC inside.
Old 6th Nov 2012, 19:55   #35
Pranja
Blackwolf
Pranja's Avatar
OMG, stop spamming all threads here. He is sponsored by Dell with this computer,dude!
If you are not interested in computers,computer hardware and modding you are on wrong forum.
Old 6th Nov 2012, 20:02   #36
sixfootsideburns
modeteer
sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.
For an individual with only 36 posts when this was written, I think your getting off on the wrong foot mate. Try constructive critisism before you say anything remotely close to flaming
Looking sweet so far Kier, asthetically I think this case has serious potential
sixfootsideburns is offline   Reply With Quote
Old 6th Nov 2012, 20:08   #37
Owndapwn
Modder
Owndapwn's Avatar
I've been building PC's for a long time, and have been an active and respected member on many forums.
This forum seems to love horribly unbalanced builds so much, they're willing to insult their betters over something that can't be debated.
Part X received score Y in Benchmark A and is available for price D.
Part Z received score Y in Benchmark A and is available for 40% less than part X.
Bring that up, and suddenly it's flaming.
Old 6th Nov 2012, 20:12   #38
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for president
Weird, I thought this was a CASE MOD on a CASE MODDING forum... NOT a hardware forum... There's a different one for that
Unless the hardware is modded, or an integral design element, I couldn't care less what hardware is in a case mod...
I really like this case, and can't wait to see it finished. Progress looks great so far
Mosquito is offline   Reply With Quote
Old 6th Nov 2012, 23:32   #39
barry99705
sudo rm -Rf /
barry99705's Avatar
barry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyanbarry99705 is a Super Spamming Saiyan
For someone with no build logs on this forum, that's debatable.
__________________
It sounds simple, but there will be wires and lube everywhere, like some kind of Japanese porno. --Cheapskate
Crap I've built/building
barry99705 is offline   Reply With Quote
Old 6th Nov 2012, 23:47   #40
spigs_rex
Multimodder
spigs_rex has yet to learn the way of the Dremel
computer porn anyone?
very cool, is a mean looking case. would'nt gone for alienware case tho, there prone to spontaneous outbersts of decompression, creating a blackhole/supernova type phenomenon on ur desk bench
spigs_rex is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
