Reply
Thread Tools View Mode
Old 8th Nov 2012, 18:01   #21
legoman
breaker of things
legoman's Avatar
legoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for president
What build of XMBC is that? it looks lovely compared to the Xbian one im running
Also subbed as a fellow pi owner!
__________________
AMD Phenom X6 1605T @ 4.5Ghz |Corsair H80 |Gigbyte970A-UD3 | 2X4 GB Kingston HyperX Beast | ASUS AMD 6950 2GB DirectCU II | Corsair HX750 | Liteon DVD RW | Samsung HD103SJ 1Tb | Crucial M4 SSD 64GB | Phobya FanMax 6 | Edimax EW-7612Pln | Coolermaster Storm Trooper | Win 7 Pro 64it | Roccat ARVO | Logitech G500 | Bamboo 1 | Samsung SyncMaster 2033SW
legoman is offline   Reply With Quote
Old 8th Nov 2012, 18:03   #22
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Canardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the Dremel
Originally Posted by jay2 View Post
I'm still waiting my raspi delivery
an XBMC+android raspi would be great..
My Mod is cheaper than yours...
Canardwc is offline   Reply With Quote
Old 8th Nov 2012, 18:05   #23
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Raspbmc. Follow this :
http://www.raspbmc.com/download/
Old 8th Nov 2012, 18:13   #24
C4B12
Scratchbuilder
C4B12's Avatar
C4B12 has yet to learn the way of the DremelC4B12 has yet to learn the way of the Dremel
Originally Posted by Canardwc View Post
A RasPi in aluminim coc@ col@ bottle??
You know me
__________________
Scratch builds | Cold Winter | CURV3D | The Red One |
Casemods | BarPC |
Check out my facebook-page where I post everything about my mods. Like/share if you want to.
C4B12 is offline   Reply With Quote
Old 8th Nov 2012, 18:27   #25
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Originally Posted by C4B12 View Post
You know me
Just an intuition
Old 8th Nov 2012, 18:38   #26
Knighthammer
Multimodder
Knighthammer has yet to learn the way of the Dremel
subbed for sure! Also fellow Pi owner.
Knighthammer is offline   Reply With Quote
Old 8th Nov 2012, 19:12   #27
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
You only need the video ID in the youtube link (udh7F6L3vMc in this case)
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 8th Nov 2012, 19:45   #28
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Many thanks for the tip... First time. I tried 3/4 times.. I have no more hairs..
I'll fix it know.
Old 8th Nov 2012, 19:51   #29
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Time to think about the encloseure of the pPi.
First idea and first test (always neat ), use black foam board. But it seems complicate (Because I don't like Maths)
Old 8th Nov 2012, 21:12   #30
Mosquito
Hypermodder
Mosquito's Avatar
I'll fix it know.
Always glad to help
__________________
Mosquito
Old 8th Nov 2012, 23:42   #31
Canardwc
Gentel-Mod'R
Canardwc's Avatar
After tests, I 3D render my Idea via SketchUP.
Old 9th Nov 2012, 01:04   #32
dark_avenger
Raspberry Pi owner
dark_avenger's Avatar
dark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysis
Sub'd
I like the USB hub mounted on top keeps the form factor nice and small.
One day I'll get around to building a case for mine haha
__________________
Xigmatek Elysium WC i7 920 Build
Raspberry Pi in a Bay
Speaker Box Project
Join the CPC/Bit-Tech FAH Team #35947
dark_avenger is offline   Reply With Quote
Old 10th Nov 2012, 00:40   #33
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Done the first Model Case in foam board
Drawings:
Cuting:
Removing first layout of paper and foam:
Old 10th Nov 2012, 05:56   #34
dancingbear84
Ultramodder
dancingbear84's Avatar
dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.
That looks really good. To be honest my only suggestion would be to move the power input to the rear to improve the cabling of things. I know you can't physically move this port, could you achieve something similar with a micro USB extension cable run inside the case to a point on the rear
Edit.
I'm an idiot that has just woken up, it was the audio port I was looking at. You've moved the power. D'oh.
__________________
Intel i5 2500k * Corsair H50 * 2 x Gkill Ripjaw Z 4gb * Asus Maximus V Gene * Evga 560Ti * OCZ Vertex 3 * 1 TB Samsung F2 * Antec Truepower 650* Fractal R3 * Win 7 Home Premium 64bit * LG 27" w2753vc
upgrade list:Blu-ray drive
It doesn't matter if you make a mistake, it only matters if you don't learn from it
dancingbear84 is online now   Reply With Quote
Old 10th Nov 2012, 08:58   #35
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Edit.
Thks
Old 10th Nov 2012, 09:34   #36
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
Cool thing
You made me thinking of buying a Raspberry Pi too. How does it perform? I would use itnas a media centre...
elAwesome is offline   Reply With Quote
Old 10th Nov 2012, 10:44   #37
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Originally Posted by elAwesome View Post
Cool thing
thks for ypur support. I bought RasPi 6 mounths ago and there were no correct distribution for media center or only slow and very complicate OS based on Openelec. Since few weeks, Rasbmc is operationnal, easy to install, auto updating via internet and is just the fastest and the easier way to do a media center on Raspi; for my opinion. It s fluid and reactive. Have you see my video & music test?
Old 10th Nov 2012, 11:12   #38
Ra6
Multimodder
Ra6's Avatar
Ra6 has yet to learn the way of the Dremel
Great job! The only problem about the USB hubs is that if you plug some device that is a wider than normal, it's impossible to plug any more thing... ^^'
Ra6 is offline   Reply With Quote
Old 12th Nov 2012, 08:48   #39
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
It's excellent think I'll have to do a Rasbmc with 1 for a present, so small I could use scraps.
Waynio is offline   Reply With Quote
Old 12th Nov 2012, 08:54   #40
Gaming_freak_10
Hypermodder
Gaming_freak_10's Avatar
Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.
This could be useful for an Media center.. where do I find the Raspberry Pi?? There's no Canada resellers around here..
__________________
Steam: Gaming_Freak_10. Xbox 360: BlueEyeDragoh. PS3: enickel2009 (PS3's dead Until I manage to fix the problem)
Gaming_freak_10 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
