Reply
Thread Tools View Mode
Old 4th Nov 2012, 21:58   #1
djzic
Bokehlicious!
djzic's Avatar
djzic has yet to learn the way of the Dremeldjzic has yet to learn the way of the Dremeldjzic has yet to learn the way of the Dremel
The Shuttle
Hi guys, I haven't really been around much recently, school and other factors of life mean I don't have much spare time . Anyway () I have a shuttle PC I'm not satisfied with.
I started sleeving it...
First ever Sata cable I've sleeved
Now I've removed the stock cooler. It uses non-stock cooler-mounting positions so I'll have to make/mod a bracket.
The PSU has been relocated. This bar will need to be cut to give the PSU clearance. Everything after the screw hole in focus is going for clearance.
GPU.
More tomorrow. Sorry for the awful pictures, I have no good light.
__________________
Check out my build: the Shuttle.
Q8300. 8gb XMS2. ATI 4650.
Thermalright AXP-140. Samsung SpinPoint 1TB.
1U 300w PSU. Shuttle Case. MDPC-X Sleeving.
djzic is offline   Reply With Quote
Old 6th Nov 2012, 19:17   #2
djzic
Bokehlicious!
djzic's Avatar
Well I happened to be looking for my cutting wheels for ages, and by the time I had found them, it was practically dark I had about 3 minutes to cut this before it was pitch black, so sorry for the awfuuul cut! Will be filed/sanded, I promise!
PSU now has clearance.
New CPU
I used about 13 cutting disks, I was in a rush and could only find the cheap variation
__________________
Old 6th Nov 2012, 19:30   #3
mrbungle
Undercooked chicken giver
mrbungle's Avatar
mrbungle should be considered for presidentmrbungle should be considered for presidentmrbungle should be considered for presidentmrbungle should be considered for presidentmrbungle should be considered for presidentmrbungle should be considered for presidentmrbungle should be considered for presidentmrbungle should be considered for presidentmrbungle should be considered for presidentmrbungle should be considered for presidentmrbungle should be considered for president
I am alll for artistic photography but these images are useless.
__________________
One//i5 3570K 4.5Ghz//Z68X-UD4-B3//8gb DDR3//EVGA 670 F.T.W.//HX850W//CM690ii//2x128 V200 SSD//Xonar DG//
Two//i5 2500K 4.5Ghz//Assrock Z68 Gen3//8gb DDR3//MSI 7970//TX750W//Akasa Mirage//128 Vertex+ SSD//Xonar DG//
mrbungle is offline   Reply With Quote
Old 6th Nov 2012, 19:36   #4
KrunchR
Supermodder
KrunchR's Avatar
KrunchR has yet to learn the way of the Dremel
I think they would be ok in good light....
KrunchR is offline   Reply With Quote
Old 6th Nov 2012, 19:52   #5
kinghong1970
Just a Clumsy Ape
kinghong1970's Avatar
kinghong1970 has yet to learn the way of the Dremel
like macro shots much?
with some decent DoF... try bumping aperture up to 2.8 or 4 and use a tripod...
kinghong1970 is offline   Reply With Quote
Old 6th Nov 2012, 21:13   #6
djzic
Bokehlicious!
djzic's Avatar
Well, since it's pissing it down outside, I hardly have any decent light...
These were shot at f/8.
Instead of telling me my pictures are useless, why don't you show off your obviously godlike photography... If you even know how to manually operate a camera, that is.
Ah, bit tech... whatever happened to the community? It seems well and truly dead now, and all I see is advertising...
__________________
Old 7th Nov 2012, 00:17   #7
kinghong1970
Just a Clumsy Ape
awww... don't get pissed...
and as for f/8... it is impressive how much bokeh and shallow DoF you are able to get from an f/8
anyways, can't say my pics are godlike... but if you like i'm over at Photography on the net forums under same handle.
don't think i had such bokeh from my EF 50mm f/1.2L or my EF 24mm f/1.4L but then again, what do i know... i'm just out in the woods shooting birds with a EF 500mm F/4L...
just curious... what was your exposure on this? have any exif info?
not to be critical but rather curious as to how you got these effects in your shots.
i guess the folks were trying to say that less bokeh would have helped us visualize your projects more.
good luck in your project.
Old 7th Nov 2012, 01:36   #8
jay2
Poor Man PC Mod
jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.
and... what are you trying to show to us?
call me noob in photography, but all i can see is blurry dark pictures.. you dont have blitz in your camera?
what part of psu is that? what gpu part is that?
jay2 is offline   Reply With Quote
Old 7th Nov 2012, 06:55   #9
djzic
Bokehlicious!
djzic's Avatar
I happened to be directing that comment towards mrbungle. There happens to be very little DOF since I'm using a manual focus 85mm f/2 with a 2x TC. It's not very easy to stop down when the ISO on my camera is awful and I'm barely getting usable shutter speeds as it is. Thanks kinghong, for actual constructive criticism
jay2, it's not blur... it's called depth of field. Why don't you learn about it before you comment?
It's a 1U psu, and it's the end where the cables come out... also it's the GPU cooler.
__________________
Old 7th Nov 2012, 08:38   #10
Lance
I ate Bhindi Bhaji.
Lance's Avatar
Lance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on you
Can't decide between:
Calm down dude.
Can you give us a few pics of the case and full setup to begin with. Even a smartphone pic would be fine if you can't get your ISO in range. Arts only interesting when you have a reference point. Your shot of the PSU clearance doesn't show us the PSU so we can't see whats changed.
Also have you considered getting some cheap bellows (or tilt shift if you're loaded) if you really love DOF & Bokeh? If would allow your photo of your CPU to have the full CPU in focus while the rest is off because it changes the focus zones.
or just get moody and say:
Man up and just take some proper photos, that lot are useless to let us know whats happening. You have a PC therefore you have electricity so buy a lamp and use that or wait till you have enough light. After 500 posts you should know how to behave on a forum
Either way. Stop flaming people, and never feed a troll.
__________________
Originally Posted by mrMonkeyChunks View Post
All hail lance, the lord of interior design.
Lance is offline   Reply With Quote
Old 7th Nov 2012, 08:47   #11
ulfar
holy s**t, i can change this?
ulfar is a hoopy frood who really knows where their towel is.ulfar is a hoopy frood who really knows where their towel is.ulfar is a hoopy frood who really knows where their towel is.ulfar is a hoopy frood who really knows where their towel is.ulfar is a hoopy frood who really knows where their towel is.ulfar is a hoopy frood who really knows where their towel is.ulfar is a hoopy frood who really knows where their towel is.ulfar is a hoopy frood who really knows where their towel is.ulfar is a hoopy frood who really knows where their towel is.ulfar is a hoopy frood who really knows where their towel is.ulfar is a hoopy frood who really knows where their towel is.
he said in reply to two members "older" than him
not to be rude, but please read the second quote, and then directly the first one.
not everyone's as skilled/interested in photography as you, thus not as knowing about it as you.
while bit-tech tends to love detail shots (i know i do), it's nice to see some broader pics as well, you know, to get a hang of what's actually going on.
just saying
__________________
finally something that's sig-worthy:
i5-3570k - asus p8z77m pro - samsung 830 128 - hitachi somecrap 160gb - 8gb corsair vengeance - tagan 480w - hd 7870 ghost
all crammed into a bitfenix shinobi
i'm working on it!
ulfar is offline   Reply With Quote
Old 7th Nov 2012, 11:45   #12
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
I'm with the others, those pics don't show anything at all really. The first one is ok, but should probably be complemented by some other, clearer, pics.
The community is still here and very friendly by the way. Don't lose your head.
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is online now   Reply With Quote
Old 7th Nov 2012, 11:49   #13
perplekks45
LIKE AN ANIMAL!
perplekks45's Avatar
perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.
Seriously? Either you're an extremely long-time lurker here or please refrain from such statements, mate.
Otherwise I can say the following: while this may be an interesting mod your pictures don't show anything but blurry darkness with tiny bits of hardware in focus... just not good enough, sorry.
Do you have any drawings to show us what your plans are? Anything rendered, by chance?
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far.
ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
Iä! Iä! Cthulhu fhtagn!
perplekks45 is offline   Reply With Quote
Old 7th Nov 2012, 15:00   #14
kinghong1970
Just a Clumsy Ape
you're very welcome...
forgive my curiosity...
85mm f/2 with a 2x TC will give you 170mm f/5.6?
why did you use a TC? or are you using extension tubes?
how about getting rid of the TC, set camera to aperture mode, set at f/8 (or whatever aperture is the sweet spot for that lens), set ISO to about 400 and use a bean bag, rice bag, masking tape and stabilize the camera for longer exposure?
ISO400
f/11
1 sec exposure with a tokina 12-24 lens.
sorry for turning this into a photog thread...
i too enjoy bokeh... truly enjoy bokeh...
but enjoy it when the subject of your shot is clearly visible and bokeh serves to isolate subject from a hectic background... just my humble opinion...
this was shot with my 50L @ f/1.2 1/125 sec exposure... could have used more exposure but liked the dark tone/feel and at 1.2 isolates enough and yet keeps object visible...
anyways, show us some pics of your log and let's stop talking bout the images... art is subjective... and just keep in mind OP, you post "artistic" images, you are subject to various opinions as seen here...
i do like the heatsink shot by itself...
oh, and get some dust blower when doing macro shots... hehehe
Old 7th Nov 2012, 16:09   #15
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role - it's over 9000!!!!!!!!1!1!1!!!Maki role - it's over 9000!!!!!!!!1!1!1!!!Maki role - it's over 9000!!!!!!!!1!1!1!!!Maki role - it's over 9000!!!!!!!!1!1!1!!!Maki role - it's over 9000!!!!!!!!1!1!1!!!Maki role - it's over 9000!!!!!!!!1!1!1!!!Maki role - it's over 9000!!!!!!!!1!1!1!!!Maki role - it's over 9000!!!!!!!!1!1!1!!!Maki role - it's over 9000!!!!!!!!1!1!1!!!Maki role - it's over 9000!!!!!!!!1!1!1!!!Maki role - it's over 9000!!!!!!!!1!1!1!!!
Bokeh is a really tricky effect, too much of it and the shot is ruined, too little and it's not noticeable and a bit pointless. Personally I'm not convinced on the artistic merit of these shots as without labels you basically don't have a clue what's going on most of the time. Better light would help but mostly it's just there's not enough of the subject in focus.
I'm curious to see where this one is going, given I can't see most of it yet.
Maki role is offline   Reply With Quote
Old 7th Nov 2012, 16:13   #16
djzic
Bokehlicious!
djzic's Avatar
wow... such friendly responses
Kinghong, the TC was for closer focusing distance, 0.8m on an 85m leaves a little to be desired, and I have an f/4, since the amount of light is halved
Some of my pictures...
Right BTT! Anyway, since you guys seem to want crappy pictures...
The cooler has part of the stock cooler fit in atm, the heatpipes will be cut off ofc, and the cooler will be installed using stand-offs or long screws, not sure yet.
__________________
Old 7th Nov 2012, 16:18   #17
Meelobee
< Your add here >
Meelobee's Avatar
Meelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run Crysis
You really brought the replies on yourself...
Looking at your pics in the last post, if you know how to photograph correctly, why do even my pics look better than the batch you initially posted? I'm no photo expert by far, but at least my pics show the object I'm shooting. Don't get me wrong, artistic pics are great, but the ones showing your hardware are too artsy and don't really show anything.
Meelobee is offline   Reply With Quote
Old 7th Nov 2012, 16:25   #18
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
I am still in the case mod sections, right? Or is the hardware modded? I can't tell... Is there a case in here somewhere?
The "crappy" pictures are a lot more useful than the rest, in my opinion. My photography skills aren't any good, and I've just got a point and shoot, but images show what I'm working on so people can understand it... That's more important in a case mod, than having "pretty" pictures of hardware, to most of us.
I lurked for quite a few years before joining, and I must say that I feel the community is still there, just doesn't tolerate rudeness and arrogance very well. Just be careful with word choices when in disagreement, so you can ensure that the message we receive is the one you're trying to convey, and you won't have many problems.
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 7th Nov 2012, 16:47   #19
djzic
Bokehlicious!
djzic's Avatar
Meh, I don't feel particularly inclined to stay in such a negative community. I have been lurking since 2006, so I can tell you that the community used to be much more positive. I honestly am shocked at the changes. Good bye bit-tech, I won't be coming back.
__________________
Old 7th Nov 2012, 16:58   #20
Mosquito
Hypermodder
Mosquito's Avatar
Bye.
__________________
Mosquito
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
