Reply
Thread Tools View Mode
Old 16th Dec 2012, 18:09   #61
kier
kier's Avatar
kier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for presidentkier should be considered for president
Alienware Aurora ALX-XL is sponsored by:
Update!!!
To start with I have placed the EK bayres to see how it looks
Installing the pump onto the bayres
Small tutorial about this
Time for the Nvidia GTX680
Also made a tut for placing the EK-FC680 onto the Nvidia GTX680
Don't wanna see the vid!!! Thank god we still have pictures
Removed the plastic
Also removed the block
Dismantled the bracket
The EK block
[IMG]http://i759.photobucket.com/albums/xx233/kier1976/NEW/Alienware/A3/EKWB/DSC09755.jpg[IMG]
First cleaning up the GPU
Placed pads and compound
Mounted the EK block
Also installed the EK-FC link
And backplate
Second GPU finished
Connected all together with the EK-FC Bridge Dual Serial
And offcourse....placed it right away
Made a minor adjustment into the CPU cooler. Placed LEDs for a nice effect, bright Alien eyes
I was still searching regards the radiator recesses on both sides. Here's the first idea.
Playing with some mesh and air outlets
But no...didn't like this.
So cut an aluminium strip, bended a lot of vents and assembled
Made it black
Next ..... The Nvidia Logo should come back. Therefore I made ​​a little cover where the Nvidia logo is displayed.
Like this
Frosted the piece
Just to see how it will look I cut out the name by hand.
This is NOT the final logo, soon there will be a better one (with Nvidia claw)
To give this a bright shine, I have used a piece of glowpad
Placed a small piece
For the cables, I cut out a recess
This will no longer be seen through the cover
And another recess for the remaining connections mobo
And a recess for the GPU power. Bottom PCI-e power is tight, but possible
And last... Busy again with acrylic tube
After some measuring, Made 2 holes ​​for the fill ports
That's it for this weekend To be continued!
__________________
kier is offline   Reply With Quote
Old 16th Dec 2012, 19:59   #62
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
Looks awesome!
Can't wait to see it finished.
elAwesome is offline   Reply With Quote
Old 16th Dec 2012, 22:07   #63
kier
kier's Avatar
Thanks
__________________
Old 17th Dec 2012, 02:09   #64
siliconfanatic
Johny-come-Lately
siliconfanatic's Avatar
siliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyan
lookin good! subtle modding, seems more like its just been cleaned up. takeing a design and enhancing it w/out changing it too much! i like!
__________________
Do not let anything good in life pass you by. Cherish it with all of your heart, because before you know it even life will have passed you by. And if you let all those things pass you by? The only thing filling your heart will be deep sadness and regret. So whatever you do, hold on, and never let go.
siliconfanatic is offline   Reply With Quote
Old 17th Dec 2012, 15:46   #65
matiss
Multimodder
matiss's Avatar
matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.
Wheres kier on the outside theres awesomeness inside
matiss is offline   Reply With Quote
Old 17th Dec 2012, 16:45   #66
kier
kier's Avatar
Thanks that was the hole idea, like the Alienware shapes allready. only thing is to clean up the place
Thank you
__________________
Old 17th Dec 2012, 17:19   #67
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
This is looking superb! I thought the rad vents looked really good without getting painted, but then again i do have naked metal fetish...
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 17th Dec 2012, 17:25   #68
kier
kier's Avatar
Lol thats the first time ive heard that one...Naked metal fetish, me like. Thanks
__________________
Old 2nd Jan 2013, 17:02   #69
TheNr24
What's a Dremel?
TheNr24 has yet to learn the way of the Dremel
OMG SWEEEET Kier does it again!! Improving on the looks of this already badass looking case is impressive!
I seriously can't believe they don't powdercoat the inside of the case themselves though, I thought that was pretty standard on high-end (gaming) cases nowadays?
And the leds in the eyes, the reversed tubes on the stock cooler, the cable cover, brilliant but they should've thought of that! On the one hand they go to extremes to light the inside up (some pretty clever stuff on that end, especially the lighting up of the connectors on the back of the case, so handy!) but then they make it so you'll never want to look inside.. (dat cable management )
To be honest, I think Alienware is just secretly using you as their designer, I wouldn't be surprised if they released an AURORA II exactly like yours when you're done fixing this one. Hahaha
At least that's what they should do, it would certainly help to justify their pricing.
Btw, ekwb does some amazing design, damn, even their packaging is gorgeous.
About time for an update though, don't you think. on a related note, how's Danbo doing an update to that thread would be most welcomed as well!
TheNr24 is offline   Reply With Quote
Old 4th Jan 2013, 23:00   #70
kier
kier's Avatar
thank you for your kind words.
At this moment the alienware is beeing poadercoated
I hope they will use some ideas in there next design
About Danbo....he's still alive and standing right next to me, waiting to be finished
Soon!!!
__________________
Old 4th Jan 2013, 23:26   #71
Si_the-dude
Techaholics Anonymous. 0 days clean
Si_the-dude's Avatar
Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.
Absolutely amazing dude! Total computer porn! LOL
__________________
Delidded i7 4770k @ 4.7- Custom EK loop with 360mm and 240mm rads - Watercooled GTX Titan SLI - Gigabyte G1 Sniper M5 - Corsair Vengeance 16gb with EK block - Monsoon Fittings - Phanteks Enthoo Primo - Dell U2713HM
Si_the-dude is offline   Reply With Quote
Old 5th Jan 2013, 03:17   #72
siliconfanatic
Johny-come-Lately
*cough*update*cough*
*whistles innocently*
__________________
Old 5th Jan 2013, 15:24   #73
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Challenging internals & your doing a very sweet job of it, I expect this one has been quite a fun challenge.
Lot of nice touches in this Kier.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 27th Jan 2013, 20:45   #74
kier
kier's Avatar
Update!!!
It took a while but here is a new update of the Alienware Aurora. After some doubt what I would do, paint or powder coating I decided to do it myself.
purchased a number of cans primer and Black.
Put the primer on
Let it dry for a night and then applied several layers of black
And again, hung to dry. Looks good i think
Internal also used some black for the heatsink and other small stuff ... still need to exchange the connectors
Always fun to play with Alien eyes
I also gave the midplate a black layer. This to get a illuminated green border using a CCFL. I first made the top ​​white, after that a black layer
Placed the CCFL
Time to place the PCB for the lighting etc. For this I have cut a aluminum plate
Placed like this
After extending some cables
Power on for testing
And it's working again
Always good to know before the cable management begins
Searched and found my sleeve stuff again for sleeving the big bundle
I discovered that the pins of the big block are not so easily to remove. 've Tried al kind of tools, but it isnt possible without demolishing. I just miss the slots for the pin remover.
So change of plans ... going to use sleeved extenions now. Sorry no sleeve update this time
I also did the lower back. Because I made ​​the Aurora a bit higher, I also need to extend the back.
For this cut, bent and drilled an aluminum plate
Cut and bent another aluminum plate
First plate mounted on the existing PSU cover
And made the other plate black and mounted it. Must still bend it a bit and still make some openings with mesh in it..I think, but this is how it fits.
Finally the choice of the fans for the rads. The Scythe SY1212SL12H ... pretty thin fans but very noisy.
definitely need some adjusments
More coming up!!!
__________________
Old 27th Jan 2013, 21:09   #75
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Nice update Kier.
I am waiting for more.
Pranja is offline   Reply With Quote
Old 28th Jan 2013, 01:13   #76
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
have you tried to remove the pins from the backside ?? they must be removable somehow :O!, if not do this:
Step 1:
Cut the cable leaving it some 3-5cm slack of wire
Step 2:
strip all the wires
step 3:
Crip the cables from the 24pin cable with male pins and attach it to a male 24pin housing, do the opposit with the special connector cable
Ready to sleeve!
KoSoVaR^ is offline   Reply With Quote
Old 28th Jan 2013, 02:18   #77
KayinBlack
Terminal is a state of mind
KayinBlack's Avatar
KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.
I was able to sleeve mine pretty well, though I'm redoing for this set of connectors that's going inline. barring a few double and triple crimps, you can get down to the connector end for almost everything. I'm putting in a midplate in my setup so you can't see the ones you can't anyway.
__________________
I don't feed the trolls...
PC: Intel i7-4830K, ASUS X79 Deluxe, 64GB GEiL Golden Dragon 1333MHz RAM, EVGA nVidia Titan Black 6GB Hydro Copper, Blu-Ray burner, 4x250GB Samsung 840 EVO in RAID 10, Corsair AX860i.
KayinBlack is offline   Reply With Quote
Old 28th Jan 2013, 04:21   #78
siliconfanatic
Johny-come-Lately
Nice to see your still alive, kier! But always chech here 'fore ya call it quits+ move on
__________________
Old 28th Jan 2013, 12:16   #79
kier
kier's Avatar
Originally Posted by Pranja View Post
Nice update Kier.
Thanks!
Step 1:
Step 2:
strip all the wires
step 3:
Ready to sleeve!
Thanks you, but i allready ordered the extensions...no excuse i know
Did you remove them from the backside, like KoSoVaR said? i really couldnt disconnect the pins from the front.
Still alive yes, very busy with other mods...also coming up soon
__________________
Old 28th Jan 2013, 12:35   #80
Ace_finland
Multimodder
Ace_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for presidentAce_finland should be considered for president
Great modding there kier, turning out much better than i thought it would be! Is the green nvidia logo made with an el-panel? looked like one but i wasn't sure. If so how big are the inverters to get it to ac current?
Ace_finland is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
