Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Nov 2012, 09:41   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for president
Microsoft waves goodbye to FAT with exFAT deals
New devices get proprietary file system.
http://www.bit-tech.net/news/hardwar...rosoft-exfat/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 8th Nov 2012, 09:55   #2
theshadow2001
Ultramodder
theshadow2001's Avatar
theshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for president
Another move to make Microsoft a more walled in Apple like eco system. I don't like it.
theshadow2001 is online now   Reply With Quote
Old 8th Nov 2012, 10:12   #3
rollo
I Mod, Therefore I Own
rollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for president
Fat is 35 years old and is a broken piece of crap that nobody uses on there pc anymore anyway.
NTFS has largely replaced all FAT systems in business, Windows 7 does not even offer the option of formating the drive as FAT last i checked.
The only software this will effect is linux which is likely to be left out in the cold.
rollo is offline   Reply With Quote
Old 8th Nov 2012, 10:22   #4
mm vr
The cheesecake is a lie
mm vr's Avatar
mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!
exFAT cannot be supported under Android, at least not as a kernel mode driver. It would have to be released under the GPL.
OSR2 is short for "OEM Service Release", by the way.
__________________
Intel Core i5 3570K @ 4.5GHz || Thermalright Ultra 120 eXtreme || Gigabyte GA-Z77-D3H || 2x 8GB Corsair Vengeance LP DDR3 1600MHz CL10 || Radeon 4870 512MB || AC Accelero Twin Turbo Pro || Asus Xonar DX || Samsung 830 128GB || 2x WD Blue 640GB || Corsair HX620 || Antec P182 || Samsung SM 2232 + 2233 || Windows Server 2012
mm vr is offline   Reply With Quote
Old 8th Nov 2012, 10:25   #5
steveo_mcg
STILL ALIVE
steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.
And any hardware manufacturers who do not wish to licence the new fat from MS...
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 8th Nov 2012, 10:31   #6
Griffter
Supermodder
Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!
sooo linux which is likely to be left out in the cold i guess. ;P
Griffter is offline   Reply With Quote
Old 8th Nov 2012, 10:50   #7
Gareth Halfacree
WIIGII!
bit-tech Staff
Actually, you *can* format drives as FAT32 under modern Windows - but only *external* drives. The option doesn't appear by default for internal drives, nor for drives above 32GB. The functionality still exists in Windows 8, 'cos otherwise you wouldn't be able to format memory cards ready for use with digital cameras and the like - all consumer-grade version of which still use FAT.
Sure it can be supported under Android: a project has been working on a kernel module for exFAT support since 2009, while a FUSE module also exists. 'Course, they're not suitable for inclusion in the Linux kernel itself - but the GPL says nothing about developers writing their own code for use on their own devices, while Microsoft will happily grant an exFAT licence to anyone willing to pay.
Huh, I always thought it was "Operating System Release 2." You learn something new every day... I'll update the article - ta!
__________________
Old 8th Nov 2012, 10:50   #8
steveo_mcg
STILL ALIVE
I realise that was tongue in cheek but I'll continue any way .
Computers are not the only places you'll find FAT, anything with internal storage will most likely be running a FAT file system. So your camera, your television, web streaming blu-ray the list goes on.
A free, (relatively) reliable and most importantly ubiquitous file system makes life much simpler for all us geeks not just Linux users .
__________________
ook
Old 8th Nov 2012, 11:40   #9
isaac12345
Supermodder
isaac12345 has yet to learn the way of the Dremel
The fact that this filesystem is proprietary makes this decision seem like more of a money making thing rather than 'fixing' an old filesystem. If they truly wanted to 'fix' it they would make it open like FAT.
__________________
"The essence of the contemporary monetary system
is creation of money,out of nothing,by private banks’ often foolish lending..."
- Martin Wolf,Financial Times,9th November 2010
Intrigued? Find out more at www.positivemoney.org.uk
isaac12345 is offline   Reply With Quote
Old 8th Nov 2012, 11:41   #10
NikoBellic
Tech Addict
NikoBellic's Avatar
NikoBellic has yet to learn the way of the Dremel
I really hope to see a new file format in my next smartphone in early 2013, because I am one of those few people that can actually go over 4GB in a single file (I have a 12GB 1080p movie) and at the moment it is annoying when you have to find ways in which you can divide those files yet still use them on your devices
PS: I know some people would think it is not really needed having a movie displayed in 1080p on a mobile device, but when I shrunk it down to my device resolution of 800x480, you could see that the film looked horrid, yet, when I divided the file and watched it in 1080p, it looked amazing... just a shame about the pauses you get when watching the film and half way through it goes to the next file...
And yes I do know that you can format the sdcard to ntfs on some android devices & it'll work with a few mods, but I can't risk bricking my phone.
__________________
Intel Core i5 750 --- Gigabyte GA-P55M-UD2
Radeon 5850 1GB -- 8GB DDR3 OCZ Platinum 1333MHz
OCZ Agility 60GB --- Windows 7 x64 (Ultimate)
NikoBellic is offline   Reply With Quote
Old 8th Nov 2012, 11:57   #11
azazel1024
Supermodder
azazel1024 has yet to learn the way of the Dremelazazel1024 has yet to learn the way of the Dremel
Is it really that hard to get along and just come up with one standard file format across all OSs? Or at least one common file format for removable media?
I like me some Windows, but seriously, it is annoying as hell when I have my external HDD along and want to transfer a whack of files to my cousin at the holidays....and since he has a Mac Book Pro...no go, as it refuses too with the NTFS formating on the 640GB external drive. So then I am stuck slapping the images on a thumb drive and transfering them in 2 or 3 steps because the only way they can talk to each other is through FAT32 (at least storage to storage).
Sigh. I really hope exFAT doesn't become standardized and leave people out in the cold. I am not a huge Linux fan, but it deffinitely has its place. It'll be a sad/bad day if, for example, my only option on my future digital camera is to use it with Windows, or a Mac or I can get a special open source digital camera that sucks and will work with Linux.
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 8th Nov 2012, 12:20   #12
isaac12345
Supermodder
Azazel1024, that's the scenario I envisaged too while reading the article. It'll be a mighty pain in the ass. And I'm sure its not hard for such massive companies to come up with one standard format. It's just a matter of will, financial and political.
__________________
Old 8th Nov 2012, 12:22   #13
Shirty
Good news everyone!
Shirty's Avatar
Shirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run Crysis
What has Microsoft got against fat people anyway? Steve Ballmer is quite fat.
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500
Why.
Shirty is offline   Reply With Quote
Old 8th Nov 2012, 12:22   #14
dyzophoria
Supermodder
dyzophoria has yet to learn the way of the Dremel
rather than leave exFAT on the cold I wish it doesn't become a closed standard so that it can be adapted by everyone faster, well unless everyone licenses exFAT. lol, i don't really want to stick to fat32 anymore honestly
__________________
[FONT=Lucida Console]picture this..[/FONT] // [FONT=Tahoma][FONT=Fixedsys]picture that..[/FONT][/FONT]
dyzophoria is offline   Reply With Quote
Old 8th Nov 2012, 12:35   #15
Guinevere
Mega mom
Guinevere's Avatar
Guinevere - may the hammer of Bindi be bestowed on youGuinevere - may the hammer of Bindi be bestowed on youGuinevere - may the hammer of Bindi be bestowed on youGuinevere - may the hammer of Bindi be bestowed on youGuinevere - may the hammer of Bindi be bestowed on youGuinevere - may the hammer of Bindi be bestowed on youGuinevere - may the hammer of Bindi be bestowed on youGuinevere - may the hammer of Bindi be bestowed on youGuinevere - may the hammer of Bindi be bestowed on youGuinevere - may the hammer of Bindi be bestowed on youGuinevere - may the hammer of Bindi be bestowed on you
You had the resources of the entire internet and a desktop PC and you couldn't down-sample a 1080p video to 480p without it looking much worse than the same resizing performed during playback? i think if you'd have persevered you'd have been able to come up with something equally as good if not better.
Guinevere is offline   Reply With Quote
Old 8th Nov 2012, 13:57   #16
rollo
NTFS is the future for internal storage
Wether exfat takes off for external storage time will tell.
Old 8th Nov 2012, 13:59   #17
proxess
Hypermodder
proxess can run Crysisproxess can run Crysisproxess can run Crysisproxess can run Crysisproxess can run Crysisproxess can run Crysisproxess can run Crysisproxess can run Crysis
Linux will be fine. It's the same as NTFS was. FUSE will solve all the issues.
__________________
Laptop: i3 330M 2.13GHz; 2x 4GB 1066MHz; Radeon 5650 1GB @ 675/1020MHz; Crucial M4 256GB SSD; Ubuntu 12.04 x64 and Windows 7 x64.
Ubuntu #8076 / Linux #429448
proxess is offline   Reply With Quote
Old 8th Nov 2012, 14:15   #18
Alecto
Minimodder
Alecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the Dremel
FAT is not missing hard links - you can have any entry pointing to a cluster already in use and pointed to by another entry. This constitutes a hard link. Might not be exactly standard (and FS checking software will report it as error) but it can be done.
Alecto is offline   Reply With Quote
Old 8th Nov 2012, 15:13   #19
PCBuilderSven
Multimodder
PCBuilderSven has yet to learn the way of the Dremel
open-source operating systems like Linux are likely to be left out in the cold.
Really? How long will it take reverse engineer it and add compatibility? Isn't NTFS also proprietary, and that works perfectly.
PCBuilderSven is offline   Reply With Quote
Old 8th Nov 2012, 15:37   #20
mi1ez
Hypermodder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
I actually came across an XP machine only today with 4x FAT32 partitions on one disk! It took me a good 10 minutes to figure out why I couldn't paste the 4.2 GB PST file to it despite some 40GB of free space!
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Reply
Tags
atmos global, black magic, exfat, fat, fat16, fat32, file system, journalling, microsoft basic, nextodi, refs, sharp, sigma, windows 8, windows 95
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
