#21 |
No disassemble!
Very cool - looking foward to this one!
Subbed.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60 |
#22 |
What's a Dremel?
Oh the memories! looking forward to seeing the finished product. Subbed!
#23 |
Modder
Trying the leds in the panels before paint.
Noticed the yellow needs to be changed to amber, too much yellow BTW, its 3mm ledīs ![]()
#24 |
Modder
Made some more panels for the USB headers.
![]() The USB headers goes here, behind the "tower" at the red arrow. ![]() And a colourtest to see how it looks ![]() ![]() Soon gettinī there, much time goes to the LEDīs and not so much for the case right now. |
#25 |
Dark Lord of BT!
Looks clean
__________________
NEW GENESIS
******************************* Modified Azza Genesis with an Intel 2600K, Gigabyte Z68X-UD3H, 32GB (8GB x 4) Corsair XMS3, 480GB Sandisk Extreme, 240GB Sandisk Extreme, 1275 Watt Thermaltake 80 Platinum Modular PSU, EVGA GTX 690 4GB, and a Corsair H60 |
#26 |
Hypermodder
Don't get any ideas of taking over the world, otherwise we're going to have to go tic tac toe on your ass
__________________
Sent from my PC using a keyboard |
#27 |
Hypermodder
__________________
I must not fear, Fear is the mind-killer.
Fear is the little-death that brings total obliteration. I will face my fear. I will permit it to pass over me and through me. And when it has gone past I will turn the inner eye to see its path. Where the fear has gone there will be nothing. Only I will remain |
#28 |
Modder
Hammertime!
*Smack* Got tired of the roof, the plastic i used was to soft that i sagged when sanded and after 10 runs with putty/filler i still didnt have a flat roof. And all wet sanding made the wood increase in thickness, had it in the oven for a couple of hours now to dry it up. Going to replace the roof with 4mm acrylic, and i hope i can get done with the casing now, all other parts just laying around and wait
#29 |
Modder
Current state of the case.
Testing the led-panel, i wish i made the cutout bigger... See if i make that change later or if i just go with it. Nevermind the edges, its not done yet ![]() Almost time for some Tic Tac Toe
#30 |
Multimodder
Hello Joshua
![]() You can never go wrong with some wargames. As a big fan of the movie i have to watch that stunning beauty come to life.
__________________
live on air fridays 20-22 @ radio.XES Gothic, Darkwave, Electro, Metal, Rock & Death
#31 |
Shut up and Mod
R.I.P.L.E.Y. died J.O.S.H.U.A. lives
__________________
Life. Liberty. The pursuit of those who oppose it.![]() Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide @furballzen |
#32 |
Modder
#33 |
Modder
I have stopped using my white plastic and moved to acrylic, more rigid and not flopping around when sanded. The styrene is to saggy to use in a case this big.
Its gettinī taller! I have three fans in the case, on on either side of it, on pulling and the other pushing, one side have double setup (where the rad is). Both fans are hidden behind a panel and push/pull air trough a duct in front of it. I have made some tests with cardboard just to see the flow and cooling capacity and its plenty good for my purposes. Tested with 100% cpuload in 4hrs and a H60 cooler. I didnt want any visible fans, im all focused on making it really really look like a smaller version of the real WOPR ![]() The small tabs behind the rounded corner on the acrylic is temporary there when gluing, to get nice straight corners. otherwise they will hit the motherboard ![]() First pic, case rising to the skies. This is the back side with IO-plate cutout. You also see the fan hole that later is hidden. ![]() Pic two Here is the cover over the fan on the left side of the case. Other side have the same type of panel. ![]() Here is how the real WOPR looks like at almost the same angle ![]()
#34 |
Fenrir The Wolf
This looks awesome.
![]() I like that movie-this is great way to remember it. |
#35 |
What's a Dremel?
You've been busted for using VLC!
#36 |
Ostekake!
AWESOME!
Planning on putting a big lens with a red light behind it on my server rack, HAL-style
__________________
A message to all the girls with nymphomania out there: Hello
#37 |
Modder
Time to start making the light controllers.
This is just a test for one of nine controllers for the LED panels. White and blue to the left is output and its triggered on/off by the red with a knot on. Soldering iron heating up...
| Thread Tools | |
| View Mode | |
