#1 |
What's a Dremel?
HTPC modding Cooler Master Elite 120
PC Components :
Case - Cooler Master Elite 120 Power Supply - Thermaltake TR2 RX 550W Motherboard - Gigabyte GA-Z77N-WIFI Processors - Intel Core i5-3570K Memory - Corsair Vengeance Blue 8GB (2x4GB) 1600MHz Video Card - Asus Radeon HD 7850 SSD - OCZ Agility 3 60 GB SATA III Fan – 2 x Scythe Gentle Typhoon 120mm 1200rpm Veris Multimedia Station Premium Water Cooling Component: Koolance CPU-370 (CPU) Koolance CHC-125 (MB) Koolance RAM-33 X 2 Koolance RP-401X2 Single 5.25" Reservoir Koolance Water Pump PMP-400 High-flow Pump Koolance Radiator, 1x120mm 20-FPI Copper Koolance Liquid Coolant ![]() http://www.youtube.com/watch?v=_bVwh...e=channel&list Cooler Master Elite 120 sound of the fan. A large microphone background 1 meters away nothing is heard ![]() http://www.youtube.com/watch?v=Ukmo9...hannel&list=UL Test LinX 0.64, CPUID HM Pro Original http://img-fotki.yandex.ru/get/6519/..._25a8bcf9_orig |
#2 |
What's a Dremel?
HTPC media center upgrade :
Video Card - Asus Radeon HD 7850 changed to ---> Gigabyte Radeon HD 7970 (GV-R797OC-3GD) ![]() modified / changed ![]() Added water block Koolance VID-AR797 (modified / changed) ![]() ![]() Koolance Radiator changed to ---> Alphacool NexXxoS XT45 x 2 units ![]() Also modified parts : Power Supply - Thermaltake TR2 RX changed to ---> OCZ ZT Series 550W SSD - OCZ Agility 3 60GB changed to ---> INTEL 330 SATA3 SSD 120GB ![]() ![]() Final (complete) results : ![]() ![]() ![]()
#3 |
What's a Dremel?
Next modification assembly Mediatheque (11 x 2TB USB HDD) assembly into a single casing
![]() Components : COOLER MASTER CM 4-IN-3 DEVICE MODULE 3X5.25"->4X3.5" x 4 units PSU ENERMAX LIBERTY ELT400AWT D-LINK DUB-H7 7-Port USB 2 Hub x 2 units As a HTPC media center no CD/DVD/BD player also assemble: ASUS SBC-06D2X-U EXTERNAL SLIM BLU-RAY ![]() Assemble discs ![]() Rebuild power supply unit (ENERMAX LIBERTY) ![]() ![]() ![]() A general view
#4 |
What's a Dremel?
Final Cooler Master Elite 120 and Mediatheque assembly into a single casing:
#5 |
Multimodder
WOOOOT! That's amazing! A lot of things in a very small space! I love it! It's a pitty that you can't see the inside of the case... ^^'
#6 |
modeteer
I don't mean to troll... but whats the point in putting that kind of hardware in an HTPC? And on top of that, why would you bother water cooling it? Just seems like a total waste to me.
#7 |
Hypermodder
#8 |
Multimodder
Don't forget you also get a way higher performance and for small lan party's it's quite good idea, hate to have in friends house somebody with a computer noisy as hell...
I really respect that build dude, to fit so much in so small space, got to try that someday myself :P (not the same way) im just thinking, would you have more benefit from shorter video card cause gigabytes cards are quite long...
__________________
Finished: -Mini-PC http://forums.bit-tech.net/showthread.php?t=248203 unfinished: none!
#9 | |
< Your add here >
#10 |
modeteer
#11 |
What's a Dremel?
#12 |
What's a Dremel?
Test results (URL original image size 1920x1080):
![]() http://img-fotki.yandex.ru/get/4604/..._fcced4b7_orig ![]() http://img-fotki.yandex.ru/get/6500/..._b717a8ec_orig ![]() http://img-fotki.yandex.ru/get/6502/..._4dceed45_orig ![]() http://img-fotki.yandex.ru/get/6506/..._31a34997_orig Last edited by ArtX38; 9th Dec 2012 at 00:28. |
#13 |
What's a Dremel?
Little case, great power ( Small box, big power )
PC Components: Cooler Master Elite 120 OCZ ZT Series 550W Gigabyte GA-Z77N-WIFI Intel Core i5-3570K Corsair Vengeance Blue 8GB (2x4GB) 1600MHz Intel 330 SATA3 SSD 120GB Gigabyte Radeon HD 7970 (GV-R797OC-3GD) Veris Multimedia Station Premium Water cooling components: Koolance CPU-370 (CPU) Koolance CHC-125 (MB) Koolance RAM-33 X 2 Koolance video block VID-AR797 Koolance RP-401X2 Single 5.25" Reservoir Koolance Water Pump PMP-400 High-flow Pump Koolance Liquid Coolant Radiator Alphacool NexXxoS XT45 x 2 unit MediaTek components: WD Elements Desktop 3.5'' 2TB x10 unit Cooler master cm 4-in-3 device module 3x5.25"->4x3.5" x 4 unit Psu Enermax Liberty elt400awt D-link dub-h7 7-port USB x 2 unit ![]() , ![]() , ![]() , ![]() , ![]() , ![]() , ![]() http://www.youtube.com/watch?v=_bVwhGWZZb4 http://www.youtube.com/watch?v=Ukmo9zg30Xg Last edited by ArtX38; 9th Dec 2012 at 15:50. |
#14 |
Minimodder
Beautiful!
#16 |
What's a Dremel?
#17 |
What's a Dremel?
| Tags |
| cooler master elite 120 |
| Thread Tools | |
| View Mode | |
