Reply
Thread Tools View Mode
Old 5th Nov 2012, 21:28   #1
HCP
Modder
HCP's Avatar
HCP has yet to learn the way of the Dremel
Wargames WOPR desk computer
From the movie Wargames i bring you WOPR.
Love this movie, and love the WOPR.
Started planning this a half year ago, tried to contact people in the US having some info about the real model to get measurements and color codes etc.
Got some good info and now its time to get it rollinī.
I found some sketchup model of the WOPR, but the measurements were totally off, and some parts were to big/small, wrong place and so on. Took me almost a month to get all details right in the sketchup model. Used the movie of course and all pics i could found on the net. Also got some emailed to me from a previous worker who made the original back in the 80īs.
Size of the case will be about 19x8x6", perfect to house a ITX motherboard with a 3870K AMD, i have a Intel 330 128GB SSD somewhere and a Corsair H60 that will to the job perfect
I do not play games, so the graphic power is not a issue for me.
If someone dont know what the WOPR is.
War Operation Plan Response
Now from the start, it may look a bit messy until i get all the parts and stuff together
The roof of the WOPR. Rounded wood stripes to get rounded parts without sanding me to death
Adding some round corners, Using 20mm pipe to get perfect corners.
The three panels for the LEDīs
Sketchup model, got them CNC cut to get perfect holes everywhere
My first order of LEDīs, 400 of them... After some counting, im gonna need 1000 more
To be continued
HCP is offline   Reply With Quote
Old 6th Nov 2012, 06:03   #2
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
when i thought about led array - i find smth like this
it's dirt cheap, no need to solder or smth. just drill holes and put leds randomly
and it blinks in 8 ways
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 6th Nov 2012, 07:23   #3
HCP
Modder
HCP's Avatar
Im using a solder kit from Velleman to control the lights, christmas lights i think will ruin the result with blue and green lights
Old 6th Nov 2012, 08:01   #4
Vetalar
*learning english*
there is alot of lights on market of any desirable color. oh and one cut away blue/green lights
__________________
20 have a sleep
30 goto 10
Old 6th Nov 2012, 08:32   #5
HCP
Modder
HCP's Avatar
Now when i think about it, the flash sequence is pretty much spot on with the WOPR, looking at my neigbours house lights.
But, already soldered 400 leds. Maybe use the christmas lights for the back side nobody see anyway
Old 6th Nov 2012, 10:36   #6
HCP
Modder
HCP's Avatar
Now it starts to look like the WOPR
Old 6th Nov 2012, 11:33   #7
Vetalar
*learning english*
one have a ton of patience
__________________
20 have a sleep
30 goto 10
Old 6th Nov 2012, 14:39   #8
C4B12
Scratchbuilder
C4B12's Avatar
C4B12 has yet to learn the way of the DremelC4B12 has yet to learn the way of the Dremel
This is gonna be fun to follow. Love that old movie!
__________________
Scratch builds | Cold Winter | CURV3D | The Red One |
Casemods | BarPC |
Check out my facebook-page where I post everything about my mods. Like/share if you want to.
C4B12 is offline   Reply With Quote
Old 6th Nov 2012, 21:36   #9
HCP
Modder
HCP's Avatar
After some re-measuring, the first part i made for the LED panels was to small. Forgot to change the setting on my table saw
Trying to hold all pieces for a photo
Old 7th Nov 2012, 20:30   #10
HCP
Modder
HCP's Avatar
Slowly growing up
sorry for the mess around the bench, i dont have time to clean up for the pics
Of course there will be some descent final pics and video of it.
Old 17th Nov 2012, 08:17   #11
HCP
Modder
HCP's Avatar
Been sanding and sanding to get straight edges and round corners.
The top parts getting good now, and ready for gluing. But i think i leave some parts to the last step so i dont get any problems adding the electronics
Adding a pic of the real deal, from almost the same angle.
Old 17th Nov 2012, 11:38   #12
Ch2pa
Minimodder
Ch2pa has yet to learn the way of the DremelCh2pa has yet to learn the way of the Dremel
I will follow this one
I like the concept and the movie too. Good Luck
Ch2pa is offline   Reply With Quote
Old 17th Nov 2012, 13:07   #13
Pfaffen
Supermodder
Pfaffen's Avatar
Pfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run CrysisPfaffen can run Crysis
Never thought of Christmas lights, how much power do they use? Voltage and Amperage?
__________________
Pfaffen
Wood Case Mods: Completed: World Map, Fibonacci, Canary Mesa, Molesworth, Cray-1, Federal Cellarette, Newbery TARDIS
Wood Case Mods: Under Construction: Vogel Haus, Four Hokusai Cases
Pfaffen is offline   Reply With Quote
Old 17th Nov 2012, 14:26   #14
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
usually 12/24v, amperage totally differs with the lenght/voltage
__________________
Works as a tool retailer, glad if i can help someone with tool questions!
Hopes that i someday completes my first scratchbuild...
kelmannen is offline   Reply With Quote
Old 18th Nov 2012, 09:55   #15
Pfaffen
Supermodder
Pfaffen's Avatar
Thanks! I may have to try that sometime.
__________________
Pfaffen
Old 18th Nov 2012, 10:30   #16
Nexxo
There is no rep for awesomeness.
Moderator
Nexxo's Avatar
Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.
HELLO HCP. SHALL WE PLAY A GAME?
>_
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust
Nexxo is offline   Reply With Quote
Old 18th Nov 2012, 11:14   #17
C4B12
Scratchbuilder
C4B12's Avatar
@nexxo It's "Greetings HCP" actually
__________________
Casemods | BarPC |
Old 18th Nov 2012, 23:57   #18
Hanoken
Modder
Hanoken has yet to learn the way of the Dremel
I thought for a sec you were hinting at warhammer my bad ha ha ha, but to say the least now that I realize it is a mod about wopr I'm even more interested can't wait to see what you have in mind for this project, by the way, ever heard of a game called defcon? you might be interested
Hanoken is offline   Reply With Quote
Old 24th Nov 2012, 21:12   #19
HCP
Modder
HCP's Avatar
My biggest concern with the WOPR was the doors, they are countersunk and have rounded edges.
Take a look
I tried different solutions, cut open pipe, sanding in a angle and other stuff, nothing really good.
Now i found this, and whats im going with. Not 100% identical with the original but good enough.
Some putty and sanding, and after that i will run a router bit making the edge rounded i think will do the job.
Old 12th Dec 2012, 20:45   #20
HCP
Modder
HCP's Avatar
Now the fun work starts
Time to figure out where the LEDīs go, from what cluster and what colour, my charts are pretty easy to follor, but with 1400 LEDīs i think i will have a brain freeze or two :P
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
