Old 5th Nov 2012, 09:54   #1
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyan
HFM RunningAsync
Hi all,
i've noticed that in HFM that the bigbeta folding rig's status bar is blue and says 'RunningAsync'
i don't think its causing any issues and i think its to do with the clocks going back last week
i have synchronized clock tick in HFM also
does any know how i can sort it out?
thanks
__________________
3770k @ 4.8GHz, GTX980 OC'd, Custom loop,
kirk46 is offline   Reply With Quote
Old 5th Nov 2012, 12:07   #2
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
Rebooting the folding machine has always worked for me.
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Old 5th Nov 2012, 13:35   #3
kirk46
Cheesecake Nom Nom
kirk46's Avatar
i will give it a go
__________________
Old 5th Nov 2012, 18:44   #4
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
Obvious question but, has the bigbeta rig, and the rig you're monitoring with via HFM, got the same time? I know I've had this when two rigs have had different clock times.
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 5th Nov 2012, 23:38   #5
kirk46
Cheesecake Nom Nom
kirk46's Avatar
a reboot didnt work
and i think your right doc! the pc HFM is on was an hour infront so ive changed it back
lets see
EDIT: it worked
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
