Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Nov 2012, 10:42   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for president
AMD launches Piledriver-based Opteron 6300 chips
'Abu Dhabi' chips boast significant performance gains.
http://www.bit-tech.net/news/hardwar...opteron-6300/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 5th Nov 2012, 12:12   #2
Phil Rhodes
Hypernobber
Phil Rhodes has yet to learn the way of the DremelPhil Rhodes has yet to learn the way of the DremelPhil Rhodes has yet to learn the way of the Dremel
When you say "launches", d'you mean "begins to advertise?"
Phil Rhodes is offline   Reply With Quote
Old 5th Nov 2012, 12:43   #3
.//TuNdRa
Resident Bulldozer Guru
.//TuNdRa's Avatar
.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president.//TuNdRa should be considered for president
It's probably just a Paper Launch, so the information is out there, plus reviews will start to trickle through soon enough. Part availability probably depends upon the manufacturers getting their shiny new Server Setups build to sell them.
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Xonar DX/XD | 2X SLI KFA2 550Ti White Edition | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | OCZ Agility 3 60GB | 1.5TB in Drives | Lite-on Blu-ray ROM
Acer H226HQL | Sennheiser HD 485s | Creative Gigaworks T40s | Logitech G13 | Microsoft Sidewinder X6 | Cyborg R.A.T 9
.//TuNdRa is offline   Reply With Quote
Old 5th Nov 2012, 12:44   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
I say what I mean and I mean what I say: you can buy them right now from AMD. Granted, only if you're ordering several 1,000-unit trays, but still.
__________________
Old 5th Nov 2012, 19:36   #5
Snips
I can do dat, giz a job
Snips's Avatar
Snips is definitely a rep cheat.Snips is definitely a rep cheat.Snips is definitely a rep cheat.Snips is definitely a rep cheat.Snips is definitely a rep cheat.Snips is definitely a rep cheat.Snips is definitely a rep cheat.Snips is definitely a rep cheat.Snips is definitely a rep cheat.Snips is definitely a rep cheat.Snips is definitely a rep cheat.
I'll take two!
Snips is offline   Reply With Quote
Old 6th Nov 2012, 05:26   #6
SazBard
10 Print "C64 ftw"
SazBard's Avatar
SazBard has yet to learn the way of the Dremel
I would love to have two of the 6386SE's in a folding rig!
Ahh here's to dreaming... :-)
SazBard is offline   Reply With Quote
Old 6th Nov 2012, 08:55   #7
TheDodoKiller
Getutech, Eh? What's that?
TheDodoKiller's Avatar
TheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on you
Does this mean that they'll start rubbish, but finish quite high? And that most of them will crash? Seems like the sort of thing that happens with Abu Dhabi.
TheDodoKiller is offline   Reply With Quote
Old 6th Nov 2012, 09:28   #8
Spreadie
No disassemble!
Spreadie's Avatar
Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.
No, they'll start really strong, and run out of steam have way through a given task!
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
2500K|Gene-Z|8GB|670|X-Fi|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|240 UT60
Spreadie is offline   Reply With Quote
Reply
Tags
abu dhabi, amd, amd abu dhabi, dual-socket, interlagos, opteron, opteron 6300, piledriver, quad-socket, server
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
