Old 2nd Nov 2012, 20:42   #1
thedonz
What's a Dremel?
thedonz has yet to learn the way of the Dremel
E5645 - only getting 2-3k PPD
Hi All - yet another thread about low PPD
i have a server running with a single E5645, 6 cores 2.4Ghz, with hyperthreading.
its running Linux and has the latest version 7 client running.
the system has nothing else to do but fold.
i've setup a pass key but the unit hasn't done its 10 units yet.
i've used the -smp 12 switch and the system load info shows the folding process taking up 1197% CPU
but i'm only getting about 2-3k per day.
from what i can tell i should be getting 3 or 4 times that - will the bonus after the first 10 make the difference up?
confused and hopeful
Donz
thedonz is offline   Reply With Quote
Old 4th Nov 2012, 07:09   #2
One_Box
Folder of the month April 2012
One_Box has yet to learn the way of the Dremel
Seems low, but wait until the bonus kicks in to get the total picture and repost if necessary.
__________________
Folding stats
Folding stats
One_Box is offline   Reply With Quote
Old 4th Nov 2012, 19:42   #3
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
Welcome to the forum
+1
BTW, the initial 10 WUs apply to your user name, not your machine. You may find it saves time to run your first 10 WUs without the 'smp -12' flag, they will be low scoring, but should finish more quickly than with the flag. There isn't a straightforward way to tell if Stanford have received the 10 WUs, you will have to count at your end. HFM.NET can show the number of completed WUs.
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
