Reply
Thread Tools View Mode
Old 28th Oct 2012, 12:09   #1
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for president
Corsair c70 "Planetside2's New Conglomerate" Case Mod, VIDEO Update
I was very excited to receive an inquiry from Planetside2's Creative Director at SONY, Matt Higby, about doing a New Conglomerate theme case mod for his new PC build. I've loved creating weathered Sci-Fi & Military themes over past year and Matt really liked what I was doing...
"PLanetside2" is the sequel to the landmark MMO FPS has been revealed and is bigger and better than ever. PlanetSide 2 is a massive multiplayer online first person shooter. Game play delivers truly epic combat on a scale never before seen in stunning, breathtaking detail. Battles wage with literally thousands of players aligning with one of three unique factions in intense land, air and vehicle gameplay where the fight for territory is more than a victory, its survival. The "New Conglomerate"(commonly abbreviated NC) is Matt Higby's favorite faction. The NC is one of three empires waging for control over the planet Auraxis. They are characterized by hard-hitting weapons and heavily-armored vehicles that are designed with straight lines and hard edges. Their faction colors are blue and yellow.
Matt will be utilizing Corsair's H100 CPU cooler for the best optimal cooling. I will be creating a unique cooling fan intake. I want to simulate hydraulic lines connecting to the sides that look hydraulic hoses and using the 120mm LEPA Chopper LED Cooling fan.. Newegg.com - LEPA Chopper (LPCP12N-BL) 120mm Blue LED Case Fan
120mm Overkill Fan Rings Link, 120mm Overkill Fan Grills
The New Conglomerate Badge will be on the right side panel. Instead of just painting it on the panel, how about a Three Dimensional version? Hell Yeah! So I surveyed my pile of acrylic.. I got some Transparent Blue and Clear. No Yellow, but I can always paint it! All of the acrylic I'm using is Cast Acrylic, 1/8" thick. I printed out the logo, cut it, and traced around it, onto a 12" x 12" sheet of Clear acrylic.
I used the Vertical saw to cut the traced pieces from the acrylic sheets.
Cutting notches in the wingspan.
Refining and defining the cuts with Hand File.
Detailing the star, from the center of the logo.
I'm debating about implementing some metal into the piece as well... Maybe mount the logo on metal shield...
The c70 stock bezel lacked depth..
so I Franken-modded a new fascia from a Lancool bezel
then remove this restrictive grill from stock c70 bezel....
Bezel and entire chassis was given a fresh Metallic Blue finish... (only to be destroyed later?)
The front intake is given industrial look with power outlet box from Home Depot
meanwhile, Sun Flower Yellow paint cures
A side panel shield for the NC logo is created from CF-1009 case panel
I mounted the New Conglomerate shield onto the left side panel. I used socket head fasteners. This afternoon I'll start hand painting everything with distressed and weathered paint effects. Matt made it clear that he wanted the surfaces to look weathered. He sent images of the NC soldiers for inspiration.
Under the guidance of Mnpctech's painter Brad Galvin, I learned a new weathering technique,
Water Drop Masking: "Distressed & Weathered Look"
1. Spray entire surface with Water Spray Bottle
2. Use Airbrush over water drops with Enamel Paint
3. Allow to dry 1 minute
4. Use Paper Towel and Dab up the water, Don't Wipe!
Distressing the Yellow striping, similar to the NC Soldier's armor, I used combination of 80 grit sandpaper, wire brush and Red scotchbrite pads. I use Scotch 233+ Masking tape
Here is the bezel after the effects were made to the paint...
The floor intake and rear exhaust fans will have these custom "New Conglomerate" logo inspired fan grills laser cut by Mnpctech and designed by fellow modder, E.E.L. Ambiense!
These were laser cut from 1/8" thick Blue transparent cast acrylic sheets.
btw, Mnpctech doesn't offer Laser Cutting, but bit-tech member, Furball zen's business PCModul.us offers Laser Cutting to Modders!
Turbine Front Intake is installed. I envisioned something evocative of heavy duty power equipment, with lines connecting to the sides that look hydraulic hoses.
For the Corsair's H100 radiator, I'm using two 120mm Modders Mesh fan grills for the custom 240 machined aluminum grill. Here are the steps I took in painting them to match the grill frame.
I'm using 3M RED Scotchbrite hand pads for cleaning and scuffing the grills for a primer base coat.
For the Primer coat, I used RUST-OLEUM Enamel Primer. It's available from Home Depot or LOWES, in Black, Red or Grey color. I used Black
After the RUST-OLEUM Primer has cured for 30 minutes, I applied the color coat, which is Plastikote's Engine Enamel, #207, Aluminum. Manufacturer Page here, Engine Enamel:Specialty | PlastiKote Paint Products
Ending results are a very good color match to the actual aluminum grill frame.
I'm giving the 2x120mm radiator grill a more detailed look with simulated armored plates. I made these piece from 1/8" thick clear acrylic sheet that I will paint in matching Metallic Blue and airbrush with weathered effects. It will also have simulated vents made from Round Modders Mesh
I used my Vertical saw to cut the basic shapes from the acrylic.
I used a Rotary Tool with cutting wheel to cut the center for the mesh backing
I'm using airbrush to add weathered effects on the top H100 radiator grill with Iwata HP-CH airbrush gun with Black Enamel paint.
Bare exposed steel effect added...
I've created some bullet holes, for the past year I've been mentored by Brad in "The ways of the airbrush"...I had done bullets with templates in the past on BF3 case mod, but this time I went freehand using Silver and Black Enamel paint.
There is a lot of different DIY techniques for creating bullet holes with an airbrush, you can use templates that you make make yourself with construction paper...don't waste your money on retail templates...
Don Johnson has a decent video tutorial to creating bullet holes on YouTube
and another DIY airbrushing guide to creating bullet holes
I can't leave the ASUS Blu-Ray drive face stock! Esp after defacing and distressing everything else....lol. ...My video tutorial shares all of the steps in painting your Optical drive face, you can apply these same steps in painting any plastics..
Following the DIY steps in the link I shared above, I painted the drive face the Metallic Blue I applied to the exterior and interior of the case.
I applied 1/4" Auto Body Masking Tape, side by side, only cause it was only thin tape I had on hand... in diagonal pattern after the Metallic Blue Lacquer paint had cured for 1 hour...
I applied Matte Black Lacquer paint....
After 30 minutes, I removed the 1/4" masking tape..
Lacquer paint cures pretty fast... 30 minutes later I covered the Matte Black with same tape again.
Next, I applied combination very light coats of Gloss Orange and Metallic Gold paint
After 15 minutes, I used a wire brush to create scratches to simulate heavy usage of time...
Using Red / Maroon Scotchbrite Pad to smooth and mute down the scratches
Next stage is installing the Blu-Ray, and Thank you for watching
mnpctech is offline   Reply With Quote
Old 28th Oct 2012, 12:47   #2
Phame
CNC mad!
Phame's Avatar
Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!
Nice man, it looks so sick! Good luck
__________________
'You had my curiosity, now you have my attention'
Work in the pipeline *Server*
Completed Projects. *Orange and Black* and *The Wet Pi*
Phame is offline   Reply With Quote
Old 28th Oct 2012, 16:08   #3
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
The whole case is already insane Bill! Really inspirational especially the front!
__________________
Current projects: Tydirium is on the way!
Previous mods: |Sandcrawler Mod| |Illuminated Mind| |Graphite5|
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 28th Oct 2012, 16:50   #4
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
Awesome job Bill. Another great mod to follow.
But I am kind of sad because you painted bullet holes-remembering your previous work, i expected from this holes to be real.
But,excellent job anyway.
__________________
Cosmos S Reaper L.R.E.C. Scorpio
Arya-under construction ROG Crawler-under construction
Pranja is offline   Reply With Quote
Old 28th Oct 2012, 19:11   #5
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
AciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run Crysis
DUDE!! Your cuts are so clean and the paint job is awesome
Edit: LOL I didn't see WHO it was that was doing that mod... Your work is awesome as always
AciD_RaiN is offline   Reply With Quote
Old 29th Oct 2012, 06:09   #6
KrunchR
Supermodder
KrunchR's Avatar
KrunchR has yet to learn the way of the Dremel
Awesome work as usual, Bill. The said panel from the cf-1009 is cool looking.
KrunchR is online now   Reply With Quote
Old 29th Oct 2012, 07:58   #7
Balder
Calmer than a monk on morphine
Balder's Avatar
Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.
Another good Monday morning, this is looking awesome as always Bill!
__________________
All progress is precarious, and the solution of one problem brings us face to face with another problem.
- Martin Luther King, Jr.
Balder is offline   Reply With Quote
Old 29th Oct 2012, 08:06   #8
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Woo hoooo, new MNPCTech project.
Kinda hard to comment on your logs when you cram so much awesosmeness into a single post, so much to comment on that even just commenting on all the awesome bits would look like a big ramble.
Complete package modding using heaps of different approaches = sheer awesomeness.
Waynio is offline   Reply With Quote
Old 29th Oct 2012, 10:38   #9
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
oh man. Another epic mod. + sub
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 29th Oct 2012, 15:22   #10
RedManc
Supermodder
RedManc's Avatar
RedManc has yet to learn the way of the DremelRedManc has yet to learn the way of the Dremel
Nice work Bill & Co!
Shame about the theme as NC are nothing but trouble, - 10 points.
TR For Life!
__________________
RedManc is offline   Reply With Quote
Old 29th Oct 2012, 15:26   #11
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
Looking great as usual Bill. I do believe you've got the whole "weathered and beat up" look down to perfection.
I really like that front fan
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 29th Oct 2012, 23:46   #12
ModsofNorway
What's a Dremel?
ModsofNorway has yet to learn the way of the DremelModsofNorway has yet to learn the way of the Dremel
Banger project, Bill! Keep up the good work!!
ModsofNorway is offline   Reply With Quote
Old 31st Oct 2012, 10:37   #13
mnpctech
bit-tech sponsor
mnpctech's Avatar
@Phame, Thank you, should have final update soon, swamped this week
@nagyizom, Thanks!, I like it too, something different...hehe
@Pranja, good call, and last minute idea Thank you for comment
@AciD_RaiN, Thnx! and good set of Hand Files are great for making mistakes disappear
@KrunchR, Thanks for tuning in! indeed, EEL has complete case stashed in his garage
@Balder, Thanks for ongoing support dude! should have next update soon
@Waynio, haha, a bit of "cramming" indeed and I'm always honored when you comment
@Fuganater, Thank you for the comment and support shane!
@RedManc, I'm in neutral zone, just me and my tools & waving white flag &
@Mosquito, Thank you! ....almost time for mounting snow tires in MinnesotaH
@ModsofNorway, Thank you, and awesome screen name... love Norway!
Old 31st Oct 2012, 13:28   #14
Pranja
Fenrir The Wolf
Pranja's Avatar
So,you going to do that?
__________________
Old 31st Oct 2012, 14:52   #15
Mosquito
Hypermodder
Mosquito's Avatar
Unless it's anything like last winter... I don't have snow tires, I just rock the stock geolandars I've got on my Subi. Once the snow flies, I finally quit wearing shorts though
__________________
Mosquito
Old 31st Oct 2012, 15:08   #16
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
Nice work there Bill, as allways.
But seriously.... Why Planetside2? This game really doesn't deserve a case made by you !
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 31st Oct 2012, 15:21   #17
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
I love this one Bill, your weathering technique is just insanely realistic now... time to make millions selling pieces to pawn shops......
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 7th Nov 2012, 17:33   #18
mnpctech
bit-tech sponsor
mnpctech's Avatar
@Pranja, can I take rain check on that?
@Mosquito, NICE, btw, bit-tech member, roboduck is from Minnesota and suby owner too
@jrs77, paying gig...heh
@Editor22, Thank you! and still learning new these tricks
Old 7th Nov 2012, 17:54   #19
Fuganater
Supermodder
Fuganater's Avatar
That is just too awesome looking!
__________________
-Fugatech-mods-
-Facebook-
Old 7th Nov 2012, 18:06   #20
Pranja
Fenrir The Wolf
Pranja's Avatar
[/center]
Bill,you made me to google what "rain check" means.
It is your decision,not mine,I just gave an idea.
These last pictures are great. When I come home,they will find place next to Shini PC posters.
__________________
Reply
Tags
corsair case mod, h100 grill
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
