Reply
Thread Tools View Mode
Old 2nd Nov 2012, 18:52   #1
dreamevil
What's a Dremel?
dreamevil has yet to learn the way of the Dremel
(project log) Arachnid - 02 november
hello and welcome to my first ever mod/build
well where to begin i was bored one night and decided to see what i could do to help with the boredom and somehow i came up with building a computer case after several ideas came through my head i saw this on the internet http://pcper.com/images/reviews/992/icon1.jpg which inspired me to create this monster.
its probably not the most sensible design to start modding with and i know i cant build this case exactly how i have it planned in my mind (very little money) so this is going to be a working model of the planned case i.e instead of black acrylic ille be using plywood and paint
so after several hours on sketchup i have finally come up with a design i like the look of (keeping that a secret)
i started the build Wednesday night (31st October) laying out the components robed from an old computer onto the hitec chassi
on thursday i started by cutting out "armour" for the case
and this is what i got done today
that's the computer running on the screen in the background unfortunately im locked out
next up im going to start work on the main shell covering the motherboard and seeing if i can rob any leds from somewhere
dreamevil is offline   Reply With Quote
Old 3rd Nov 2012, 18:56   #2
dreamevil
What's a Dremel?
main body
last night i decided to base the main body around three case fans i had lying around and again i used more of that lovely plywood to build up the cases main carapace
im really happy with the way this is turning out but tbh it friggin huge
Old 8th Nov 2012, 20:39   #3
Warrior_Rocker
Holder of the sacred iron
Warrior_Rocker's Avatar
Warrior_Rocker has yet to learn the way of the Dremel
This is a great start, some of the best case mods on this site are made using wood. It also makes a great template to start from if you do decide to use acrylic in the future. Interested in seeing more progress on this build.
Mod on
Warrior_Rocker is offline   Reply With Quote
Old 23rd Nov 2012, 23:27   #4
dreamevil
What's a Dremel?
sorry about taking so long to give an update i haven't worked on this as much as i would like too and unfortunately i dropped the build a few weeks ago while tidying (proof no good comes from tidying up) and i broke the top of the shell so I've decided to rebuild it out of steel
so i popped round to a friends shop to pick at his scrap machines and decided to "borrow" this.
so this is what I used to build the new chassis for some reason i was sure I'd taken pictures of marking and cutting them out but someone stole them
fortunately i didn't get too far into bending the metal before i remembered to take a photo
drilled some holes and made sure the cd drive fits
cut out and finished bending the rest of the steel
it was far too flexible so using a piece of off cut i made a nice support marked drilled and riveted it to the frame
now i need to create another support for the other side
Old 24th Nov 2012, 20:52   #5
dreamevil
What's a Dremel?
woop woop, I've found myself a dremel 395. I will start testing it out tomorrow but it seams to cut through this stuff fairly easily
Old 25th Nov 2012, 13:23   #6
Ra6
Multimodder
Ra6's Avatar
Ra6 has yet to learn the way of the Dremel
What's that? Batman's car?
Great job! Similar to mine:
http://forums.bit-tech.net/showthread.php?t=248535
Ra6 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
