Reply
Thread Tools View Mode
Old 9th Nov 2012, 05:27   #1
TheGreatSatan
Dark Lord of BT!
TheGreatSatan's Avatar
TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.
Project: Studded - COMPLETE!
I've always loved steel diamond plate. It's such a strong and attractive metal and I like using it here and there when modding
For a while now, I've been thinking that a computer made entirely of diamond plate would be pretty cool. It will be in a diamond plate box shrouded inside in diamond plate too!
My canvas is this diamond plate steel box
First, I got a micro ATX motherboard and PSU to see if it would all fit. These are not the components that I'm using, but just a size guide for what I need
__________________
2011-3 WET DREAM MACHINE
MountainMods U2-UFO with an Intel i7 5960x (8-Core), MSI X99S-SLI, 32GB (4GB x 8) DDR4, 960GB Crucial M500, 1TB Samsung 850 Pro, 240GB Sandisk Extreme, Corsair AX1500i 80 Titanium, GTX Titan X, a Corsair H80i and 15 Green LED Coolmax fans!
TheGreatSatan is offline   Reply With Quote
Old 1st Jan 2013, 16:35   #2
TheGreatSatan
Dark Lord of BT!
It only took me 6 weeks of Playing Borderlands 2 to finally cut the window
And the card slots too
__________________
Old 1st Jan 2013, 17:23   #3
ASPHIAX
Hypermodder
ASPHIAX's Avatar
ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!
Yeah, a new TheGreatSatan build !
You my friend are a modding machine!
__________________
Sander van der Velden
ModWithMe Concept Founder
E. Sander@ModWithMe.com
FB. https://www.facebook.com/ModWithMe
ASPHIAX is offline   Reply With Quote
Old 6th Jan 2013, 03:51   #4
TheGreatSatan
Dark Lord of BT!
I cut out the backplate area
And the PSU intake
Then I riveted the motherboard tray in place and added the PSU
__________________
Old 6th Jan 2013, 03:55   #5
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming Saiyan
Nice start! So how sturdy is the box at the handle? It looks kind of thin. Looking forward to seeing how this progresses, Subbed.
__________________
Deders - What if you touch yourself with kittens?
.//TuNdRa - Short of standing on a street corner (I'd make an ugly hooker, anyhow.)
i7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, MSI 660TI 3GB, BFG 260 GTX Core 216 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is offline   Reply With Quote
Old 6th Jan 2013, 04:18   #6
TheGreatSatan
Dark Lord of BT!
It's full diamond plate. This thing is hard to cut!
__________________
Old 17th Feb 2013, 05:36   #7
TheGreatSatan
Dark Lord of BT!
Now on to the motherboard shroud. I mapped out the motherboard using cardboard
And then traced it onto the piece of diamond plate I'm using
Then I just had to cut it all out
I can't have the bare metal from the diamond plate touching the surface of the motherboard, so I'm coating the bottom with liquid rubber
The dry time will be at least a couple of days
__________________
Old 19th Feb 2013, 16:50   #8
Mechh69
Mechh69's Avatar
About time you did something on this! . Is that video card going to fit correctly with the diamond plate in-between? Are you going to have a heat problem with the chipset/mofset as there doesn't look like there is any where for air to circulate around the board. Just a thought.
__________________
Old 17th Mar 2013, 15:44   #9
TheGreatSatan
Dark Lord of BT!
I cut out two 70mm fan intakes
I'm using these aluminum 70mm fans for the perfect match, but I'm still waiting on the grills
And a 120mm on top
The grills arrived. I'll be using longer screws with nuts, and rubber washers
I bought feet for a Lian Li case
Once all the fans and feet were mounted I used my dremel to cut off the excess screw thread
I'm gonna put the power button on the back
Time to get the wiring
__________________
Old 18th Mar 2013, 12:46   #10
TheGreatSatan
Dark Lord of BT!
I had to change the PSU to something that will fit easier for the shroud I'm gonna be adding.
And I'm happy that it boots
I'm using a 60GB SSD that I got for $20!!
And my old Radeon 6850 too
__________________
Old 20th Mar 2013, 13:05   #11
TheGreatSatan
Dark Lord of BT!
Now I have a big mess of wires
I'm using a shroud to cover the wires
And cut a notch for the wires to pass through
Then set it in
Then I spent quite a while trying to get the cover to fit on the motherboard with no luck. I even cut it into pieces hoping to segment it together and it still won't stay in place
Moving on....
For now I'm just adding a light
One thing I've been meaning to do is make another piece for the back of the video card. I even used a little extra spray rubber to adhere the metal to the PCB.
I put a window on, but the double sided tape looks rediculous
So I used aluminum tape to cover it up
I guess that's it, I'm done.
Ending specs:
AMD FX4100
Asrock 880GM-LE
4GB DDR3
MSI HD 6850
60GB SSD
380W PSU
CM S524 Heatsink
__________________
Old 20th Mar 2013, 14:00   #12
aramil
One does not simply upgrade Windows
aramil's Avatar
aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.
Must stop looking at the shinny thing :cool:
Seriously great job :thumbup:
__________________
System: Intel i5 3570K delidded CLU @ 4.4Ghz | Asus Stabertooth Z77 |Palit GeForce GTX 980 Super Jetstream 4Gb | Samsung 840 EVO 250Gb | Samsung 1Tb F2 | WD 1Tb | Corsair 750TX v2 | 16Gb (4x4) Corsair Vengence | Corsair K90 Keyboard | XSPC-Raystorm-750-RS2400 | Zalman MS800 | AOC 27" 2560x1440 | Windows 10 Pro 64bit | Linx10 Tablet ED: CMDR Aramil Lorrathain Become a Star Citizen get 5,000 free Credits HERE
aramil is offline   Reply With Quote
Old 21st Mar 2013, 12:08   #13
Mechh69
Mechh69's Avatar
Looking good keep it up. Sorry to hear that the MB cover isn't working out.
__________________
Old 21st Mar 2013, 15:23   #14
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Nice work and very shiny!
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 22nd Mar 2013, 14:52   #15
WhatTheTech
Macmodder Addict
WhatTheTech has yet to learn the way of the Dremel
New competition idea: "Bomb-Proof Mod of the Month".
You win.
WhatTheTech is offline   Reply With Quote
Old 22nd Mar 2013, 15:38   #16
Mechh69
Mechh69's Avatar
So what are the temps like?
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
