Old 7th Nov 2012, 17:27   #1
andyjhill
What's a Dremel?
andyjhill has yet to learn the way of the Dremel
GTX295 not getting work units
Hi ive got 2 gtx295 folding for the team but since yday i cant seem to be able to get work units from folding@home for it .ive tried getting the latest folding at home installer and installing it on the machine but to no good. Can any of the team help me please ?
andyjhill is offline   Reply With Quote
Old 10th Nov 2012, 09:51   #2
Tattysnuc
Thinking about which mod to do 1st.
Tattysnuc's Avatar
Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!
Mines getting units fine - I'm using the 6.23 client...
__________________
Folding statsFolding stats
Tattysnuc is offline   Reply With Quote
Old 6th Jan 2013, 10:14   #3
Tattysnuc
Tattysnuc's Avatar
Correction. Mine's not now
See:
Code:
# Windows GPU Console Edition #################################################
                       Folding@Home Client Version 6.23
                          http://folding.stanford.edu
Launch directory: C:\Users\Mike\AppData\Roaming\Folding@home-gpu1
Arguments: -gpu 1 -forcegpu nvidia_g80 -forcegpu nvidia_g80
[12:05:53] - Ask before connecting: No
[12:05:53] - User name: Tattysnuc (Team 35947)
[12:05:53] - User ID: 1DF4827C6FEDCA07
[12:05:53] - Machine ID: 3
[12:05:53]
[12:05:53] Loaded queue successfully.
[12:05:53] Initialization complete
[12:05:54] - Preparing to get new work unit...
[12:05:54] + Attempting to get work packet
[12:05:54] - Connecting to assignment server
[12:05:55] + No appropriate work server was available; will try again in a bit.
[12:05:55] + Couldn't get work instructions.
[12:05:55] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
__________________
Old 13th Jan 2013, 09:05   #4
Tattysnuc
Tattysnuc's Avatar
The only thing I've not tried is re-installing the graphics driver.
The upside is, that I've now got a stable 24/7 CPU fold overclock @4ghz, and all 6gb of RAM on my board is showing (usually 1 channel of 2gb is shown missing) - points are now up to 21k ppd.
__________________
Old 21st Jan 2013, 21:20   #5
Tattysnuc
Tattysnuc's Avatar
Still nothing. Graphics driver re-installed, no change.
How many others are running GTX 295's? If so, which client are you running?
__________________
Old 26th Jan 2013, 05:19   #6
mikemaher205
Multimodder
mikemaher205 has yet to learn the way of the Dremel
http://foldingforum.org/viewtopic.php?f=83&t=21205
Might hold some answers.
Also, try the latest client (7.2.9) as it now auto-updates it's GPU list (as you'll read in the above link).
Hope it helps you.
__________________
Folding stats
mikemaher205 is offline   Reply With Quote
Old 26th Jan 2013, 08:09   #7
Taffy
Folding for Margaret 17/3/2011 RIP
Taffy's Avatar
Taffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the Dremel
Have checked out my 275's and they work OK,however I am thinking of upgrading them but dont know what too, 660,670 or 680's any comments appreciated.
__________________
1) MSI 790FX-GD70, AMD PH.II X4 955, 4GB Corsair DDR3, 2 X GTX 275, 1000W PSU in Lian Li 2100. 2) MSI 790FX-GD70, AMD PH II X3 720, 4GB Corsair DDR3, 1 X GTX 275 600W PSU in Lian Li 1100. Alienware M17x-R2 folding on i5 520M
Folding stats
Taffy is offline   Reply With Quote
Old 26th Jan 2013, 09:18   #8
Tattysnuc
Tattysnuc's Avatar
I'm going to to try an OS re-install to see if that fixes it. I've been having some issues with Windows updates on this machine for a while too, so I wouldn;t be surprised if somethign in the BASE os is corrupt. Besides, I've got a nice SSD sat going begging, so that would be reason enough for me
__________________
Old 26th Jan 2013, 10:36   #9
mikemaher205
Multimodder
I'll be getting a GTX 660 into my rig soon, I shall PM you with an average PPD if you like.
Get that OS onto your SSD! You won't regret it one bit.
If your windows has been playing up then I wouldn't be surprised if that is the cause. I have my settings to inform me but not download or install updates, that way they won't interfere with any running applications (i.e. Folding).
Good luck with getting it working again.
__________________
Folding stats
Old 26th Jan 2013, 18:55   #10
Taffy
Taffy's Avatar
Thanks for reply Mike, would apprciate that info.
I am also thinking of upgrading to an SSD
To Tatty,
I have accepted all upgrades and it has not caused any bother so far !!
__________________
Folding stats
Old 26th Jan 2013, 19:42   #11
mikemaher205
Multimodder
Taffy, get an SSD. You can read all the reviews and numbers about how much better they are, but until you get one you've no idea how much better things are.
__________________
Folding stats
Old 26th Jan 2013, 22:19   #12
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
The 600 series don't perform as well as they should when folding, until the F@H cores get rewritten for the new architecture. So you could go for a 500 series card with the same budget, and perhaps get better PPD until the update is rolled out. Either of them will outclass your 275s.
SSD doesn't make much difference to folding, but it will make the machine more responsive in day-to-day use.
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Old 27th Jan 2013, 10:27   #13
StreetSam
Multimodder
StreetSam's Avatar
StreetSam has yet to learn the way of the Dremel
This doesn't mean they perform badly, my 650Ti is about the same PPD as a 460(768) but uses less power and stays 10degC cooler.
http://forums.bit-tech.net/showthread.php?t=254797
__________________
Folding stats
Current Folding@Home stats
StreetSam is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
