Reply
Thread Tools View Mode
Old 9th Nov 2012, 06:02   #1
jj_sky5000
Multimodder
jj_sky5000's Avatar
jj_sky5000 has yet to learn the way of the Dremel
Cooler Master Scout 2 Camo Edition
Its been a crazy summer & fall , and has been a blast with my family and friends, but back into the garage i go for a few projects. First project is the New Cooler master Scout 2 case, Having a military name and theme on the box i am definitely going a camo theme
The case has a very sleek design and the Handle on top is great for lan gaming
I like the window, but since i will be watercooling i will be removing the fan grills and making it bigger
planning on removing one or both hard drive cages to make room for teh water cooling
Time to break it all down
using the scout insignia on the side panel
Camo paracord just need in a few other builds this will be perfect.
jj_sky5000 is offline   Reply With Quote
Old 9th Nov 2012, 06:07   #2
jj_sky5000
Multimodder
jj_sky5000's Avatar
One would think growing up hunting a fishing i would be able to paint camo that wasnt the case lol . It took me three tries and several stencils before i begin to like the design .
sanded and Primed
black then brown
beige
a few touches up and it will be finished
Started cutting out the Guns and skull out of plexi. I ended up redoing the skull
testing the position
Old 9th Nov 2012, 12:27   #3
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
well someone should tell CM that loaded guns will shoot much better - check that "military clown" on case box...
oh! nice paintjob here!
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 9th Nov 2012, 14:30   #4
krussellusaf
Modder
krussellusaf has yet to learn the way of the Dremel
The paint job turned out great but I think the skull could be improved. I am excited to see more. Makes me want to get to work right now.
krussellusaf is offline   Reply With Quote
Old 14th Nov 2012, 00:41   #5
jj_sky5000
Multimodder
jj_sky5000's Avatar
Touching up a few spots
getting ready to cut a bigger Window out , I did like how this look but going water cooling make a pretty easy descion for me to do it.
sorry a little blurry
The paint seems to flow to gether nicely
Camo, aluminum and Mesh from the case what could i make?
using the logo from the CM scout 2 box
no fingers where lost this time ( where my thumb?) jk
alittle touch of paint suggestion from my friend Haley!!!
More to come thanks for looking
Old 14th Nov 2012, 11:48   #6
krussellusaf
Modder
That Scout 2 logo turned out great. I will be looking for more.
Old 14th Nov 2012, 15:24   #7
jj_sky5000
Multimodder
jj_sky5000's Avatar
Thank you !!!
Old 7th Dec 2012, 02:58   #8
jj_sky5000
Multimodder
jj_sky5000's Avatar
A little break for the holiday Back to modding, Adding another cut out on the case . using a new blade and u can make some nice tight cuts with this.
Cm red
but the finish looks pretty good
Making room for the 240 rad for the front of the case, The optical drive bays made it too snug, i no longer use optical drives so one less bay wont hurt. so time to bring the dremal out
Fits now
Stayed tuned more to come!!
Old 7th Dec 2012, 03:16   #9
jj_sky5000
Multimodder
jj_sky5000's Avatar
Next up The camo shroud for the interior!!! Dremal Time
mesuring it up
getting ready to make a bend, now wear did i put that bender( all 250 lbs of it)
It was alot harder to bend than i thought, I need to eat some more and try again
time to to connect them
test fit
sand down my edge
a little paint
a little camo
More to come!!!
Old 7th Dec 2012, 04:23   #10
Dmlindley
Minimodder
Dmlindley's Avatar
Dmlindley has yet to learn the way of the Dremel
Love the use of the mesh! very nicely done
Dmlindley is offline   Reply With Quote
Old 8th Dec 2012, 23:27   #11
jj_sky5000
Multimodder
jj_sky5000's Avatar
More updates!!!!
finishing cutting out the window
Cut out a piece of smoked arcylic
Time to etch!!!
Lights out flashlight on( redneck light table (lol)
I used the etcher on teh ponited ends then bring out the dremal to finish the larger areas
I will finish the missed spots and clean it all up
Side window panel done!!!
Old 9th Dec 2012, 08:40   #12
KrunchR
Supermodder
KrunchR's Avatar
KrunchR has yet to learn the way of the Dremel
looks good, dude!
__________________
SYSTEM ONE on hold for now....
But my KnuckleDuster makes a Return!
KrunchR is offline   Reply With Quote
Old 11th Dec 2012, 02:49   #13
jj_sky5000
Multimodder
jj_sky5000's Avatar
In order to be stealthy We need to add some silent fans, But clear isnt going to work.
One of my fav thing about these fans i sthe fan just pops off
Flat Black
next up sleeving
little ass screw drive does have a purpose
all yea camo sleeving
Old 12th Dec 2012, 23:53   #14
jj_sky5000
Multimodder
jj_sky5000's Avatar
A couple of cool things about this pc , its headed to CES in las Vegas in Jan ( super excited). I will have to finish with the components when its gets back, It also entered inot the 2012 coolermaster case mod contest If you like it please follow the link on facebook http://woobox.com/qz4swg/vote/for/138536 also vote for your favorite thank you
Thanks for watching keep watching after the new year for the New components
Old 13th Dec 2012, 15:24   #15
WALKYRIE
Minimodder
WALKYRIE has yet to learn the way of the Dremel
Hi, I dont understand why you black spray the frame of the 120mm fans, there are everywhere online plenty of fans available with black frame
WALKYRIE is offline   Reply With Quote
Old 13th Dec 2012, 18:56   #16
Stem83
Addicted to modding.
Stem83's Avatar
Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.
Cos you use what you already got and change it, thats modding aint it?
I think it looks good, my opinion, im not overly struck on the guns and skull on the side panel. That aside its a nice mod, good looking camo.
Stem83 is offline   Reply With Quote
Old 14th Dec 2012, 02:53   #17
jj_sky5000
Multimodder
jj_sky5000's Avatar
I have about 15 of those fans and they are pretty slient and free it was easy to use them .
Thank you Stem83
Old 17th Dec 2012, 22:59   #18
jj_sky5000
Multimodder
jj_sky5000's Avatar
Last nite to vote for the 2012 Cooler Master MOD contest. throw some support by casting a vote!!!
thanks for voting!!!!
Old 10th Jan 2013, 01:24   #19
jj_sky5000
Multimodder
jj_sky5000's Avatar
Well The case Made it to vegas and to CES 2013 in one piece,
Wes from Lanoc took some really nice Pics of the cases In the cooler Master Suite and I thought i would Share
Hope this will hold you over
Thanks for looking !!!
Old 10th Jan 2013, 01:54   #20
xXSebaSXx
Supermodder
xXSebaSXx's Avatar
xXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run CrysisxXSebaSXx can run Crysis
Case? What case? I don't see no case anywhere on them pictures.
Great mod my man... very nice use of mesh and cammo theme.
xXSebaSXx is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
