#1 |
Gentel-Mod'R
RasPi - XBMC - FINISHED
New Raspberry Pi for Media Center based on XBMC.
The problems of the Raspberry are: N°1 - Need to had a powered USB HUB for more USB devices. N°2 - If you need a powered USB HUB, you need an DC/AC plug and RaspPi need another ONE. Finaly, you need TWO???? 2 for 1 small computer??? Too Bad!!!N°3 - have you ever see a RasPi? Have a look bellow. There are plug everywhere on all sides. (how do a nice little case look in those conditions? N°4 - Need a case that doesn't exist... A problem? Not really. MMMMOOOODDDDDDD ![]()
__________________
CanardWC, The Gentle-Mod'R with A Stupid N@m3 ![]() CM 690 http://forums.bit-tech.net/showthread.php?t=217260 RasPi http://forums.bit-tech.net/showthread.php?t=248805 OldNavY http://forums.bit-tech.net/showthread.php?t=217563 Last edited by Canardwc; 2nd Jan 2013 at 22:06. |
#2 |
Gentel-Mod'R
Project:
__________________
CanardWC, The Gentle-Mod'R with A Stupid N@m3 ![]() CM 690 http://forums.bit-tech.net/showthread.php?t=217260 RasPi http://forums.bit-tech.net/showthread.php?t=248805 OldNavY http://forums.bit-tech.net/showthread.php?t=217563 |
#3 |
Gentel-Mod'R
Presentations
1 - Presentations
The RasPi The HUB Both
__________________
#4 |
Gentel-Mod'R
First PROBLEM
__________________
#5 |
Gentel-Mod'R
So I decide to keep only one power plug for both "cards". I decide to keep the USB HUB power and condamn one port of the HUB to use it as RasPi POWER.
RasPi POWER plug (an old Noki@ charger) Connected to the condamned USB port of the HUB. Connecting the Hub to the RasPi HUB connected to the RasPi Power plug must be moved to the rear of the case
__________________
CanardWC, The Gentle-Mod'R with A Stupid N@m3 ![]() CM 690 http://forums.bit-tech.net/showthread.php?t=217260 RasPi http://forums.bit-tech.net/showthread.php?t=248805 OldNavY http://forums.bit-tech.net/showthread.php?t=217563 Last edited by Canardwc; 7th Nov 2012 at 22:35. |
#6 |
Gentel-Mod'R
Removing the RCA video outpout (because of the HDMI and it's on the bottom of RasPi) and prepare the mounting plate to associate RasPi and the HUB
Glued Aluminium HUB/POWER plate on the ethernet device
__________________
CanardWC, The Gentle-Mod'R with A Stupid N@m3 ![]() CM 690 http://forums.bit-tech.net/showthread.php?t=217260 RasPi http://forums.bit-tech.net/showthread.php?t=248805 OldNavY http://forums.bit-tech.net/showthread.php?t=217563 Last edited by Canardwc; 7th Nov 2012 at 21:36. |
#7 |
Gentel-Mod'R
Glue is dry...
Power HUB moved 2nd step, glue the hub to the plate
__________________
#8 |
Gentel-Mod'R
Then... My discusting work is working..!
__________________
#9 |
Keep calm & mod on. =)
I like it Canard & love the additional USB ports
#10 | |
Gentel-Mod'R
And Thks Again, from you, I take it as a compliment. ![]() I haven't the choise with the posh glue work, there are no holes on the 2 cards... no holes = no screws... ![]() But you do an awsome job on your Scratch' Builds! And quite neat
__________________
#11 |
Steering a Boat in Holland
I like this a lot. It's a nice change from the high-power systems. Keep us updated!
#12 |
Poor Man PC Mod
I'm still waiting my raspi delivery
![]() an XBMC+android raspi would be great.. |
#13 | |
Gentel-Mod'R
__________________
#14 |
Scratchbuilder
Hmm this gives me ideas!
__________________
Scratch builds | Cold Winter | CURV3D | The Red One | Casemods | BarPC | Check out my facebook-page where I post everything about my mods. Like/share if you want to.
#15 |
theorycrafting
Nice idea to build something really small.
What I don't understand tho, as you allready started to solder/desolder some parts... Why didn't you just desolder the power-plug of the RasPI or USB-Hub and make a permanent wired connection between the two boards? Same for the USB-ports ofc. Would've been even better imho and it would look neater aswell.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#16 | |
Gentel-Mod'R
But if I could, I'll do.
__________________
#17 |
Gentel-Mod'R
__________________
#18 | |
theorycrafting
__________________
#19 |
Gentel-Mod'R
Unfortunatly, don't have those kind of equipments...
![]() I do with stuff on board
__________________
#20 |
Gentel-Mod'R
A real test: on Youtube, follow the link bellow
I know, poor quality. Thkx to my Nokio N8-00 http://www.youtube.com/watch?v=udh7F6L3vMc&feature=youtu.be
__________________
CanardWC, The Gentle-Mod'R with A Stupid N@m3 ![]() CM 690 http://forums.bit-tech.net/showthread.php?t=217260 RasPi http://forums.bit-tech.net/showthread.php?t=248805 OldNavY http://forums.bit-tech.net/showthread.php?t=217563 Last edited by Canardwc; 8th Nov 2012 at 19:45. |
| Thread Tools | |
| View Mode | |
