#1 |
Supermodder
PC for the parents
Hi Everyone! Been some time since i've posted on Bit-Tech, needless to say, i'm a little out of touch with whats going on in the hardware world anymore (which is sadening), i've not built a PC in quite some time (and just check my signature to see what i'm running)...
I've been enlisted to build a PC for my parents, as there's has finally gone pop. They don't need much, but what you think of the spec below: Intel Core i3 2120 3.3GHz Socket 1155 3MB L3 Cache Retail Boxed Processor £91.46 Gigabyte GA-Z77-DS3H £67.96 Crucial 8GB DDR3 1600Mhz Ballistix Sport Memory (2x4gb) £27.99 Xenta 600W 12cm Fan PSU - 1x 6pin PCI-E 2x SATA £26.58 LG GH24NS90 SATA DVD Optical Drive | OEM £13.57 WD 500GB Green Desktop Drive £50.25 CiT Vantage Gaming Case Black HD Audio Black Interior 4 Fans Card Reader No PSU £31.95 Microsoft Windows 7 Home Premium w/SP1 £69.99 All costed from eBuyer... Any help apprecated as always...and it feels good to be back!!! Rich
__________________
xp 2500+ m running at 2.5GHz, 9700 pro (massivley overclocked) 1 gig of pc 3700 twister, abit nf7-s v2.0, 80 gig WD s-ata, akasa 480w
CM Stacker watercooled fully with a thermochill 120.3 in bottom -------------------------------------------------- A64 3200+ winnie at 2.4, gainward 7900gs 256mb, i gig of OCZ vx4000 Gold, lanparty RDX-200 crossfire mobo, 250 gig + 2x80 gig WD s-ata, tagan power 420w lian li v1000 no longer watercooled, but silent on air ![]() |
#2 |
Derp
Hey there Rich,
You have a nice build there but I would like to make a few suggestions;
I would take up the advantage of the free delivery with Scan if the parts or similar are available on there. Just my thoughts that's all.
__________________
i5 2500K - MSI 7970 Lightning - Corsair H100 - Nzxt Phantom - Dell U2412 x 2 - Asus Sabertooth P67 - WD640 Black - Corsair Force 3 120GB - Samsung 840 250GB - Vengeance Black 16GB - Asus Xonar DG w/ T40s - MBP OSX ML w/ Toshiba 128GB SSD
Steam: Louis - Origin: Grexthor Last edited by suragh; 5th Nov 2012 at 13:01. |
#3 |
Good news everyone!
Good advice. With the money saved you could put a little more into the case, since that's the only bit that's really on display. I coerced my folks into paying for a Silverstone FT-03 rather than a plasticky "G4m3r 4 lyfe" cheapo affair.
That's probably overkill, but you could look at one of the options from Antec/BitFenix/Fractal etc. Spend 20 minutes in here for some ideas.
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500 Why. |
#4 |
I'm not half arsed, I'm an arsehole
All looks good except that psu - overpowered and unbranded = potential headache.
For the system listed I would be surprised if it went over 150W tbh I would go with this: http://www.scan.co.uk/products/430w-...et-fan-atx-psu Lots of headroom should you need it and it won't go bang taking everything else with it. If you really want to keep the cost down then this would suffice: http://www.scan.co.uk/products/300w-...et-fan-atx-psu Personally I would spend the extra £6 though for a little bit of future proofing. |
#5 |
Good news everyone!
I'd echo that advice on the PSU. Branded is the way to go really. It's also worth considering whether it might make more sense (or be more fun) to build a smaller unit such as a mini-ITX machine.
__________________
#6 |
Case and Mobo idea - go mATX - means the unit is less intrusive/can be hidden away better. The case listed is a top case to and the mobo has heatsinks on everything too unlike other cheap mATX/ATX boards.
http://www.scan.co.uk/products/msi-h...vi-d-micro-atx http://www.scan.co.uk/products/fract...et-fan-w-o-psu |
#7 |
As per Shirty's suggestion some ideas for mini ITX.
http://www.scan.co.uk/products/coole...4x25-hdd-usb-3 http://www.scan.co.uk/products/msi-b...-hdmi-mini-itx I think micro ATX give more freedom though in terms of componants later on to upgrade and gives better air movement to keep stuff cool. |
#8 |
Also if you still want a card reader then this will be far better than the built in one on the case you listed:
http://www.scan.co.uk/products/sweex...nc-usb-20-port |
#9 |
Supermodder
Ah i love Bit-Tech. thanks for all the quick replies!!!
Great ideas, would love to build a mini ITX PC, what about cooling in it though? Though about mATX, but the mobos seemed to be more expensive... (but obviously not from your links)... Will do some more research tonight i think, was thinkg 8gb of memory as it's pretty cheap in comparison to other components, but if 8gb will be utalised about as much as 4gb, i'll save a tenner...!
__________________
#10 |
Good news everyone!
Just for illustration, I use my PC almost exclusively for gaming. I have never exceeded 4GB or RAM usage, the additional 4GB are really just future-proofing because it's relatively cheap.
Cooling won't be an issue with the type of hardware you are looking at, so a quiet & neat build will be the order of the day. Do you have a budget? I'm sure you'd get a suggested build up together in next to no time if you give the Bit-techers some tangible money to spend ![]() P.S. I love the first part of your sig, it's sooo 2004 and takes me back.
__________________
#11 |
Supermodder
Well, the intially said they don't want to spend over £500, but i was thinking £400 would be enough to suit what they need.
haha, that just proves how out of touch i am! The NF7 was a classic though.....
__________________
#12 |
Good news everyone!
How about this? Leaves some budget to be creative with if required...
![]() A few comments:
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500 Why. Last edited by Shirty; 5th Nov 2012 at 14:57. |
#13 |
DemonHighwayman
I built a pc for my dad a couple years back for his xmas, It was only a dual core atom (1.66Ghz)with a 80gb laptop hdd i had lying around and win 7. He seems to love it, the only thing i'd change would be to swap out the hdd for a smallish ssd (64gb probably) The atom is fine for everything he does internet and writing, so open office and chrome were loaded on along with stuff like foxit reader just in case he needs to open a pdf. So that was about £140 for an atom ion mini itx board and ram, then I just knocked up a case out of some cutoffs of wood that were lying around the garage.
__________________
Main Rig:Case: CoolerMaster Cosmos S, Motherboard: Asus M4A785TD-V Evo, CPU: AMD Phenom II X6 1100T, RAM: 8Gb 1600Mhz Corsair Vengeance GPU: XFX ATI 5870, Primary HDD: 128Gb Kingston SSDNOW 200, Optical Drive: LG Super Multi Blue HTPC:Case: Gutted out VCR, Motherboard: Asus AT5IONT-I, CPU: Intel Atom D525 @ 1.94Ghz, RAM: 4Gb 1333Mhz Kingston GPU: Nvidia Ion 2, Primary HDD: Hitachi 500Gb, Optical Drive: NEC ND-6500A Laptop Drive |
#14 |
Supermodder
Cheers Dave, interesting idea, couldn't definately save some pennies there... thinking about upgrade potential as well in some respects.
Thanks for the shopping list shirty! You'd recomend mini ITX over mATX then? Not to much price difference... but what about features? Also not much extra space in that little box.
__________________
#15 |
Good news everyone!
What features will they realistically use? I think in reality I found working on a smaller scale quite fun, because my own rigs end up being enormous. Plus, unless you are a real power user then you can get everything you need in a smaller, neater package.
Space will only be a premium if you have things lined up to fill it
__________________
#16 |
Not sure if they're available in the UK yet, but an ITX FM2 setup would be pretty perfect imo.
__________________
Intel i7-3820 @ 4.65GHz | GeForce GTX 480 | 4x4GB Vengeance | Asus Sabertooth X79
Silverstone TJ07 | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet |
#17 |
Hypermodder
I'd spend the extra few quid on 8GB of ram and forget the Hard drive get an ssd
#18 |
Supermodder
What SSD would you recomend, would the SSD just be for windows etc? how about this:
http://www.scan.co.uk/products/120gb...75mb-s-50k-iop could get a cheaper seperate sata i guess for storage
__________________
#19 |
Supermodder
also, how do you get free delivery at Scan...?
__________________
#20 |
"Jammy..."
Are you sure they wouldn't be more comfortable with a chalkboard. To be helpful 4GB RAM is enough with little multi tasking.
Scan free delivery https://secure.scan.co.uk/aspnet/MyA...ecarriage.aspx. Check their sub-forum, it only comes into effect after £20 ex VAT |
| Thread Tools | |
