Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Nov 2012, 12:05   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
AMD FX-8350 review
http://www.bit-tech.net/hardware/201...-8350-review/1
brumgrunt is offline   Reply With Quote
Old 6th Nov 2012, 12:21   #2
xxxsonic1971
W.O.T xxxsonic1971
xxxsonic1971's Avatar
xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.
I might as well keep my old i7 920 for another couple of years then...
__________________
intel pentium 4 640, 1gb ddr2 @266mhz, radeon x600.
xxxsonic1971 is online now   Reply With Quote
Old 6th Nov 2012, 12:26   #3
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
thanks for the review. Not bad considering the price tag and the plateform cost. For pleople running 2007 / 2008 era CPU (like my Q6600), this could be a good upgrade.
But I'm more tempted by an A10-5700 (space issue and low power requirement).
GuilleAcoustic is offline   Reply With Quote
Old 6th Nov 2012, 12:39   #4
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
The biggest issue for most who on here might still have the i7920 or some who have the 980 990 chips they have now had those chips for 3-4 years and they are still ahead of amd in every benchmark if they own the later 2. An overclocked i7 920 is still as fast as this at stock ( in most of the tests here) and nobody is going to buy for the sake of it.
For the gaming platform i run i still dont have a reason to upgrade my overclocked i7950 to something faster. my vid and photo edit machine was upgraded already.
rollo is offline   Reply With Quote
Old 6th Nov 2012, 12:43   #5
GuilleAcoustic
Ook ? Ook !
Given the signature I see in many profiles here ... a lot of us still use C2D/C2Q CPUs.
Old 6th Nov 2012, 12:44   #6
Madness_3d
Bit-Tech/Asus OC Winner
Madness_3d's Avatar
Madness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for president
Nvidia GeForce GTX 490 3GB graphics card
That must have been OEM only :P
Sticking with my 965 until Haswell at the mo. Using my desktop less and less these days so really struggling to justify upgrades.
__________________
XFXScorpio911INTEL i7 3770k @ 4.5Ghz SLI GTX 480 1536MB ASUS MAXIMUS V FORMULA16GB CORSAIR DDR3 1600 9-9-9-24 1TCORSAIR HYDRO H50CORSAIR Force 3 120GB WINDOWS 7 HP 64bitMusings On The Technical WorldSteam
Madness_3d is offline   Reply With Quote
Old 6th Nov 2012, 12:44   #7
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
sigh...unless AMD can increase their IPC by at least 30-40% to at least match Sandy-bridge, never mind Ivy-Bridge, I just cant see any of their CPU range ever appealing to me again.
I'm into emulation in a big way, and that needs as much single threaded performance as possible, precisely what AMD cant offer these days, once you go past 2 or 3 cores in the world of emulation, your into fast diminishing returns.
I'm sure for modern games, when paired with a good GPU, these AMD chips are perfectly adequate and you are only really talking about the difference between 80fps or 100fps, therefore pretty irrelevant if they're slower than Intel's line-up, but I'm not into modern games.
Hustler is offline   Reply With Quote
Old 6th Nov 2012, 13:10   #8
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
I am looking at a 4 CPU AMD server with the new 16 core processors at work, to demolish our PostGIS delays. 64 cores running at 2.2GHz. For the same money I can get 16 3.3Ghz cores from Intel or 24 slower.... It we had went with SQL 2012 then that would have been ok because of the licencing costs, but with PostGIS more cores = happy customers. For the server market AMD are providing some compelling solutions. For integrated solutions, netbooks, laptops and the base end of the PC market, AMD is the way to go. But for enthusiasts it is hard to see anything that they can provide.
In terms of CPU design, I assume by now AMD must have taken Intels design apart and understand where the single threaded performance difference is coming from.
And remind me, why have we not had a the same level of die shrinkage with AMD? as intel.
Blackshark is offline   Reply With Quote
Old 6th Nov 2012, 13:19   #9
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
AMD doesn't own its own fabrication labs anymore, they got spun off into newco Global Foundries, so AMD's kind of at the mercy of GloFlo. If it says it can't do the 22nm process, AMD is stuck on 32nm until it can.
Baz is offline   Reply With Quote
Old 6th Nov 2012, 13:20   #10
Panos
Supermodder
Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.
Hmm. Sticking with my water cooled T1100 @ 4.6Ghz.
However I am surprised for the low FPS the 690 GTX produces. I have a 580 GTX and with everything on, including HD gfx & texture mods, I get way better fps!!!
Panos is offline   Reply With Quote
Old 6th Nov 2012, 13:26   #11
Baz
I work for Corsair
Baz's Avatar
Our benchmark takes place outside whiterun during a storm; lots of weather effects and a large area to render, not inside a city or dungeon, where frame rates are typically much higher.
Old 6th Nov 2012, 13:43   #12
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Meanwhile consumers aren't getting the best deal, with it costing £165 on scan and a whopping £180 on overclockers! I honestly see no reason at all for anyone to buy this processor.
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is online now   Reply With Quote
Old 6th Nov 2012, 13:46   #13
Baz
I work for Corsair
Baz's Avatar
Still cheaper than the £200 the FX-8150 launched at. Oddly, I noticed that it's sold out almost everywhere too (or at least, on order) so someone's buying them!
Old 6th Nov 2012, 13:46   #14
GuilleAcoustic
Ook ? Ook !
It costs 100€ less than an i7, 15€ less than an i7-2500k ... nothing to add.
Old 6th Nov 2012, 13:49   #15
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Yep, my 920 @ 4.2GHz is probably on par with the 8350.
Yes, they clearly have something to offer the server market, and I do find their APUs quite appealing.
I wouldn't touch their desktop line with a bargepole, though.
Design a new memory controller, AMD.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170i Pro|32GB|256GB M.2|500GB SSD|8TB NAS|GTX 980|3007WFP-HC|Hadron Air
David is online now   Reply With Quote
Old 6th Nov 2012, 13:53   #16
maverik-sg1
Supermodder
maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.
It's a shame you're not choosing win8 for this review - given AMD was all about these cores being designed around and beyond win8 in terms of max performance.
Thats said AMD should be more honest in their markeing, it's not 8 full x86 cores at all, more like 4 cores each with a co-processor (maybe call it 4+4).
Even when all that is said an done - agree with whats been said, more IPC's and less power draw are required to make this a viable option for many.
maverik-sg1 is offline   Reply With Quote
Old 6th Nov 2012, 14:03   #17
Harlequin
Harlequin's Avatar
Harlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming Saiyan
can you rerun this on Win 8 please - the scheduler is apparantly better designed
__________________
They shall grow not old, as we that are left grow old:
Age shall not weary them, nor the years contemn.
At the going down of the sun and in the morning
We will remember them
Harlequin is offline   Reply With Quote
Old 6th Nov 2012, 14:17   #18
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.
Toms hardware (I think) tested it and in some cases it was worse than a hot fixed win7.
Amd really are in trouble, it doesnt even beat the i5 when overclocked, let alone at stock at a higher power consumption and without a gpu inside. I dont see why people would buy these unless the only thing you ever used was multi threaded applications, which is probably a very small demographic.
fdbh96 is offline   Reply With Quote
Old 6th Nov 2012, 14:20   #19
Harlequin
Harlequin's Avatar
actually it does depend on whicha rticle you read - with some it really does do well against the i5
__________________
Old 6th Nov 2012, 14:49   #20
rollo
Can't see bit rerunning all benches for windows 8
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
