#101 | |
There is no rep for awesomeness.
Moderator
Dude, you gave your unrestrained opinion and then you found that you had to apologise for sounding a bit rude and conceited. Now you're going for round two? We know what you think of Alienware by now. Let it go. This is about the modding.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust |
#102 | |||
Modder
From what I've seen, no one disagrees with you.
Which is exactly why no one wants to see that cooler burst. Granted, when these stats were pulled (By a Dell CR rep just before leaving the company), the year was 2009, so maybe they've fixed it. I had to service one that had the pump stop circulating water. Luckily he didn't get the overclock option, or else throttling and emergency shutdown would have been disabled. They are (or were) not quality water coolers. They're not worth defending. Quote:
All of what he said. Email updates and a smartphone that beeps when you get an email. Quote:
No way you sleeved non-modular cables that smoothly without performing some sort of sacrificial ritual. ![]() Teach us your secrets, oh great sleever of cables! Guide us to the path to OCD peace and prosperity! Quote:
Or those sombreros with the bells and stuff on them. Anyways, I'm not going for round two. My replies have offered significant advice (It's advisable to not spill fluids on expensive electronics, or put them at undue risk of being fluided on. GTX 680's aren't cheap.) or contributed positively. ("This is how the case should have been from the beginning.") |
#103 |
Car lover and Speed Junkie
Well, on the bright side of this debate, this thread got boosted to page six!
![]() And yay cablemanagement! ![]() @owndapwn, smartphones just aren't worth it imho. They're one heeeeeeeyuuuuge gimmick full of more gimmicks. I text alot, yes, but the screens are'nt big enough and the apps are free but if your not cautious you'll wind up broke! and my email has become a spambox to the point where im getting spam faster'n i can mark it as such and I'm sub'd to too many threads to put in my yahoo account anyway that's for another thread..
__________________
![]() I *am* the guy who loves too many threads to bump them all. Last edited by siliconfanatic; 2nd Feb 2013 at 15:53. |
#104 | ||
Moderator
Expressing concerns about the cooling system is great. Saying that you don't like Alienware is fine. Harping on about how it's poop crosses the line from honest opinion to self-important asshole just a little bit. Don't be that guy. Be the mellow guy. The guy who wears the cool cowboy hat.
__________________
#105 |
Modding and coffee
Alienware Aurora ALX-XL is sponsored by:
![]() ![]() ![]() Update!!! The end is almost in sight. Recent weeks i've done a lot on the Alienware Aurora R4 Because the sleeving didnt go easy with the large connector I used extensions. It is certainly not MDPC sleeve, but it's not too bad Lower GPU power connected ![]() ![]() And another ![]() ![]() One more ![]() And the last one ![]() ![]() Some straightening and pulling ![]() Looks nice ![]() 24 pins also some shapening ![]() ![]() ![]() You've probably saw some pictures pass by with the the tubes, but here everything is connected. This time with 12/10mm tubing Finally I found them with the perfect size (thanks E22 Nate). Only thing to do is to file a little edge off the tubes just like the crystal links. ![]() ![]() ![]() ![]() ![]() Was a lot of work, but here one pic of the other side finished lol ![]() Time to fill her up and leak testing. Optical drive removed and fill the bayres. ![]() After some noise...it became quit ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And then it was dark ... Lights on please!!! Oww almost forgot, the midplate: I've got the whole plate illuminated using a green ccfl bar for one half. And the other half (left) I've used a glowpad. The PSU cage would otherwise cause a dark spot ... not now ![]() ![]() ![]() And power on!!!. Because the side panel is off, 3 white LEDs are shining at the top, which shows the internal ![]() ![]() Leds off ![]() Default color is green, but all original color options are possible ![]() Front is looking very nice ![]() And lights back on. Some pictures with daylight and the panels installed ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Still some minor work to be done, such as the Nvidia GPU sticker on the cover, acrylic window and so on. Next time Cheers!
#106 |
Fenrir The Wolf
Very nice. Great job!
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
#107 |
Supermodder
ooh, havent watched this log in a while, and now it's almost done... '-_-
Really good craftmanship kier, high class as usual
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#108 |
Supermodder
DELL!
Take note!
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb Coolermaster 600w Silent Pro Modded Lian Li PC-0700 |
#109 |
Bliiiiiiiiiiiiiiiinded by the liiight!
Loop just got filled with awesomesauce ![]() Are you gonna keep it as-is mostly, or pull off some kier acrylic pipe power of pine-sol magic trick on the cpu block? Thats what you've got! The power 'o pine-sol, baby!
__________________
![]() I *am* the guy who loves too many threads to bump them all. Last edited by siliconfanatic; 19th Feb 2013 at 00:04. |
#110 |
Modder
I feel that if Alienware ever wants to boost their sale, they will probably come after you Kier to do their next on display model
seriously what you have done so far has made the computer all the more desirable, and probably made me think again of getting an alienware product (not a hater, just not a fan of the price tag ) anways, Im kind of bummed that the second tubing covers the Nvidia logo on the GPUs, I really liked that logo :3
__________________
Current Rig: i7 920 oc @ 3.5 GHZ, Evga X58 SLI FTW3, 24 Gb G Skill Sniper Ram @ 1600 Mhz Evga 670 GTX FTW SLI Need to build something new soon... I'm thirsting for a new build
#111 |
Tech-Kid
Not a big fan of alienware (and Dell by that matter), but I like this. Interested in seeing more
#113 |
Multimodder
kier, thank you very much for the tutorial of how to install the GPU water block! That really helped me a lot
![]() And I must say that this is an absolutely outstanding build!! I love every detail of it! |
#114 | |||||
Modding and coffee
Thanks
![]() ![]() Quote:
earn some money with it. there will be another beter logo and will be visible all the way Quote:
![]() Just the way i like it too Quote:
#115 |
Modding and coffee
![]() ![]() ![]() Update!!! This is it ... he's finished. Last work is done and now only the final photo shoot. Then he (temporarily) returns to Alienware. For the demo room and events ... so maybe you'll see it again live somewhere Window was one of the last things that must be done, so I have adjusted the original cover a bit more unnecessary plastic removed ![]() ![]() Cut a piece of acrylic. ![]() And installed ![]() ![]() ![]() ![]() ![]() ![]() ![]() The vinyl stickers were in and looks very nice. They gave my some more pieces to try it out. Letterop Advertising thank you very much for this. ![]() ![]() ![]() ![]() Applied and tested the light ![]() ![]() ![]() ![]() ![]() ![]() And the Alienware Aurora ALX-XL connected ![]() Crysis 3 installed ![]() ![]() ![]() Last update will be the final photo shoot and maybe a nice vid ... until then! |
#116 |
Fenrir The Wolf
Wow-sexy pc.
__________________
#117 |
MD of Mutant Zombie Armies Inc
Outstanding. A very evil green machine... muwah ha ha ha haaaaaaa!
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts. |
#118 |
Hackintosher
That mid plate is such an amazing piece of craftsmanship. Great work.
#119 |
Modder
oh my.... oh my... oh my.... oh my... (this went on for an hour as I kept at looking at that logo) yep, I def agree with you having a better logo... damn so that is the product of putting vinyl over plexiglass?
__________________
#120 |
Multimodder
so clean!
love it
| Thread Tools | |
| View Mode | |
