Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Oct 2012, 11:32   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
AMD announces ARM-based Opterons
Server-centric SoCs due to launch in 2014.
http://www.bit-tech.net/news/hardwar...arm-opterons/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 30th Oct 2012, 12:00   #2
Harlequin
I Mod, Therefore I Own
Harlequin's Avatar
Harlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming Saiyan
i`ll say it now - TOLD YOU SO ; said this a few months back AMD are moving into ARM....
__________________
They shall grow not old, as we that are left grow old:
Age shall not weary them, nor the years contemn.
At the going down of the sun and in the morning
We will remember them
Harlequin is offline   Reply With Quote
Old 30th Oct 2012, 12:50   #3
NikoBellic
Tech Addict
NikoBellic's Avatar
NikoBellic has yet to learn the way of the Dremel
Well done AMD, Intel are still strong in the PC Gaming market, but most day to day user tasks can already be handled quite well by ARM, and its not gonna be too long until ARM delivers the performance of x86-64 yet still has that infamous ARM efficiency!. Can't wait to try OC'in a future ARM based desktop chip with watercooling!
__________________
Intel Core i5 3570K --- ATI Radeon 7850 2GB
16GB DDR3 2133MHz --- ASUS P8Z77-V PRO
Samsung 840 EVO 256GB
NikoBellic is offline   Reply With Quote
Old 30th Oct 2012, 14:58   #4
p3n
Hypermodder
p3n has yet to learn the way of the Dremel
Total codswhallop...
p3n is offline   Reply With Quote
Old 30th Oct 2012, 15:57   #5
asura
jack of all trades
asura's Avatar
asura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyan
Total? Codswallop?
Are Intel strong in the PC gaming market? Yes.
Can ARM handle many day to day tasks? RasPi does browsing and word processing to an adequate degree and can playback at HD quality and it uses an old cortex... so again yes.
How long until ARM delivers x86-64 performance? Well this one's a stumper, particularly as "x86-64" is a pretty wide open goal a quick google points out that the first was the AMD Opteron... I couldn't quantify it, but I'm pretty sure that if someone did some testing comparing a top of the range ARM chip with an old K8 then ARM would come out on top. Conversely compare the same ARM chip to a high end Intel or AMD product and I'm sure we'd see it brought to it's knees. It's a bad first statement, not what I'd term codswallop, but he hadn't properly defined his terms.
ARM, efficient? Again, yes, again.
ARM, over-clocking? Yet again, yes; jumping back to the RasPi, it's ridiculously easy in Rasparian, open up a txt editor, enter the clock speed you want, and if it's possible then it's there on your next boot.
Water cooling an Arm chip? Well, it's a bit silly due to the aforementioned efficiency. But whatever floats your boat.
asura is offline   Reply With Quote
Old 30th Oct 2012, 18:30   #6
Narishma
Multimodder
Narishma has yet to learn the way of the Dremel
Announced at an event in the US last night, the deal will see AMD become an ARM licensee for the first time with a deal to produce chips based around a 64-bit implementation of ARMv8, the instruction set architecture found in the Cortex-A15 'Eagle' IP.
The Cortex A15 supports the ARMv7a instruction set which is 32-bit with a PAE-like extension to support 40-bit memory addressing at the OS level, but not at the application level.
Narishma is offline   Reply With Quote
Old 30th Oct 2012, 18:37   #7
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
ARM implementation will always do certain things well, it will always lack behind as well. There is no magic solution that will give you perfect 64 and 32bit execution whilst doing it at normal ARM power usage levels. If it could be done, it would be being done. However, what ARM are doing, with the software to support it, is making people ask the question as to whether the cost and power usage differences are worth it. For peeps needing raw power, the answer is yes. For those that want a tablet in future, the answer is no, ARM will provide what the platform and user needs.
As is said above, AMDs saving grace is that they recognise the need to deliver a good product at the low end. Both with this licensing agreement and their APUs. What Intel give is is useless Atoms. They were no good when they came out and still suck &#/ IMO. Will they be better in 12 to 18 months once they get an inegrated GPU, erm, no. It will be woefully underpowered and will provide so little GPU muscle the machines with them in will struggle with showing the Metro start screen.
Blackshark is offline   Reply With Quote
Old 30th Oct 2012, 18:39   #8
Blackshark
Multimodder
Many users are finding significant gains using heatsinks and quiet fans on our RPis. I would certainly consider a integrated peltier and water cooler! Oh hang on, that kills the power efficiency a bit doesn't it!?
Old 30th Oct 2012, 18:56   #9
NikoBellic
Tech Addict
NikoBellic's Avatar
The reason I mentioned the idea of water cooling was because I would like to see how well a more power efficient/cooler cpu architecure would OC, although I'm not really a big fan of running my system in an OC'd state unless I'm doing a little gaming for the next few hours... which admittedly is rare these days...
I've tried OC'ing my SGS2 before to see how well that would run with higher clock speeds and that did cause it to get very hot, hence I suggested water cooling, and the reason I'd want to try it on a desktop chip is because I believe that it would be easier to get a good water cooling kit for a desktop setup lol...
but power efficiency is still more important to me than higher clock speeds, OC'in is just a hobby when I've got a few hours to spare, and when I'm done I restore most settings back to their defaults...
__________________
Old 31st Oct 2012, 11:49   #10
Gareth Halfacree
WIIGII!
bit-tech Staff
Quite right - brainfart. Corrected, ta!
__________________
Reply
Tags
64-bit, 64-bit arm, amd, arm, armv8, cpu, data centre, datacentre, intel, opteron, opteron arm, processor, seamicro, server
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
