#1 |
Modder
Project: TRON
Hi all!
I wanted to share with you my project. The project is based on the movie Tron: Legacy. The main idea of the project was taken at L3p D3sk, for which he thanks a lot Really needed a computer desk, this decided to do it with the integrated system. I apologize for my English, I use "Translate Google" ))) My system: i7-920 + EK-Supreme HF Gigabyte X58A UD3R + EK-NB/SB 6 Asus GTX580 DCII + EK-VGA Supreme HF ASUS Xonar D1 1Tb WD Caviar Black + 500Gb WD Caviar Blue Corsair 650HXEU Swiftech MCP355 + EK-DDC X-RES 140 VERSION 2 XSPC RX480 Extreme Performance Radiator To start drawing drawn: ![]() So what did the layout, scale 1:10: ![]() Dismantled the rear wall and frame mount, his old body Termaltake V9. ![]() Installing the motherboard tray: ![]() ![]() ![]() It will look like in the collection system: ![]() Painted mounting video and sound card: ![]() ![]() To cool the VRM I used passive radiators Enzotech RAM (BMR-C1): ![]() ![]() They had to be cut down a bit and paint: ![]() ![]() Radiators come perfectly! ![]() ![]() ![]() Radiator XSPC RX480 installation: ![]() ![]() ![]()
#2 |
Multimodder
Nice start i like the vrm coooling
#3 |
Modder
#4 |
Modder
Complete system:
![]() ![]() ![]() ![]() Install the power supply. The power supply is outside. For it made a fan out: ![]() ![]() ![]() ![]() Been thinking about the design of the front panel. As a result, I decided to paste over DVD-ROM plastic plate: ![]() ![]() ![]() ![]() ![]() ![]()
#5 |
Modder
Installed on the side panel are two fans:
![]() ![]() Used Thermalright X-Silent 120 and filter: ![]() ![]() ![]() ![]() ![]() Water block for fastening painted in black: ![]() ![]() I bought a neon cord, UV acrylic and UV lamp: ![]() ![]() Glass installed around the motherboard: ![]() ![]() Just set the band for memory: ![]() ![]() It was evening: ![]() ![]()
#6 |
Calmer than a monk on morphine
I'll just ask since I can, but your image hosting seems to be blocked from my location, you wouldnt consider swapping to like photobucket, I would love to see some TRON modding xD
__________________
All progress is precarious, and the solution of one problem brings us face to face with another problem. - Martin Luther King, Jr. |
#7 |
Modder
._.
Pretty lights..... What is this "neon cord" you're using, how does it work, and where can I find some? |
#8 |
Supermodder
The geek in me loves all things related to tron, just a damn shame tapatalk Keeps crashing, can't wait to get home and get a proper look at the pic
#9 |
Modder
Balder, a link to the hosting without registration, pls )))
Owndapwn, "neon cord" - http://www.pcdesign.ru/faq-neon_worm.shtml (description "neon cord" in Russian) ))) Yaka, big picture? And I do not understand))) Last edited by timerhan; 9th Nov 2012 at 05:45. |
#10 | |
< Your add here >
And I love the VRam cooling, looks very good
#11 |
Modder
Thank you))) I also like very much : Dremel :
#12 |
Modder
A little update. Installed on HDD UV Acrylic:
![]() ![]() After work, accidentally stepped on the tool and broke it ((( ![]() HDD in the night)))
#13 |
What's a Dremel?
this is super wierd.....im doing a Tron themed build right now as well. nice work man!
#14 |
↓ Don't trust that face!
Looks good.
Will you use 'false floor' panels to hide the cables?The material on the optical gave me an idea. If I covered my desk with grip tape, I could sand stuff at the computer. ...Using the mouse might get bloody that way, though.
__________________
#15 | ||
Modder
![]() Later will be pictures))) |
#16 |
Modder
Today made pan ... Some photos)))
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Tomorrow I'll paint))) |
#17 |
www.^.nl
Really love what you did with the neon lights, can't wait for more!
__________________
Preparing: Raz3r D3sk Running : L3p Parvum Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk Sites: www.l3p.nl - www.redharbinger.com |
#18 |
Modder
#19 |
Modder
Finished with a tray ... A hole for the HDD and the pump:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() More recently bought a Crucial M4 128Gb and made a basket for SSD and HDD: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#20 |
Modder
Found in a toy store))))
![]() ![]() ![]() Later used in the design of the model)))) |
| Thread Tools | |
| View Mode | |
